0003182FreeCADBugpublic2017-10-02 17:55
ReporterKarenRei Assigned Toyorik
Status closedResolutionfixed
Product Version0.17
Summary0003182: Failure to load .3ds file
DescriptionAttempt to open 3ds file (attached) leads to following python traceback in the report view (and no success opening the file)
  File "<string>", line 1, in <module>
  File "/usr/lib64/freecad/Mod/Arch/import3DS.py", line 57, in open
    doc.Label = decode(docname)
  File "/usr/lib64/freecad/Mod/Arch/import3DS.py", line 79, in decode
    decodedName = (utf8_decode(name))
<type 'exceptions.NameError'>: global name 'utf8_decode' is not defined
Steps To ReproduceLoad the attached 3ds file.
Perhaps it's occurring because of my locale (is_IS)?
Additional InformationOS: "Fedora release 24 (Twenty Four)"
Version: 0.17.11828 (Git)
Build type: Unknown
Hash: 71130d09ed57c03c03bbbc0ef49e94a590f6ddd4
Python version: 2.7.13
Qt version: 4.8.7
Coin version: 3.1.3
OCC version: 6.8.0.oce-0.17
Locale: Icelandic/Iceland (is_IS)
Tags#post-to-forum, import, unicode
KarenRei
2017-09-12 20:55
reporter
hús.3ds (10,896 bytes)
2017-09-13 12:14
administrator   ~0010113
@wmayer care to weigh in?
normandc
2017-09-13 14:24
manager   ~0010118
Maybe this specific file is at fault.
When trying to import it in MeshLab, I get the following error:
Error encountered while loading file:
"/home/normand/Bureau/hus.3ds"
Error details: No vertex field found
MeshLab
Do you have another 3DS file to test?
KarenRei
2017-09-13 19:22
reporter   ~0010120
Blender can load the model just fine, meaning that it's possible to make load. One should always strive to make models load if possible, no? :) You can look at import_3ds.py from blender (attaching) if it would help.
Regardless, the fact that your import code is trying to call a function that doesn't exist should be fixed, no? :)
import_3ds.py (38,364 bytes)
# ##### BEGIN GPL LICENSE BLOCK #####
#  This program is free software; you can redistribute it and/or
#  modify it under the terms of the GNU General Public License
#  as published by the Free Software Foundation; either version 2
#  of the License, or (at your option) any later version.
#  This program is distributed in the hope that it will be useful,
#  but WITHOUT ANY WARRANTY; without even the implied warranty of
#  MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
#  GNU General Public License for more details.
#  You should have received a copy of the GNU General Public License
#  along with this program; if not, write to the Free Software Foundation,
#  Inc., 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301, USA.
# ##### END GPL LICENSE BLOCK #####
# <pep8 compliant>
# Script copyright (C) Bob Holcomb
# Contributors: Bob Holcomb, Richard L?rk?ng, Damien McGinnes, Campbell Barton, Mario Lapin, Dominique Lorre, Andreas Atteneder
import os
import time
import struct
import bpy
import mathutils
BOUNDS_3DS = []
# Data Structures
#Some of the chunks that we will see
#----- Primary Chunk, at the beginning of each file
PRIMARY = 0x4D4D
#------ Main Chunks
OBJECTINFO = 0x3D3D  # This gives the version of the mesh and is found right before the material and object information
VERSION = 0x0002  # This gives the version of the .3ds file
EDITKEYFRAME = 0xB000  # This is the header for all of the key frame info
#------ Data Chunks, used for various attributes
PERCENTAGE_SHORT = 0x30
PERCENTAGE_FLOAT = 0x31
#------ sub defines of OBJECTINFO
MATERIAL = 0xAFFF  # This stored the texture info
OBJECT = 0x4000  # This stores the faces, vertices, etc...
#>------ sub defines of MATERIAL
#------ sub defines of MATERIAL_BLOCK
MAT_NAME = 0xA000  # This holds the material name
MAT_AMBIENT = 0xA010  # Ambient color of the object/material
MAT_DIFFUSE = 0xA020  # This holds the color of the object/material
MAT_SPECULAR = 0xA030  # SPecular color of the object/material
MAT_SHINESS = 0xA040  # ??
MAT_TRANSPARENCY = 0xA050  # Transparency value of material
MAT_SELF_ILLUM = 0xA080  # Self Illumination value of material
MAT_WIRE = 0xA085  # Only render's wireframe
MAT_TEXTURE_MAP = 0xA200  # This is a header for a new texture map
MAT_SPECULAR_MAP = 0xA204  # This is a header for a new specular map
MAT_OPACITY_MAP = 0xA210  # This is a header for a new opacity map
MAT_REFLECTION_MAP = 0xA220  # This is a header for a new reflection map
MAT_BUMP_MAP = 0xA230  # This is a header for a new bump map
MAT_MAP_FILEPATH = 0xA300  # This holds the file name of the texture
MAT_MAP_TILING = 0xa351   # 2nd bit (from LSB) is mirror UV flag
MAT_MAP_USCALE = 0xA354   # U axis scaling
MAT_MAP_VSCALE = 0xA356   # V axis scaling
MAT_MAP_UOFFSET = 0xA358  # U axis offset
MAT_MAP_VOFFSET = 0xA35A  # V axis offset
MAT_MAP_ANG = 0xA35C      # UV rotation around the z-axis in rad
MAT_FLOAT_COLOR = 0x0010  # color defined as 3 floats
MAT_24BIT_COLOR = 0x0011  # color defined as 3 bytes
#>------ sub defines of OBJECT
OBJECT_MESH = 0x4100  # This lets us know that we are reading a new object
OBJECT_LAMP = 0x4600  # This lets un know we are reading a light object
OBJECT_LAMP_SPOT = 0x4610  # The light is a spotloght.
