| 0003252 | Sketcher | Bug | public | 2017-11-09 07:29 | 2017-12-25 09:50 |
| Reporter | reox | Assigned To | abdullah | ||
| Summary | 0003252: External geometry tool keeps hovered item active after leaving | ||||
| Description | If you select the external geometry tool in the Sketcher and hover over a face, the face will change color. If you press now ESC or leave the external geometry tool in another way, the color will stay. This makes reading sketches very hard. A workaround is to select external geometry tool again and click in empty space or never leave the external geometry tool when hovering a surface. | ||||
| Steps To Reproduce | * Create some body (e.g. additive box) * create a sketch on a surface * choose external geometry * hover over the face * press ESC | ||||
| Additional Information | https://forum.freecadweb.org/viewtopic.php?f=3&t=25269 | ||||
| Tags | external geometry, Sketch, UI | ||||
To keep track of everything. This is a fix that has to be discussed as it affects GUI namespace which is Werner's exclusive zone: https://github.com/abdullahtahiriyo/FreeCAD_sf_master/commit/5583c7712a16cce7b539b4771a53614066b384a2 This is the explanation of the fix and probably the arena where the discussion will unfold: https://forum.freecadweb.org/viewtopic.php?f=10&t=25761 |
https://github.com/FreeCAD/FreeCAD/commit/1ef069292c58331569b6d24fba3c0416146e8c37 https://github.com/FreeCAD/FreeCAD/commit/c18bc414bb1ca4f3f4bb33f2e103ba744a7f0009 |
| 2017-11-09 07:29 | reox | New Issue | |
| 2017-11-09 07:29 | reox | Tag Attached: external geometry | |
| 2017-11-09 07:29 | reox | Tag Attached: Sketch | |
| 2017-11-10 14:33 | Kunda1 | Tag Attached: UI | |
| 2017-12-08 15:40 | abdullah | Assigned To | => abdullah |
| 2017-12-08 15:40 | abdullah | Status | new => assigned |
| 2017-12-08 15:42 | abdullah | Note Added: 0010544 | |
| 2017-12-25 09:50 | wmayer | Status | assigned => closed |
| 2017-12-25 09:50 | wmayer | Resolution | open => fixed |
| 2017-12-25 09:50 | wmayer | Fixed in Version | => 0.17 |
| 2017-12-25 09:50 | wmayer | Note Added: 0010630 |
