| 0003256 | PartDesign | Bug | public | 2017-11-12 10:35 | 2019-07-29 15:04 |
| Reporter | reox | Assigned To | wmayer | ||
| Summary | 0003256: additive elements do not use color of Body | ||||
| Description | If you set the color of a body, but the last element is an additive element, the color goes back to grey. Sometimes the transparency setting is still the same, but it is harder to reproduce... It looks like the color setting works only if there is only a single additive element or the last element is not an additive element. | ||||
| Steps To Reproduce | * Create a new body * Add for example an additive box * Go to Body -> View and change Shape Color and Transparency * The box is now colored and transparent * Now, create another additive element on one of the faces (e.g. an additive cone; select a face and Interial CS) * The Body is now again grey and not transparent * If you add now another feature (like a fillet), the color and transparency is applied again | ||||
| Additional Information | https://forum.freecadweb.org/viewtopic.php?f=13&t=25095 In the attached file, just change the visibility of each item.
| Tags | colors, Part Design NEXT | ||||
| 2017-11-12 10:35 | reox | New Issue | |
| 2017-11-12 10:35 | reox | File Added: color_test.fcstd | |
| 2017-11-12 10:35 | reox | Tag Attached: colors | |
| 2017-11-12 10:35 | reox | Tag Attached: Part Design NEXT | |
| 2018-06-10 04:06 | Kunda1 | Target Version | => 0.18 |
| 2018-06-10 08:13 | wmayer | Assigned To | => wmayer |
| 2018-06-10 08:13 | wmayer | Status | new => closed |
| 2018-06-10 08:13 | wmayer | Resolution | open => fixed |
| 2018-06-10 08:13 | wmayer | Fixed in Version | => 0.18 |
| 2018-06-10 08:13 | wmayer | Note Added: 0011390 | |
| 2019-07-29 15:04 | Kunda1 | Changeset attached | => FreeCAD master 41b278a0 |