OBJECT_LAMP_OFF = 0x4620  # The light off.
OBJECT_LAMP_ATTENUATE = 0x4625
OBJECT_LAMP_RAYSHADE = 0x4627
OBJECT_LAMP_SHADOWED = 0x4630
OBJECT_LAMP_LOCAL_SHADOW = 0x4640
OBJECT_LAMP_LOCAL_SHADOW2 = 0x4641
OBJECT_LAMP_SEE_CONE = 0x4650
OBJECT_LAMP_SPOT_RECTANGULAR = 0x4651
OBJECT_LAMP_SPOT_OVERSHOOT = 0x4652
OBJECT_LAMP_SPOT_PROJECTOR = 0x4653
OBJECT_LAMP_EXCLUDE = 0x4654
OBJECT_LAMP_RANGE = 0x4655
OBJECT_LAMP_ROLL = 0x4656
OBJECT_LAMP_SPOT_ASPECT = 0x4657
OBJECT_LAMP_RAY_BIAS = 0x4658
OBJECT_LAMP_INNER_RANGE = 0x4659
OBJECT_LAMP_OUTER_RANGE = 0x465A
OBJECT_LAMP_MULTIPLIER = 0x465B
OBJECT_LAMP_AMBIENT_LIGHT = 0x4680
OBJECT_CAMERA = 0x4700  # This lets un know we are reading a camera object
#>------ sub defines of CAMERA
OBJECT_CAM_RANGES = 0x4720  # The camera range values
#>------ sub defines of OBJECT_MESH
OBJECT_VERTICES = 0x4110  # The objects vertices
OBJECT_FACES = 0x4120  # The objects faces
OBJECT_MATERIAL = 0x4130  # This is found if the object has a material, either texture map or color
OBJECT_UV = 0x4140  # The UV texture coordinates
OBJECT_TRANS_MATRIX = 0x4160  # The Object Matrix
#>------ sub defines of EDITKEYFRAME
ED_KEY_AMBIENT_NODE = 0xB001
ED_KEY_OBJECT_NODE = 0xB002
ED_KEY_CAMERA_NODE = 0xB003
ED_KEY_TARGET_NODE = 0xB004
ED_KEY_LIGHT_NODE = 0xB005
ED_KEY_L_TARGET_NODE = 0xB006
ED_KEY_SPOTLIGHT_NODE = 0xB007
#>------ sub defines of ED_KEY_OBJECT_NODE
# EK_OB_KEYFRAME_SEG = 0xB008
# EK_OB_KEYFRAME_CURTIME = 0xB009
# EK_OB_KEYFRAME_HEADER = 0xB00A
EK_OB_NODE_HEADER = 0xB010
EK_OB_INSTANCE_NAME = 0xB011
# EK_OB_PRESCALE = 0xB012
EK_OB_PIVOT = 0xB013
# EK_OB_BOUNDBOX =   0xB014
# EK_OB_MORPH_SMOOTH = 0xB015
EK_OB_POSITION_TRACK = 0xB020
EK_OB_ROTATION_TRACK = 0xB021
EK_OB_SCALE_TRACK = 0xB022
# EK_OB_CAMERA_FOV_TRACK = 0xB023
# EK_OB_CAMERA_ROLL_TRACK = 0xB024
# EK_OB_COLOR_TRACK = 0xB025
# EK_OB_MORPH_TRACK = 0xB026
# EK_OB_HOTSPOT_TRACK = 0xB027
# EK_OB_FALLOF_TRACK = 0xB028
# EK_OB_HIDE_TRACK = 0xB029
# EK_OB_NODE_ID = 0xB030
ROOT_OBJECT = 0xFFFF
global scn
scn = None
object_dictionary = {}
object_matrix = {}
#the chunk class
class chunk:
    ID = 0
    length = 0
    bytes_read = 0
    #we don't read in the bytes_read, we compute that
    binary_format = "<HI"
    def __init__(self):
        self.ID = 0
        self.length = 0
        self.bytes_read = 0
    def dump(self):
        print('ID: ', self.ID)
        print('ID in hex: ', hex(self.ID))
        print('length: ', self.length)
        print('bytes_read: ', self.bytes_read)
def read_chunk(file, chunk):
    temp_data = file.read(struct.calcsize(chunk.binary_format))
    data = struct.unpack(chunk.binary_format, temp_data)
    chunk.ID = data[0]
    chunk.length = data[1]
    #update the bytes read function
    chunk.bytes_read = 6
    #if debugging
    #chunk.dump()
def read_string(file):
    #read in the characters till we get a null character
    s = b''
    while True:
        c = struct.unpack('<c', file.read(1))[0]
        if c == b'\x00':
            break
        s += c
        #print 'string: ',s
    #remove the null character from the string
# 	print("read string", s)
    return str(s, "utf-8", "replace"), len(s) + 1
# IMPORT
def process_next_object_chunk(file, previous_chunk):
    new_chunk = chunk()
    while (previous_chunk.bytes_read < previous_chunk.length):
        #read the next chunk
        read_chunk(file, new_chunk)
def skip_to_end(file, skip_chunk):
    buffer_size = skip_chunk.length - skip_chunk.bytes_read
    binary_format = "%ic" % buffer_size
    file.read(struct.calcsize(binary_format))
    skip_chunk.bytes_read += buffer_size
def add_texture_to_material(image, texture, scale, offset, extension, material, mapto):
    #print('assigning %s to %s' % (texture, material))
    if mapto not in {'COLOR', 'SPECULARITY', 'ALPHA', 'NORMAL'}:
