| 0003179 | PartDesign | General | public | 2017-09-08 10:36 | 2017-09-29 17:58 |
| Reporter | galou_breizh | Assigned To | wmayer | ||
| Summary | 0003179: PDN + AdditiveBox + MultiTransform (with LinearPattern) | ||||
| Description | You cannot choose the direction of a LinearPattern within a MultiTransform. Described in https://forum.freecadweb.org/viewtopic.php?f=19&t=23924 | ||||
| Steps To Reproduce | Steps to reproduce: - Make a sketch - Pad it - Make an Additive Box, named "Box" - Make a MultiTransform from "Box" - Right-click to add a LinearPattern - Notice that you cannot select any Direction for the LinearPattern. If you do a LinearPattern directly instead of the MultiTransform, every works as it should. MirrorTransform inside MultiTransform also works. | ||||
| Additional Information | OS: Ubuntu 14.04.5 LTS Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.17.11792 (Git) Build type: None Branch: master Hash: 7aec98ffb66065854a66d6d6715845fdbf0869a7 Python version: 2.7.6 Qt version: 4.8.6 Coin version: 4.0.0a OCC version: 7.1.0 Locale: English/UnitedStates (en_US) | ||||
Moved to 'PartDesign' |
Fix proposed in FreeCAD Pull Request 989 |
Fix merged in commit #2e2c041 |
This is strange. I use a FreeCAD version posterior to the merge of commit #2e2c041 and the problem is not solved. OS: Ubuntu 14.04.5 LTS Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.17.12208 (Git) Build type: None Branch: master Hash: 47cd41f25c1be55eabfe382f4a994d4b62eb8b0f Python version: 2.7.6 Qt version: 4.8.6 Coin version: 4.0.0a OCC version: 7.1.0 Locale: English/UnitedStates (en_US) |
Fixed in commit #7ae850d |
| 2017-09-08 10:36 | galou_breizh | New Issue | |
| 2017-09-08 10:36 | galou_breizh | File Added: bug_multitransform.fcstd | |
| 2017-09-08 12:09 | Kunda1 | Project | File formats => PartDesign |
| 2017-09-08 12:10 | Kunda1 | Product Version | => 0.17 |
| 2017-09-08 12:10 | Kunda1 | Note Added: 0010091 | |
| 2017-09-15 23:57 | Kunda1 | Note Added: 0010130 | |
| 2017-09-17 16:50 | normandc | Note Added: 0010135 | |
| 2017-09-27 08:11 | galou_breizh | Note Added: 0010199 | |
| 2017-09-29 17:58 | wmayer | Assigned To | => wmayer |
| 2017-09-29 17:58 | wmayer | Status | new => closed |
| 2017-09-29 17:58 | wmayer | Resolution | open => fixed |
| 2017-09-29 17:58 | wmayer | Fixed in Version | => 0.17 |
| 2017-09-29 17:58 | wmayer | Note Added: 0010215 |
