| 0003223 | GCS | Bug | public | 2017-10-30 14:48 | 2018-06-14 16:11 |
| Reporter | zhukovgreen | Assigned To | abdullah | ||
| Platform | unix | OS | ubuntu | OS Version | 17.04 |
| Summary | 0003223: Sketcher solver fails with some type of constraints | ||||
| Description | I refer to the discussion on this Freecad forum thread With certain type of constraints the solver returns over constrained sketch. While other, type of constraint, works well | ||||
| Steps To Reproduce | Open not_work.fcstd and open sketch. Change angle from 20 to 150 deg (constraint name is angle). If you remove Constraint44 (symetry) and replace it with the solution from rest 3 corners (file work.fcstd), then there is no error. | ||||
| Additional Information | OS: Ubuntu 17.04 Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.17.12495 (Git) Build type: None Branch: master Hash: a16f5bf9aabaeaf82048d773d1ed3ed4e2f5d704 Python version: 2.7.13 Qt version: 4.8.7 Coin version: 4.0.0a OCC version: 7.1.0 Locale: English/UnitedStates (en_US) | ||||
| Tags | constraints, Solver | ||||
Could you please check your ticket with this AppImage? https://forum.freecadweb.org/viewtopic.php?f=10&t=28370&p=229975#p230397 I think the issue is solved there. Please confirm either way. |
Please, read my reply above. |
Yes, I'll check it out. Thanks |
In the meanwhile it has been merged into master, so you can test it with the current master. When I open the "not working", now it reports a redundancy. If I delete this redundancy and change the angle from 20 to 150 degrees it just seems to give the right result. |
I validated it, so we don't have to wait for OP to respond. |
| 2017-10-30 14:48 | zhukovgreen | New Issue | |
| 2017-10-30 14:48 | zhukovgreen | File Added: work.fcstd | |
| 2017-10-30 14:48 | zhukovgreen | File Added: not_work.fcstd | |
| 2017-10-31 20:33 | Kunda1 | Description Updated | |
| 2017-10-31 20:33 | Kunda1 | Tag Attached: constraints | |
| 2017-10-31 20:36 | Kunda1 | Tag Attached: Solver | |
| 2017-10-31 20:37 | Kunda1 | Severity | major => minor |
| 2017-10-31 20:37 | Kunda1 | Project | FreeCAD => Sketcher |
| 2018-04-27 09:48 | abdullah | Note Added: 0011203 | |
| 2018-04-27 09:48 | abdullah | Assigned To | => abdullah |
| 2018-04-27 09:48 | abdullah | Status | new => feedback |
| 2018-04-27 09:48 | abdullah | Note Added: 0011204 | |
| 2018-04-27 10:42 | zhukovgreen | Note Added: 0011209 | |
| 2018-04-27 10:42 | zhukovgreen | Status | feedback => assigned |
| 2018-06-08 22:15 | abdullah | Status | assigned => feedback |
| 2018-06-08 22:15 | abdullah | Note Added: 0011371 | |
| 2018-06-14 16:11 | chrisb | Status | feedback => closed |
| 2018-06-14 16:11 | chrisb | Resolution | open => fixed |
| 2018-06-14 16:11 | chrisb | Note Added: 0011435 |