        print('/tError:  Cannot map to "%s"\n\tassuming diffuse color. modify material "%s" later.' % (mapto, material.name))
        mapto = "COLOR"
    if image:
        texture.image = image
    mtex = material.texture_slots.add()
    mtex.texture = texture
    mtex.texture_coords = 'UV'
    mtex.use_map_color_diffuse = False
    mtex.scale = (scale[0], scale[1], 1.0)
    mtex.offset = (offset[0], offset[1], 0.0)
    texture.extension = 'REPEAT'
    if extension == 'mirror':
        # 3DS mirror flag can be emulated by these settings (at least so it seems)
        texture.repeat_x = texture.repeat_y = 2
        texture.use_mirror_x = texture.use_mirror_y = True
    elif extension == 'decal':
        # 3DS' decal mode maps best to Blenders CLIP
        texture.extension = 'CLIP'
    if mapto == 'COLOR':
        mtex.use_map_color_diffuse = True
    elif mapto == 'SPECULARITY':
        mtex.use_map_specular = True
    elif mapto == 'ALPHA':
        mtex.use_map_alpha = True
    elif mapto == 'NORMAL':
        mtex.use_map_normal = True
def process_next_chunk(file, previous_chunk, importedObjects, IMAGE_SEARCH):
    from bpy_extras.image_utils import load_image
    #print previous_chunk.bytes_read, 'BYTES READ'
    contextObName = None
    contextLamp = [None, None]  # object, Data
    contextMaterial = None
    contextMatrix_rot = None  # Blender.mathutils.Matrix(); contextMatrix.identity()
    #contextMatrix_tx = None # Blender.mathutils.Matrix(); contextMatrix.identity()
    contextMesh_vertls = None  # flat array: (verts * 3)
    contextMesh_facels = None
    contextMeshMaterials = []  # (matname, [face_idxs])
    contextMeshUV = None  # flat array (verts * 2)
    TEXTURE_DICT = {}
    MATDICT = {}
# 	TEXMODE = Mesh.FaceModes['TEX']
    # Localspace variable names, faster.
    STRUCT_SIZE_FLOAT = struct.calcsize('f')
    STRUCT_SIZE_2FLOAT = struct.calcsize('2f')
    STRUCT_SIZE_3FLOAT = struct.calcsize('3f')
    STRUCT_SIZE_4FLOAT = struct.calcsize('4f')
    STRUCT_SIZE_UNSIGNED_SHORT = struct.calcsize('H')
    STRUCT_SIZE_4UNSIGNED_SHORT = struct.calcsize('4H')
    STRUCT_SIZE_4x3MAT = struct.calcsize('ffffffffffff')
    # STRUCT_SIZE_4x3MAT = calcsize('ffffffffffff')
    # print STRUCT_SIZE_4x3MAT, ' STRUCT_SIZE_4x3MAT'
    # only init once
    object_list = []  # for hierarchy
    object_parent = []  # index of parent in hierarchy, 0xFFFF = no parent
    pivot_list = []  # pivots with hierarchy handling
    def putContextMesh(myContextMesh_vertls, myContextMesh_facels, myContextMeshMaterials):
        bmesh = bpy.data.meshes.new(contextObName)
        if myContextMesh_facels is None:
            myContextMesh_facels = []
        if myContextMesh_vertls:
            bmesh.vertices.add(len(myContextMesh_vertls) // 3)
            bmesh.vertices.foreach_set("co", myContextMesh_vertls)
            nbr_faces = len(myContextMesh_facels)
            bmesh.polygons.add(nbr_faces)
            bmesh.loops.add(nbr_faces * 3)
            eekadoodle_faces = []
            for v1, v2, v3 in myContextMesh_facels:
                eekadoodle_faces.extend((v3, v1, v2) if v3 == 0 else (v1, v2, v3))
            bmesh.polygons.foreach_set("loop_start", range(0, nbr_faces * 3, 3))
            bmesh.polygons.foreach_set("loop_total", (3,) * nbr_faces)
            bmesh.loops.foreach_set("vertex_index", eekadoodle_faces)
            if bmesh.polygons and contextMeshUV:
                bmesh.uv_textures.new()
                uv_faces = bmesh.uv_textures.active.data[:]
            else:
                uv_faces = None
            for mat_idx, (matName, faces) in enumerate(myContextMeshMaterials):
                if matName is None:
                    bmat = None
                else:
                    bmat = MATDICT.get(matName)
