| 0003173 | FreeCAD | Feature | public | 2017-08-30 22:22 | 2018-08-26 18:38 |
| Reporter | Sam | Assigned To | wmayer | ||
| Priority | none | Severity | feature | Reproducibility | always |
| Summary | 0003173: Allow renaming macros from the macro dialog | ||||
| Description | Forum thread: [Feature Request] Rename macro It occurred to me that it'd save me some time, and probably a bunch of others, if you were able to rename macros from the macro dialog. A rename button, or F2 on the name. So, I did some simple hacking to add a rename button. The code to do it was pretty much already there and I just hacked it around into a new function. While I was there I tidied up some white space and made the button enablement/clickability a bit saner. This looks like old code: It looks a bit loose, and and the style is inconsistent. Some more things could be tidied up while I'm here if you like. One thing I'd kind of like to add is a preference for the default option in the macro dialog. I'd prefer the default was edit, not execute; I prefer to look before I leap. Also, I still haven't read the FreeCAD style guide, or patch submission guidelines, apart from the sticky at the top of the developers forum. If it pisses you off that I've gone off half cocked like this, I don't blame you! I'll get around to it OK? | ||||
| Additional Information |
0001-Add-a-rename-option-to-the-macro-dialog.patch.txt (7,368 bytes)
From d6240300ed1b77c9ed808ac8efa8b7625d7fe639 Mon Sep 17 00:00:00 2001
Message-Id: <d6240300ed1b77c9ed808ac8efa8b7625d7fe639.1504098250.git.aaron@pelly.co>
Date: Thu, 31 Aug 2017 01:03:42 +1200
Subject: [PATCH] Add a rename option to the macro dialog
Also took out a touch of trailing white space.
src/Gui/DlgMacroExecute.ui | 13 ++++++++
src/Gui/DlgMacroExecuteImp.cpp | 76 +++++++++++++++++++++++++++++++++++++++---
src/Gui/DlgMacroExecuteImp.h | 1 +
3 files changed, 85 insertions(+), 5 deletions(-)
diff --git a/src/Gui/DlgMacroExecute.ui b/src/Gui/DlgMacroExecute.ui
index 1b6e526..319e916 100644
--- a/src/Gui/DlgMacroExecute.ui
+++ b/src/Gui/DlgMacroExecute.ui
@@ -246,12 +246,25 @@
</item>
<item>
<widget class="QPushButton" name="editButton">
+ <property name="enabled">
+ <bool>false</bool>
+ </property>
<property name="text">
<string>Edit</string>
</property>
</widget>
</item>
<item>
+ <widget class="QPushButton" name="renameButton">
+ </property>
+ <property name="text">
+ <string>Rename</string>
+ </property>
+ </widget>
+ </item>
+ <item>
<spacer>
<property name="orientation">
<enum>Qt::Vertical</enum>
diff --git a/src/Gui/DlgMacroExecuteImp.cpp b/src/Gui/DlgMacroExecuteImp.cpp
index d512e90..d9de284 100644
--- a/src/Gui/DlgMacroExecuteImp.cpp
+++ b/src/Gui/DlgMacroExecuteImp.cpp
@@ -53,9 +53,9 @@ namespace Gui {
MacroItem(QTreeWidget * widget, bool systemwide)
: QTreeWidgetItem(widget),
systemWide(systemwide){}
~MacroItem(){}
bool systemWide;
@@ -65,8 +65,8 @@ namespace Gui {
/* TRANSLATOR Gui::Dialog::DlgMacroExecuteImp */
- * Constructs a DlgMacroExecuteImp which is a child of 'parent', with the
- * name 'name' and widget flags set to 'f'
+ * Constructs a DlgMacroExecuteImp which is a child of 'parent', with the
+ * name 'name' and widget flags set to 'f'
* The dialog will by default be modeless, unless you set 'modal' to
* true to construct a modal dialog.
