| 0003225 | FreeCAD | Bug | public | 2017-11-02 20:22 | 2017-11-08 22:21 |
| Reporter | JoshM | Assigned To | eivindkvedalen | ||
| Summary | 0003225: Inserting Rows prior to a cell containing a calculation referencing cells moved by an INSERT-ROW causes errors. | ||||
| Description | I found a bug that has been verified in the SPREADSHEET workbench, where inserting Rows will generate errors in certain instances. It is described in a thread on the Freecad forums: https://forum.freecad.org/viewtopic.php?f=3&t=25149&e=1&view=unread#unread I believe that it is likely that Column inserts will behave similarly, but I have not tested that. This is my first attempt at reporting a bug--apologies if I messed anything up... Regards, Josh | ||||
| Steps To Reproduce | Detailed at: https://forum.freecad.org/viewtopic.php?f=3&t=25149&e=1&view=unread#unread | ||||
| Tags | spreadsheet | ||||
Please test my branch at https://github.com/eivindkv/FreeCAD/tree/Fix_issue_3225 and see if this resolves your problem. This branch is based on current master. |
https://github.com/FreeCAD/FreeCAD/commit/5fe7a9af712b8255bc28cc2255250c81d32f7340 |
| 2017-11-02 20:22 | JoshM | New Issue | |
| 2017-11-03 03:56 | Kunda1 | Tag Attached: spreadsheet | |
| 2017-11-03 03:57 | Kunda1 | Assigned To | => eivindkvedalen |
| 2017-11-03 03:57 | Kunda1 | Status | new => assigned |
| 2017-11-04 20:38 | eivindkvedalen | Note Added: 0010373 | |
| 2017-11-08 22:21 | wmayer | Status | assigned => closed |
| 2017-11-08 22:21 | wmayer | Resolution | open => fixed |
| 2017-11-08 22:21 | wmayer | Fixed in Version | => 0.17 |
| 2017-11-08 22:21 | wmayer | Note Added: 0010398 |