                    # in rare cases no materials defined.
                    if bmat:
                        img = TEXTURE_DICT.get(bmat.name)
                    else:
                        print("    warning: material %r not defined!" % matName)
                        bmat = MATDICT[matName] = bpy.data.materials.new(matName)
                        img = None
                bmesh.materials.append(bmat)  # can be None
                if uv_faces  and img:
                    for fidx in faces:
                        bmesh.polygons[fidx].material_index = mat_idx
                        uv_faces[fidx].image = img
                else:
                    for fidx in faces:
            if uv_faces:
                uvl = bmesh.uv_layers.active.data[:]
                for fidx, pl in enumerate(bmesh.polygons):
                    face = myContextMesh_facels[fidx]
                    v1, v2, v3 = face
                    # eekadoodle
                    if v3 == 0:
                        v1, v2, v3 = v3, v1, v2
                    uvl[pl.loop_start].uv = contextMeshUV[v1 * 2: (v1 * 2) + 2]
                    uvl[pl.loop_start + 1].uv = contextMeshUV[v2 * 2: (v2 * 2) + 2]
                    uvl[pl.loop_start + 2].uv = contextMeshUV[v3 * 2: (v3 * 2) + 2]
                    # always a tri
        bmesh.validate()
        bmesh.update()
        ob = bpy.data.objects.new(contextObName, bmesh)
        object_dictionary[contextObName] = ob
        SCN.objects.link(ob)
        importedObjects.append(ob)
        if contextMatrix_rot:
            ob.matrix_local = contextMatrix_rot
            object_matrix[ob] = contextMatrix_rot.copy()
    #a spare chunk
    new_chunk = chunk()
    temp_chunk = chunk()
    CreateBlenderObject = False
    def read_float_color(temp_chunk):
        temp_data = file.read(STRUCT_SIZE_3FLOAT)
        temp_chunk.bytes_read += STRUCT_SIZE_3FLOAT
        return [float(col) for col in struct.unpack('<3f', temp_data)]
    def read_float(temp_chunk):
        temp_data = file.read(STRUCT_SIZE_FLOAT)
        temp_chunk.bytes_read += STRUCT_SIZE_FLOAT
        return struct.unpack('<f', temp_data)[0]
    def read_short(temp_chunk):
        temp_data = file.read(STRUCT_SIZE_UNSIGNED_SHORT)
        temp_chunk.bytes_read += STRUCT_SIZE_UNSIGNED_SHORT
        return struct.unpack('<H', temp_data)[0]
    def read_byte_color(temp_chunk):
        temp_data = file.read(struct.calcsize('3B'))
        temp_chunk.bytes_read += 3
        return [float(col) / 255 for col in struct.unpack('<3B', temp_data)]  # data [0,1,2] == rgb
    def read_texture(new_chunk, temp_chunk, name, mapto):
        new_texture = bpy.data.textures.new(name, type='IMAGE')
        u_scale, v_scale, u_offset, v_offset = 1.0, 1.0, 0.0, 0.0
        mirror = False
        extension = 'wrap'
        while (new_chunk.bytes_read < new_chunk.length):
            #print 'MAT_TEXTURE_MAP..while', new_chunk.bytes_read, new_chunk.length
            read_chunk(file, temp_chunk)
            if temp_chunk.ID == MAT_MAP_FILEPATH:
                texture_name, read_str_len = read_string(file)
                img = TEXTURE_DICT[contextMaterial.name] = load_image(texture_name, dirname)
                temp_chunk.bytes_read += read_str_len  # plus one for the null character that gets removed
            elif temp_chunk.ID == MAT_MAP_USCALE:
                u_scale = read_float(temp_chunk)
            elif temp_chunk.ID == MAT_MAP_VSCALE:
                v_scale = read_float(temp_chunk)
            elif temp_chunk.ID == MAT_MAP_UOFFSET:
                u_offset = read_float(temp_chunk)
            elif temp_chunk.ID == MAT_MAP_VOFFSET:
                v_offset = read_float(temp_chunk)
            elif temp_chunk.ID == MAT_MAP_TILING:
                tiling = read_short(temp_chunk)
                if tiling & 0x2:
                    extension = 'mirror'
                elif tiling & 0x10:
                    extension = 'decal'
            elif temp_chunk.ID == MAT_MAP_ANG:
                print("\nwarning: ignoring UV rotation")
            skip_to_end(file, temp_chunk)
            new_chunk.bytes_read += temp_chunk.bytes_read
        # add the map to the material in the right channel
        if img:
            add_texture_to_material(img, new_texture, (u_scale, v_scale),
                                    (u_offset, v_offset), extension, contextMaterial, mapto)
    dirname = os.path.dirname(file.name)
    #loop through all the data for this chunk (previous chunk) and see what it is
        #print '\t', previous_chunk.bytes_read, 'keep going'
        #print 'reading a chunk'
        #is it a Version chunk?
