| 0003169 | FreeCAD | Bug | public | 2017-08-27 03:21 | 2017-10-17 17:15 |
| Reporter | yclee126 | Assigned To | wmayer | ||
| Summary | 0003169: Mesh Design WB tools does not work on translated object | ||||
| Description | In Mesh Design workbench, the mesh cut tool(Cuts a mesh with a picked polygon) and some others does not works on object which has placement value, it acts like if the object is not translated. The following example is for mesh cut tool, also I've found same error in Curvature plot tool and Split mesh tool.(I couldn't test error for other tools, sorry) Edit: Forum thread: https://forum.freecadweb.org/viewtopic.php?f=3&t=24073 | ||||
| Steps To Reproduce | 1.Create a new document 2.Set to top view(2) 3.Go to Mesh Design WB 4.Meshes > Regular soild > Create a 10x10x10mm cube 5.Select the cube > placement (...) > type 10mm for x coordinate > OK 6.Select the cube, execute the mesh cut tool 7.select right-bottom part of the cube with triangle shape > inner 8.The cube does not being cut 9.Do step 6 10.Do step 7, but select it like if the cube does not translated 11.The cube being cut. | ||||
| Additional Information | OS: Windows 7 Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.16.6706 (Git) Build type: Release Branch: releases/FreeCAD-0-16 Hash: f86a4e411ff7848dea98d7242f43b7774bee8fa0 Python version: 2.7.8 Qt version: 4.8.7 Coin version: 4.0.0a OCC version: 6.8.0.oce-0.17 | ||||
| Tags | Mesh | ||||
@chrisb care to weigh in ? @yclee126 FYI please open a forum thread before you open a ticket to confirm that this is a valid bug especially since you are reporting a 0.16 bug and over 5K commits have been made to 0.17dev. |
@Kunda1 Sorry for not posting a topic in forum first, I'll remember this for not happening again. Later I posted the topic in forum, but no one tested it on the newest 0.17 dev version. So I've downloaded the newest 0.17 dev version, and the bug occurred as same. A quick proof video is uploaded here, I recorded it on my laptop, please ignore flaccid cursor movement. OS: Windows 7 Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.17.11919 (Git) Build type: Release Branch: master Hash: fccb5dbc87b919164610296adc96aa8b4fe4825e Python version: 2.7.8 Qt version: 4.8.7 Coin version: 4.0.0a OCC version: 7.1.0 Locale: Korean/RepublicOfKorea (ko_KR) |
@yclee126 if you posted to the forum, please link to this ticket and vice-a-versa Thanks! Also thanks for your detailed bug report especially re-testing on 0.17. We appreciate the effort! |
I am sorry, but I have no experience with meshes. |
@Kunda1 link to the post : here @chrisb What's the problem? Just make your experience now! |
Confirmed by @bejant on the forum thread |
Added forum thread: https://forum.freecadweb.org/viewtopic.php?f=3&t=24073 |
https://github.com/FreeCAD/FreeCAD/commit/9c2528a982eb10a5cd15af738b72d63de44d60f6 https://github.com/FreeCAD/FreeCAD/commit/3bd425df26e5a3a973928c69644c162c0a25bc49 |
| 2017-08-27 03:21 | yclee126 | New Issue | |
| 2017-08-27 03:21 | yclee126 | Tag Attached: Mesh | |
| 2017-08-28 14:16 | Kunda1 | Note Added: 0010019 | |
| 2017-08-28 16:02 | yclee126 | Note Added: 0010024 | |
| 2017-08-28 16:07 | Kunda1 | Note Added: 0010025 | |
| 2017-08-28 16:07 | Kunda1 | Note Edited: 0010025 | |
| 2017-08-29 06:52 | chrisb | Note Added: 0010038 | |
| 2017-08-29 15:01 | yclee126 | Note Added: 0010040 | |
| 2017-08-29 15:05 | yclee126 | Note Edited: 0010040 | |
| 2017-08-29 17:36 | Kunda1 | Status | new => confirmed |
| 2017-08-29 17:36 | Kunda1 | Note Added: 0010041 | |
| 2017-08-29 17:38 | Kunda1 | Target Version | => 0.17 |
| 2017-10-10 19:04 | Kunda1 | Description Updated | |
| 2017-10-10 19:04 | Kunda1 | Note Added: 0010284 | |
| 2017-10-16 18:15 | wmayer | Assigned To | => wmayer |
| 2017-10-16 18:15 | wmayer | Status | confirmed => closed |
| 2017-10-16 18:15 | wmayer | Resolution | open => fixed |
| 2017-10-16 18:15 | wmayer | Fixed in Version | => 0.17 |
| 2017-10-16 18:15 | wmayer | Note Added: 0010302 | |
| 2017-10-17 17:15 | wmayer | Note Edited: 0010302 |
