| 0003174 | FreeCAD | Bug | public | 2017-08-31 13:54 | 2018-09-22 17:23 |
| Reporter | wmayer | Assigned To | vejmarie | ||
| Target Version | 0.18 | Fixed in Version | 0.17 | ||
| Summary | 0003174: Import of simple shapes no longer works | ||||
| Description | Simple shape objects like a compound of edges can be exported using the advanced STEP importer but reading them back is not longer possible. | ||||
| Steps To Reproduce |
| Additional Information | https://forum.freecad.org/viewtopic.php?f=10&t=23400&p=189013#p189013 | ||||
I know from where the issue comes. will fix it next week. |
@vejmarie would you be able to fix this before the upcoming release ? |
https://github.com/FreeCAD/FreeCAD/commit/52fe4cd2a7d4efae333bec7bd8393fac376c9608 As a workaround for 0.17 this sets the parameter ReadShapeCompoundMode to true to fully load a STEP model. |
The workaround implemented below should be sufficient to fix this issue. |
| 2017-08-31 13:54 | wmayer | New Issue | |
| 2017-08-31 13:54 | wmayer | Status | new => assigned |
| 2017-08-31 13:54 | wmayer | Assigned To | => vejmarie |
| 2017-08-31 14:37 | vejmarie | Note Added: 0010054 | |
| 2017-08-31 17:35 | Kunda1 | Target Version | => 0.17 |
| 2017-12-04 14:44 | Kunda1 | Note Added: 0010515 | |
| 2017-12-06 16:57 | wmayer | Priority | urgent => high |
| 2017-12-06 16:57 | wmayer | Severity | block => major |
| 2017-12-06 16:57 | wmayer | Target Version | 0.17 => 0.18 |
| 2017-12-06 16:57 | wmayer | Note Added: 0010520 | |
| 2018-09-22 17:23 | wmayer | Status | assigned => closed |
| 2018-09-22 17:23 | wmayer | Resolution | open => fixed |
| 2018-09-22 17:23 | wmayer | Fixed in Version | => 0.17 |
| 2018-09-22 17:23 | wmayer | Note Added: 0011818 |