        if new_chunk.ID == VERSION:
            #print 'if new_chunk.ID == VERSION:'
            #print 'found a VERSION chunk'
            #read in the version of the file
            #it's an unsigned short (H)
            temp_data = file.read(struct.calcsize('I'))
            version = struct.unpack('<I', temp_data)[0]
            new_chunk.bytes_read += 4  # read the 4 bytes for the version number
            #this loader works with version 3 and below, but may not with 4 and above
            if version > 3:
                print('\tNon-Fatal Error:  Version greater than 3, may not load correctly: ', version)
        #is it an object info chunk?
        elif new_chunk.ID == OBJECTINFO:
            #print 'elif new_chunk.ID == OBJECTINFO:'
            # print 'found an OBJECTINFO chunk'
            process_next_chunk(file, new_chunk, importedObjects, IMAGE_SEARCH)
            #keep track of how much we read in the main chunk
        #is it an object chunk?
        elif new_chunk.ID == OBJECT:
            if CreateBlenderObject:
                putContextMesh(contextMesh_vertls, contextMesh_facels, contextMeshMaterials)
                contextMesh_vertls = []
                contextMesh_facels = []
                ## preparando para receber o proximo objeto
                contextMeshMaterials = []  # matname:[face_idxs]
                # Reset matrix
            CreateBlenderObject = True
            contextObName, read_str_len = read_string(file)
            new_chunk.bytes_read += read_str_len
        #is it a material chunk?
        elif new_chunk.ID == MATERIAL:
# 			print("read material")
            #print 'elif new_chunk.ID == MATERIAL:'
            contextMaterial = bpy.data.materials.new('Material')
        elif new_chunk.ID == MAT_NAME:
            #print 'elif new_chunk.ID == MAT_NAME:'
            material_name, read_str_len = read_string(file)
# 			print("material name", material_name)
            #plus one for the null character that ended the string
            contextMaterial.name = material_name.rstrip()  # remove trailing  whitespace
            MATDICT[material_name] = contextMaterial
        elif new_chunk.ID == MAT_AMBIENT:
            #print 'elif new_chunk.ID == MAT_AMBIENT:'
            if temp_chunk.ID == MAT_FLOAT_COLOR:
                contextMaterial.mirror_color = read_float_color(temp_chunk)
# 				temp_data = file.read(struct.calcsize('3f'))
# 				temp_chunk.bytes_read += 12
# 				contextMaterial.mirCol = [float(col) for col in struct.unpack('<3f', temp_data)]
            elif temp_chunk.ID == MAT_24BIT_COLOR:
                contextMaterial.mirror_color = read_byte_color(temp_chunk)
# 				temp_data = file.read(struct.calcsize('3B'))
# 				temp_chunk.bytes_read += 3
# 				contextMaterial.mirCol = [float(col)/255 for col in struct.unpack('<3B', temp_data)] # data [0,1,2] == rgb
            else:
        elif new_chunk.ID == MAT_DIFFUSE:
            #print 'elif new_chunk.ID == MAT_DIFFUSE:'
                contextMaterial.diffuse_color = read_float_color(temp_chunk)
# 				contextMaterial.rgbCol = [float(col) for col in struct.unpack('<3f', temp_data)]
                contextMaterial.diffuse_color = read_byte_color(temp_chunk)
# 				contextMaterial.rgbCol = [float(col)/255 for col in struct.unpack('<3B', temp_data)] # data [0,1,2] == rgb
            else:
# 			print("read material diffuse color", contextMaterial.diffuse_color)
        elif new_chunk.ID == MAT_SPECULAR:
            #print 'elif new_chunk.ID == MAT_SPECULAR:'
                contextMaterial.specular_color = read_float_color(temp_chunk)
                contextMaterial.specular_color = read_byte_color(temp_chunk)
            else:
        elif new_chunk.ID == MAT_TEXTURE_MAP:
            read_texture(new_chunk, temp_chunk, "Diffuse", "COLOR")
        elif new_chunk.ID == MAT_SPECULAR_MAP:
            read_texture(new_chunk, temp_chunk, "Specular", "SPECULARITY")
        elif new_chunk.ID == MAT_OPACITY_MAP:
            read_texture(new_chunk, temp_chunk, "Opacity", "ALPHA")
        elif new_chunk.ID == MAT_BUMP_MAP:
            read_texture(new_chunk, temp_chunk, "Bump", "NORMAL")
        elif new_chunk.ID == MAT_TRANSPARENCY:
            #print 'elif new_chunk.ID == MAT_TRANSPARENCY:'
            if temp_chunk.ID == PERCENTAGE_SHORT:
                contextMaterial.alpha = 1 - (float(struct.unpack('<H', temp_data)[0]) / 100)
            elif temp_chunk.ID == PERCENTAGE_FLOAT:
                contextMaterial.alpha = 1 - float(struct.unpack('f', temp_data)[0])
            else:
                print( "Cannot read material transparency")
        elif new_chunk.ID == OBJECT_LAMP:  # Basic lamp support.
