0003264FreeCADBugpublic2017-11-19 15:36
Reportersurferdudemi Assigned To
Platformx86 64 bitOSWindowsOS Version7
Product Version0.16
Summary0003264: Sketch not valid for Pad
DescriptionI'm walking through the Basic Part Design Tutorial at
https://www.freecadweb.org/wiki/Basic_Part_Design_Tutorial
When I attempt to pad Sketch 2, I get the error
"None of selected sketches/2D objects is valid for padding"
I've followed the steps exactly as far as I can tell. I've tried repeating them three times. I looked up the error message and came across issue 0002169 and tried looking for a circular reference issue by installing and viewing GraphViz. I don't see anything wrong.
Steps To ReproduceWalk through the Basic Part Design Tutorial to the step:
"Next we will click on the Pad feature and in the Pad dialog in the Combo View we want a length of 26 mm leaving the type as Dimension and then placing a check on the Reversed checkbox."
It will fail with the error message cited.
Additional InformationOS: Windows 7
Version: 0.16.6706 (Git)
Branch: releases/FreeCAD-0-16
Hash: f86a4e411ff7848dea98d7242f43b7774bee8fa0
Python version: 2.7.8
Qt version: 4.8.7
OCC version: 6.8.0.oce-0.17
surferdudemi
2017-11-19 06:00
reporter
PartDesign.FCStd (15,043 bytes)
PartDesign.FCStd1 (1,031 bytes)
chrisb
2017-11-19 08:22
developer   ~0010427
It is a user error of using construction lines instead of real lines.
Forum discussion: https://forum.freecadweb.org/viewtopic.php?p=200083#p200083
It can be closed.
2017-11-19 15:35
administrator   ~0010429
@chrisb in the future, feel free to close these when you come across them.
Thanks ;)
@surferdudemi just wondering is it not conspicuous enough to see the banner at the top of this page with instructions on how to submit bugs?
Closing
2017-11-19 06:00 surferdudemi New Issue
2017-11-19 06:00 surferdudemi File Added: PartDesign.FCStd
2017-11-19 06:00 surferdudemi File Added: PartDesign.FCStd1
2017-11-19 06:00 surferdudemi Tag Attached: Part Design
2017-11-19 08:22 chrisb Note Added: 0010427
2017-11-19 15:35 Kunda1 Status new => closed
2017-11-19 15:35 Kunda1 Resolution open => no change required
2017-11-19 15:35 Kunda1 Note Added: 0010429
2017-11-19 15:36 Kunda1 Tag Detached: Part Design
