| 0003199 | FreeCAD | Feature | public | 2017-09-27 15:59 | 2019-01-16 14:12 |
| Reporter | sherif | Assigned To | wmayer | ||
| Summary | 0003199: It is impossible to get to the ShapeMaterial field without gui | ||||
| Description | Hi Im using FreeCad as a library for a file conversion program Ie calling from FreeCAD import Base load my input file (usually step) and then write my output format. Recently I wanted to access the ShapeMaterial variable, which is located in the ViewObject field. The problem is that the view object is not initialized if there is no gui. This makes sense but in this case The ShapeMaterial is not an attribute of the ViewObject and should not be stored there. Can you please provide a workaround ? or how can I get the material without FreeCADGui.showMainWindow() and ImportGui.insert | ||||
| Steps To Reproduce | | ||||
| Additional Information | OS: Ubuntu 16.04.2 LTS Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.17.10101 (Git) Build type: Unknown Branch: master Hash: 99fa203f323927b0dd027420d4421b577b7420c3 Python version: 2.7.12 Qt version: 4.8.7 Coin version: 4.0.0a OCC version: 6.8.0.oce-0.17 | ||||
| Tags | #lowhangingfruit, headless, python | ||||
Please open a thread on the forum and then link bi-directionally thread <=> ticket |
https://forum.freecadweb.org/viewtopic.php?f=10&t=24657 |
The Import.open() function has been reworked (for several months now) to return a dict of Part feature and list of colors. So you can write:
The output can be e.g.:
| 2017-09-27 15:59 | sherif | New Issue | |
| 2017-09-27 17:03 | Kunda1 | Tag Attached: #post-to-forum | |
| 2017-09-27 17:03 | Kunda1 | Note Added: 0010202 | |
| 2017-09-27 17:04 | Kunda1 | Steps to Reproduce Updated | |
| 2017-09-27 17:04 | Kunda1 | Additional Information Updated | |
| 2017-09-27 17:04 | Kunda1 | Tag Attached: python | |
| 2017-09-27 17:04 | Kunda1 | Tag Attached: headless | |
| 2017-09-28 08:38 | sherif | Note Added: 0010206 | |
| 2017-10-09 14:29 | Kunda1 | Tag Detached: #post-to-forum | |
| 2017-10-19 12:39 | Kunda1 | Tag Attached: #lowhangingfruit | |
| 2017-10-19 17:45 | wmayer | Category | Bug => Feature |
| 2018-02-13 02:47 | Kunda1 | Target Version | => 0.18 |
| 2019-01-16 14:11 | wmayer | Note Added: 0012439 | |
| 2019-01-16 14:12 | wmayer | Assigned To | => wmayer |
| 2019-01-16 14:12 | wmayer | Status | new => closed |
| 2019-01-16 14:12 | wmayer | Resolution | open => fixed |
| 2019-01-16 14:12 | wmayer | Fixed in Version | => 0.18 |