            x, y, z = struct.unpack('<3f', temp_data)
            new_chunk.bytes_read += STRUCT_SIZE_3FLOAT
            # no lamp in dict that would be confusing
            contextLamp[1] = bpy.data.lamps.new("Lamp", 'POINT')
            contextLamp[0] = ob = bpy.data.objects.new("Lamp", contextLamp[1])
            importedObjects.append(contextLamp[0])
            #print 'number of faces: ', num_faces
            #print x,y,z
            contextLamp[0].location = x, y, z
            # Reset matrix
            #print contextLamp.name,
        elif new_chunk.ID == OBJECT_MESH:
            # print 'Found an OBJECT_MESH chunk'
            pass
        elif new_chunk.ID == OBJECT_VERTICES:
            Worldspace vertex locations
            # print 'elif new_chunk.ID == OBJECT_VERTICES:'
            num_verts = struct.unpack('<H', temp_data)[0]
            new_chunk.bytes_read += 2
            # print 'number of verts: ', num_verts
            contextMesh_vertls = struct.unpack('<%df' % (num_verts * 3), file.read(STRUCT_SIZE_3FLOAT * num_verts))
            new_chunk.bytes_read += STRUCT_SIZE_3FLOAT * num_verts
            # dummyvert is not used atm!
            #print 'object verts: bytes read: ', new_chunk.bytes_read
        elif new_chunk.ID == OBJECT_FACES:
            # print 'elif new_chunk.ID == OBJECT_FACES:'
            num_faces = struct.unpack('<H', temp_data)[0]
            # print '\ngetting a face'
            temp_data = file.read(STRUCT_SIZE_4UNSIGNED_SHORT * num_faces)
            new_chunk.bytes_read += STRUCT_SIZE_4UNSIGNED_SHORT * num_faces  # 4 short ints x 2 bytes each
            contextMesh_facels = struct.unpack('<%dH' % (num_faces * 4), temp_data)
            contextMesh_facels = [contextMesh_facels[i - 3:i] for i in range(3, (num_faces * 4) + 3, 4)]
        elif new_chunk.ID == OBJECT_MATERIAL:
            # print 'elif new_chunk.ID == OBJECT_MATERIAL:'
            new_chunk.bytes_read += read_str_len  # remove 1 null character.
            num_faces_using_mat = struct.unpack('<H', temp_data)[0]
            new_chunk.bytes_read += STRUCT_SIZE_UNSIGNED_SHORT
            temp_data = file.read(STRUCT_SIZE_UNSIGNED_SHORT * num_faces_using_mat)
            new_chunk.bytes_read += STRUCT_SIZE_UNSIGNED_SHORT * num_faces_using_mat
            temp_data = struct.unpack("<%dH" % (num_faces_using_mat), temp_data)
            contextMeshMaterials.append((material_name, temp_data))
            #look up the material in all the materials
        elif new_chunk.ID == OBJECT_UV:
            num_uv = struct.unpack('<H', temp_data)[0]
            temp_data = file.read(STRUCT_SIZE_2FLOAT * num_uv)
            new_chunk.bytes_read += STRUCT_SIZE_2FLOAT * num_uv
            contextMeshUV = struct.unpack('<%df' % (num_uv * 2), temp_data)
        elif new_chunk.ID == OBJECT_TRANS_MATRIX:
            # How do we know the matrix size? 54 == 4x4 48 == 4x3
            temp_data = file.read(STRUCT_SIZE_4x3MAT)
            data = list(struct.unpack('<ffffffffffff', temp_data))
            new_chunk.bytes_read += STRUCT_SIZE_4x3MAT
            contextMatrix_rot = mathutils.Matrix((data[:3] + [0],
                                                  data[3:6] + [0],
                                                  data[6:9] + [0],
                                                  data[9:] + [1],
                                                  )).transposed()
        elif  (new_chunk.ID == MAT_MAP_FILEPATH):
            if contextMaterial.name not in TEXTURE_DICT:
                TEXTURE_DICT[contextMaterial.name] = load_image(texture_name, dirname, place_holder=False, recursive=IMAGE_SEARCH)
            new_chunk.bytes_read += read_str_len  # plus one for the null character that gets removed
        elif new_chunk.ID == EDITKEYFRAME:
            pass
        # including these here means their EK_OB_NODE_HEADER are scanned
        elif new_chunk.ID in {ED_KEY_AMBIENT_NODE,
                               ED_KEY_OBJECT_NODE,
                               ED_KEY_CAMERA_NODE,
                               ED_KEY_TARGET_NODE,
                               ED_KEY_LIGHT_NODE,
                               ED_KEY_L_TARGET_NODE,
                               ED_KEY_SPOTLIGHT_NODE}:  # another object is being processed
            child = None
        elif new_chunk.ID == EK_OB_NODE_HEADER:
            object_name, read_str_len = read_string(file)
            temp_data = file.read(STRUCT_SIZE_UNSIGNED_SHORT * 2)
            hierarchy = struct.unpack('<H', temp_data)[0]
            child = object_dictionary.get(object_name)
            if child is None:
                child = bpy.data.objects.new(object_name, None)  # create an empty object
