| 0003168 | Path | Bug | public | 2017-08-26 20:52 | 2017-10-07 23:33 |
| Reporter | marc | Assigned To | mlampert | ||
| Platform | Mac | OS | Mac OS | OS Version | 10.12.5 |
| Summary | 0003168: Path >Pocket > Predictably ignores some Pockets | ||||
| Description | The Path > Pocket function has trouble detecting only certain letter of the alphabet that are cut into a piece. | ||||
| Steps To Reproduce | Make a Cube. Add to a Part File Select a surface Select "Draft" > (S,S) ShapeString type the alphabet add the "avenir.tff" font Select "Part Design" > cut to a depth of 10 thou set the default tool to an engraver, cutting diameter=5 thou, cutting angle 45 Deg select the floor of each letter Select the Path > "pocket" select any "pattern" Certain letters will be left out as if the slot is too small even though it is clear there is enough room for the cutter to reach | ||||
@sliptonic please weigh in @marc thanks for the report. Please read https://freecadweb.org/wiki/Tracker to familiarize yourself with how to post bugs/features. Thanks |
Any update on this? It appears the algorithm doesn't play nice with little tools like my engraver. |
@marc again please read tracker guidelines. You need to add your full FC info (Help > About FreeCAD > Copy to clipboard) also it is customary to let the devs know on the forum first. That's how you get more publicity about issues. CC @mlampert care to weigh in? |
I'm afraid this is a known issue with no solution as of today (https://forum.freecadweb.org/viewtopic.php?f=15&t=23492). OCC just released a new version and we still have to see how it'll behave. In order to reproduce, can you attach your FC file please and your full version info (see Kunda1's comment above on how to get that)? |
I've compiled FC with the latest version of OCC (7.2) and the issue seems to be resolved - however I cannot verify/test without having the actual file. |
Fixed by new pocketing operation https://github.com/FreeCAD/FreeCAD/pull/1004 |
| 2017-08-26 20:52 | marc | New Issue | |
| 2017-08-26 20:52 | marc | File Added: Screen Shot 2017-08-26 at 1.28.30 PM.png | |
| 2017-08-26 20:52 | marc | File Added: Avenir-Roman.ttf | |
| 2017-08-28 19:38 | Kunda1 | Note Added: 0010032 | |
| 2017-09-05 06:45 | marc | Note Added: 0010068 | |
| 2017-09-05 19:47 | Kunda1 | Note Added: 0010069 | |
| 2017-09-05 20:16 | mlampert | Note Added: 0010070 | |
| 2017-09-06 02:54 | Kunda1 | Status | new => feedback |
| 2017-09-07 20:58 | mlampert | Note Added: 0010089 | |
| 2017-10-07 23:32 | mlampert | Assigned To | => mlampert |
| 2017-10-07 23:32 | mlampert | Status | feedback => assigned |
| 2017-10-07 23:33 | mlampert | Status | assigned => closed |
| 2017-10-07 23:33 | mlampert | Resolution | open => fixed |
| 2017-10-07 23:33 | mlampert | Fixed in Version | => 0.17 |
| 2017-10-07 23:33 | mlampert | Note Added: 0010260 |
