0003254FreeCADFeaturepublic2021-02-06 06:50
ReporterKunda1 Assigned To
Status newResolutionopen
Product Version0.17
Target Version0.20
Summary0003254: Wrong paths to fonts occur when you exchange models between different systems. An 'Embed' option would be useful
DescriptionIf a font that is used in FC file is missing on a system that the file wasn't created on, FC throws errors as described in th forum thread
Workaround is copying the font file into a local directory on the other system, set the font in Preferences->Draft->TextAndDimensions and use relative paths.
Additional InformationOriginal Forum thread: https://forum.freecadweb.org/viewtopic.php?p=198905#p198775
Dedicated forum thread: https://forum.freecadweb.org/viewtopic.php?f=8&t=29504&p=241658#p241658
Please discuss in the above 'dedicated' forum thread
Tags#lowhangingfruit, Bountysource Potential, export, font, packaging
yorik
2019-01-18 21:54
administrator   ~0012462
Supposing this is about draft shapestrings...
Indeed the font file is needed to rebuild the correct geometry. Therefore it makes sense to have it embedded. It's a rather simle change (change App::PropertyFile with PropertyFileIncluded) however, if we have many shapestrings, each of them will embed a copy of the font file in the file.. That might be annoying. Not sure what would be a best path here...
normandc
2019-02-09 20:27
manager   ~0012600
Guys, there's a potential license issue here. What if the font that was used has a license that prohibits the user from distributing it?
2019-02-10 15:33
administrator   ~0012604
@normandc IMO, this is the users responsiblity. Take Scribus for example, I don't recall Scribus having this functionality, and it is a FOSS Desktop Publishing program.
normandc
2019-02-10 17:16
manager   ~0012612
Are you saying that Scribus doesn't offer the option to embed fonts in documents? If that's so, well, maybe this is related.
2019-08-30 11:10
administrator   ~0013488
More related discussion on this topic at https://forum.freecadweb.org/viewtopic.php?f=8&t=38643&start=40#p330424
yorik
2022-03-03 13:55
administrator   ~0016581
This ticket has been migrated to GitHub as issue 5746.
2017-11-11 11:56 Kunda1 New Issue
2017-11-11 12:13 Kunda1 Tag Attached: #lowhangingfruit
2017-12-09 11:40 Kunda1 Tag Attached: export
2017-12-09 11:40 Kunda1 Tag Attached: font
2017-12-09 11:40 Kunda1 Tag Attached: packaging
2017-12-09 11:41 Kunda1 Target Version => 0.18
2018-06-28 13:21 Kunda1 Additional Information Updated
2019-01-18 21:54 yorik Note Added: 0012462
2019-02-09 20:27 normandc Note Added: 0012600
2019-02-10 15:33 Kunda1 Note Added: 0012604
2019-02-10 17:16 normandc Note Added: 0012612
2019-02-23 20:42 wmayer Target Version 0.18 => 0.19
2019-08-30 11:10 Kunda1 Note Added: 0013488
2019-08-30 11:11 Kunda1 Tag Attached: Bountysource Potential
2021-02-06 06:50 abdullah Target Version => 0.20
