| 0003255 | Expressions | Feature | public | 2017-11-11 17:54 | 2021-02-06 06:30 |
| Reporter | reox | Assigned To | eivindkvedalen | ||
| Priority | normal | Severity | tweak | Reproducibility | N/A |
| Summary | 0003255: Use consistent angle measure for expressions | ||||
| Description | When inserting values into fields, radians are used for trigonometric functions. But in the expression window (f(x) button), grad are used. IMO Only the latter one is documented in the wiki: https://www.freecadweb.org/wiki/Expressions I think both fields should be unified for the angle measurement. For example both should use grad by default. | ||||
| Steps To Reproduce | See also images in the forum. in normal mode cos(30) gives 0.15 (30 as radians) in expression mode cos(30) gives 0.87 (30 as grad) | ||||
| Additional Information | Discussion https://forum.freecadweb.org/viewtopic.php?f=3&t=25275 | ||||
| Tags | expressions, UI | ||||
| 2017-11-11 17:54 | reox | New Issue | |
| 2017-11-11 17:54 | reox | Tag Attached: expressions | |
| 2017-11-11 17:54 | reox | Tag Attached: UI | |
| 2017-11-11 20:40 | Kunda1 | Assigned To | => eivindkvedalen |
| 2017-11-11 20:40 | Kunda1 | Status | new => assigned |
| 2017-12-13 15:29 | Kunda1 | Project | FreeCAD => Expressions |