@@ -90,7 +90,7 @@ DlgMacroExecuteImp::DlgMacroExecuteImp( QWidget* parent, Qt::WindowFlags fl )
fillUpList();
* Destroys the object and frees any allocated resources
DlgMacroExecuteImp::~DlgMacroExecuteImp()
@@ -136,11 +136,15 @@ void DlgMacroExecuteImp::on_userMacroListBox_currentItemChanged(QTreeWidgetItem*
executeButton->setEnabled(true);
deleteButton->setEnabled(true);
createButton->setEnabled(true);
+ editButton->setEnabled(true);
+ renameButton->setEnabled(true);
else {
executeButton->setEnabled(false);
deleteButton->setEnabled(false);
+ editButton->setEnabled(false);
+ renameButton->setEnabled(false);
@@ -152,11 +156,15 @@ void DlgMacroExecuteImp::on_systemMacroListBox_currentItemChanged(QTreeWidgetIte
createButton->setEnabled(false);
+ editButton->setEnabled(true); //look but don't touch
else {
@@ -170,11 +178,15 @@ void DlgMacroExecuteImp::on_tabMacroWidget_currentChanged(int index)
else {
else { //index==1 system-wide
@@ -184,11 +196,15 @@ void DlgMacroExecuteImp::on_tabMacroWidget_currentChanged(int index)
+ editButton->setEnabled(true); //but you can't save it
else {
@@ -376,4 +392,54 @@ void DlgMacroExecuteImp::on_deleteButton_clicked()
+ * renames the selected macro
+void DlgMacroExecuteImp::on_renameButton_clicked()
+ QDir dir;
+ QTreeWidgetItem* item = 0;
+ int index = tabMacroWidget->currentIndex();
+ if (index == 0) { //user-specific
+ item = userMacroListBox->currentItem();
+ dir.setPath(this->macroPath);
+ if (!item)
+ return;
+ QString oldName = item->text(0);
+ QFileInfo oldfi(dir, oldName);
+ QFile oldfile(oldfi.absoluteFilePath());
+ if (!oldfile.open(QFile::ReadWrite)) {
+ QMessageBox::warning(this, tr("System reports read-only file"),
+ tr("Can not rename '%1'.").arg(oldfi.absoluteFilePath()));
+ return;
+ // query new name
+ QString fn = QInputDialog::getText(this, tr("Renaming Macro File"),
+ tr("Enter new name:"), QLineEdit::Normal, oldName, 0);
+ if (!fn.isEmpty()) {
+ QString suffix = QFileInfo(fn).suffix().toLower();
+ if (suffix != QLatin1String("fcmacro") && suffix != QLatin1String("py"))
+ fn += QLatin1String(".FCMacro");
+ QFileInfo fi(dir, fn);
+ // check if new name exists
+ if (fi.exists()) {
+ QMessageBox::warning(this, tr("Existing file"),
+ tr("'%1'\n already exists.").arg(fi.absoluteFilePath()));
+ } else {
+ QFile file(fi.absoluteFilePath());
+ if (!oldfile.rename(fi.absoluteFilePath())) {
+ QMessageBox::warning(this, tr("Rename Failed"),
+ tr("Failed to rename to '%1'.\nPerhaps a file permission error?").arg(fi.absoluteFilePath()));
+ return;
+ fillUpList();
#include "moc_DlgMacroExecuteImp.cpp"
diff --git a/src/Gui/DlgMacroExecuteImp.h b/src/Gui/DlgMacroExecuteImp.h
index 4ec5b1e..3090fc1 100644
--- a/src/Gui/DlgMacroExecuteImp.h
+++ b/src/Gui/DlgMacroExecuteImp.h
@@ -50,6 +50,7 @@ public Q_SLOTS:
void on_createButton_clicked();
void on_deleteButton_clicked();
void on_editButton_clicked();
+ void on_renameButton_clicked();
protected Q_SLOTS:
void on_userMacroListBox_currentItemChanged(QTreeWidgetItem*);
2.7.4
@Sam made a PR for you: FreeCAD Pull Request 973 Thanks for your contribution ;) |
https://github.com/FreeCAD/FreeCAD/commit/21e1a5fde5de01c4493ae14206e0752bf76bac3b |
| 2017-08-30 22:22 | Sam | New Issue | |
| 2017-08-30 22:22 | Sam | File Added: 0001-Add-a-rename-option-to-the-macro-dialog.patch.txt | |
| 2017-08-30 22:22 | Sam | Tag Attached: #lowhangingfruit | |
| 2017-09-07 00:05 | Kunda1 | Note Added: 0010077 | |
| 2017-09-07 08:54 | wmayer | Assigned To | => wmayer |
| 2017-09-07 08:54 | wmayer | Status | new => closed |
| 2017-09-07 08:54 | wmayer | Resolution | open => fixed |
| 2017-09-07 08:54 | wmayer | Fixed in Version | => 0.17 |
| 2017-09-07 08:54 | wmayer | Note Added: 0010079 | |
| 2018-08-26 18:38 | Kunda1 | Tag Detached: #lowhangingfruit |