                SCN.objects.link(child)
                importedObjects.append(child)
            object_list.append(child)
            object_parent.append(hierarchy)
            pivot_list.append(mathutils.Vector((0.0, 0.0, 0.0)))
        elif new_chunk.ID == EK_OB_INSTANCE_NAME:
            # child.name = object_name
            child.name += "." + object_name
            object_dictionary[object_name] = child
            # print("new instance object:", object_name)
        elif new_chunk.ID == EK_OB_PIVOT:  # translation
                pivot = struct.unpack('<3f', temp_data)
                pivot_list[len(pivot_list) - 1] = mathutils.Vector(pivot)
        elif new_chunk.ID == EK_OB_POSITION_TRACK:  # translation
            new_chunk.bytes_read += STRUCT_SIZE_UNSIGNED_SHORT * 5
            temp_data = file.read(STRUCT_SIZE_UNSIGNED_SHORT * 5)
            nkeys = struct.unpack('<H', temp_data)[0]
            new_chunk.bytes_read += STRUCT_SIZE_UNSIGNED_SHORT * 2
            for i in range(nkeys):
                nframe = struct.unpack('<H', temp_data)[0]
                loc = struct.unpack('<3f', temp_data)
                if nframe == 0:
                    child.location = loc
        elif new_chunk.ID == EK_OB_ROTATION_TRACK:  # rotation
                temp_data = file.read(STRUCT_SIZE_4FLOAT)
                rad, axis_x, axis_y, axis_z = struct.unpack("<4f", temp_data)
                new_chunk.bytes_read += STRUCT_SIZE_4FLOAT
                if nframe == 0:
                    child.rotation_euler = mathutils.Quaternion((axis_x, axis_y, axis_z), -rad).to_euler()   # why negative?
        elif new_chunk.ID == EK_OB_SCALE_TRACK:  # translation
                sca = struct.unpack('<3f', temp_data)
                if nframe == 0:
                    child.scale = sca
        else:  # (new_chunk.ID!=VERSION or new_chunk.ID!=OBJECTINFO or new_chunk.ID!=OBJECT or new_chunk.ID!=MATERIAL):
            # print 'skipping to end of this chunk'
            #print("unknown chunk: "+hex(new_chunk.ID))
            buffer_size = new_chunk.length - new_chunk.bytes_read
            temp_data = file.read(struct.calcsize(binary_format))
            new_chunk.bytes_read += buffer_size
        #update the previous chunk bytes read
        # print 'previous_chunk.bytes_read += new_chunk.bytes_read'
        # print previous_chunk.bytes_read, new_chunk.bytes_read
        ## print 'Bytes left in this chunk: ', previous_chunk.length - previous_chunk.bytes_read
    # FINISHED LOOP
    # There will be a number of objects still not added
    # Assign parents to objects
    # check _if_ we need to assign first because doing so recalcs the depsgraph
    for ind, ob in enumerate(object_list):
        parent = object_parent[ind]
        if parent == ROOT_OBJECT:
            if ob.parent is not None:
                ob.parent = None
        else:
            if ob.parent != object_list[parent]:
                ob.parent = object_list[parent]
            # pivot_list[ind] += pivot_list[parent]  # XXX, not sure this is correct, should parent space matrix be applied before combining?
    # fix pivots
        if ob.type == 'MESH':
            pivot = pivot_list[ind]
            pivot_matrix = object_matrix.get(ob, mathutils.Matrix())  # unlikely to fail
            pivot_matrix = mathutils.Matrix.Translation(pivot_matrix.to_3x3() * -pivot)
            ob.data.transform(pivot_matrix)
def load_3ds(filepath,
             context,
             IMPORT_CONSTRAIN_BOUNDS=10.0,
             IMAGE_SEARCH=True,
             APPLY_MATRIX=True,
             global_matrix=None):
    global SCN
    # XXX
# 	if BPyMessages.Error_NoFile(filepath):
# 		return
    print("importing 3DS: %r..." % (filepath), end="")
    if bpy.ops.object.select_all.poll():
        bpy.ops.object.select_all(action='DESELECT')
    time1 = time.clock()
# 	time1 = Blender.sys.time()
    current_chunk = chunk()
    file = open(filepath, 'rb')
    #here we go!
    # print 'reading the first chunk'
    read_chunk(file, current_chunk)
    if current_chunk.ID != PRIMARY:
        print('\tFatal Error:  Not a valid 3ds file: %r' % filepath)
        file.close()
        return
    if IMPORT_CONSTRAIN_BOUNDS:
        BOUNDS_3DS[:] = [1 << 30, 1 << 30, 1 << 30, -1 << 30, -1 << 30, -1 << 30]
    else:
        del BOUNDS_3DS[:]
    ##IMAGE_SEARCH
    # fixme, make unglobal, clear in case
    object_dictionary.clear()
    object_matrix.clear()
    scn = context.scene
# 	scn = bpy.data.scenes.active
    SCN = scn
# 	SCN_OBJECTS = scn.objects
# 	SCN_OBJECTS.selected = [] # de select all
    importedObjects = []  # Fill this list with objects
    process_next_chunk(file, current_chunk, importedObjects, IMAGE_SEARCH)
    # Link the objects into this scene.
    # Layers = scn.Layers
    # REMOVE DUMMYVERT, - remove this in the next release when blenders internal are fixed.
    if APPLY_MATRIX:
        for ob in importedObjects:
                me = ob.data
                me.transform(ob.matrix_local.inverted())
    # print(importedObjects)
    if global_matrix:
            if ob.parent is None:
                ob.matrix_world = ob.matrix_world * global_matrix
        ob.select = True
    # Done DUMMYVERT
    if IMPORT_AS_INSTANCE:
        name = filepath.split('\\')[-1].split('/')[-1]
        # Create a group for this import.
        group_scn = Scene.New(name)
            group_scn.link(ob) # dont worry about the layers
        grp = Blender.Group.New(name)
        grp.objects = importedObjects
        grp_ob = Object.New('Empty', name)
        grp_ob.enableDupGroup = True
        grp_ob.DupGroup = grp
        scn.link(grp_ob)
        grp_ob.Layers = Layers
        grp_ob.sel = 1
    else:
        # Select all imported objects.
            scn.link(ob)
            ob.Layers = Layers
            ob.sel = 1
    context.scene.update()
    axis_min = [1000000000] * 3
    axis_max = [-1000000000] * 3
    global_clamp_size = IMPORT_CONSTRAIN_BOUNDS
    if global_clamp_size != 0.0:
        # Get all object bounds
            for v in ob.bound_box:
                for axis, value in enumerate(v):
                    if axis_min[axis] > value:
                        axis_min[axis] = value
                    if axis_max[axis] < value:
                        axis_max[axis] = value
        # Scale objects
        max_axis = max(axis_max[0] - axis_min[0],
                       axis_max[1] - axis_min[1],
                       axis_max[2] - axis_min[2])
        scale = 1.0
        while global_clamp_size < max_axis * scale:
            scale = scale / 10.0
        scale_mat = mathutils.Matrix.Scale(scale, 4)
        for obj in importedObjects:
            if obj.parent is None:
                obj.matrix_world = scale_mat * obj.matrix_world
    # Select all new objects.
    print(" done in %.4f sec." % (time.clock() - time1))
    file.close()
def load(operator,
         context,
         filepath="",
         constrain_size=0.0,
         use_image_search=True,
         use_apply_transform=True,
         global_matrix=None,
    load_3ds(filepath,
             context,
             IMPORT_CONSTRAIN_BOUNDS=constrain_size,
             IMAGE_SEARCH=use_image_search,
             APPLY_MATRIX=use_apply_transform,
             global_matrix=global_matrix,
    return {'FINISHED'}
2017-09-13 19:54
administrator   ~0010121
Trying to load the file with Blender (2.59) and Meshlab (2016.12) works without problems. When trying to load it with FreeCAD I get this error:
Dice3DS not found, 3DS support is disabled.
OS: Windows 7
Version: 0.17.12106 (Git)
Hash: c401f9d75c945117fbd20a45af3a4a403e5f323b
Python version: 2.7.8
Qt version: 4.8.7
OCC version: 7.0.0
2017-09-30 12:07
administrator   ~0010218
From https://github.com/FreeCAD/FreeCAD/blob/master/src/Mod/Arch/import3DS.py#L32-L48
## @package import3DS
#  \ingroup ARCH
#  \brief 3DS file format importer
#  This module provides tools to import 3DS files.
def check3DS():
    "checks if collada if available"
    global dom3ds
    dom3ds = None
    try:
        from Dice3DS import dom3ds
    except ImportError:
        FreeCAD.Console.PrintError("Dice3DS not found, 3DS support is disabled.\n")
        return False
    else:
return True
@yorik do you mind weighing in?
yorik
2017-10-02 17:54
administrator   ~0010238
I don't remember where this utf_decode function came from... In any case, that issue is now fixed in commit 49fdb1ca7 and the attached file loads correctly.
2017-09-12 20:55 KarenRei New Issue
2017-09-12 20:55 KarenRei File Added: hús.3ds
2017-09-13 12:14 Kunda1 Note Added: 0010113
2017-09-13 12:14 Kunda1 Tag Attached: unicode
2017-09-13 14:24 normandc Note Added: 0010118
2017-09-13 19:11 Kunda1 Status new => feedback
2017-09-13 19:22 KarenRei File Added: import_3ds.py
2017-09-13 19:22 KarenRei Note Added: 0010120
2017-09-13 19:22 KarenRei Status feedback => new
2017-09-13 19:54 wmayer Note Added: 0010121
2017-09-30 11:42 Kunda1 Tag Attached: #post-to-forum
2017-09-30 12:07 Kunda1 Note Added: 0010218
2017-09-30 12:08 Kunda1 Tag Attached: import
2017-10-02 17:54 yorik Note Added: 0010238
2017-10-02 17:55 yorik Assigned To => yorik
2017-10-02 17:55 yorik Status new => closed
2017-10-02 17:55 yorik Resolution open => fixed
