| 0003284 | Path | Bug | public | 2017-12-16 08:18 | 2019-01-13 11:13 |
| Reporter | Assigned To | sliptonic | |||
| Platform | AMD 64 | OS | Ubuntu | OS Version | 64bit |
| Summary | 0003284: Path Face Edge or Profile Edge Does run wrong direction on Not UseCompensation | ||||
| Description | Hi im new but not that "New" 70+ i discovered on making a NEW dressup Featurer LEAD in OUT to get CRC working G41/42 that on UN Checking USE COMPENSATION the Path runs the Wrong direction OS: Ubuntu 14.04.3 LTS Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.17.12802 (Git) Build type: None Branch: master Hash: 91bb7ed0c51ba47f011199af7bc0a3a2964cf5be Python version: 2.7.6 Qt version: 4.8.6 Coin version: 4.0.0a OCC version: 7.1.0 Locale: German/Germany (de_DE) | ||||
| Steps To Reproduce | Make a Part goto Path ""get a JOB "" select topface or the EDges make a Prifile path UN CHECK the USECompensation -> Exact Part Shape outside CW Simulate it will run counterclockwise NOW it eighter came the Wrong direction from the BASE Contour or it is twisted somwhere inside the generator | ||||
| Additional Information | Video of the Dressup to get https://www.youtube.com/watch?v=EmflIoiweEk&feature=youtu.be I will do this BUG Fix if i get to the point where the main Path is created | ||||
| Tags | Path | ||||
SOLVED needs CHANGE in PathProfileBASE
do i need to make a commit PathProfileBase.py (6,431 bytes)
# -*- coding: utf-8 -*-
# * Copyright (c) 2017 sliptonic <shopinthewoods@gmail.com> *
# * This program is free software; you can redistribute it and/or modify *
# * it under the terms of the GNU Lesser General Public License (LGPL) *
# * as published by the Free Software Foundation; either version 2 of *
# * the License, or (at your option) any later version. *
# * for detail see the LICENCE text file. *
# * This program is distributed in the hope that it will be useful, *
# * but WITHOUT ANY WARRANTY; without even the implied warranty of *
# * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the *
# * GNU Library General Public License for more details. *
# * You should have received a copy of the GNU Library General Public *
# * License along with this program; if not, write to the Free Software *
# * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 *
# * USA *
import FreeCAD
import PathScripts.PathAreaOp as PathAreaOp
import PathScripts.PathLog as PathLog
import PathScripts.PathOp as PathOp
from PySide import QtCore
__title__ = "Base Path Profile Operation"
__author__ = "sliptonic (Brad Collette)"
__url__ = "http://www.freecadweb.org"
__doc__ = "Base class and implementation for Path profile operations."
if False:
PathLog.setLevel(PathLog.Level.DEBUG, PathLog.thisModule())
PathLog.trackModule(PathLog.thisModule())
else:
PathLog.setLevel(PathLog.Level.INFO, PathLog.thisModule())
# Qt tanslation handling
def translate(context, text, disambig=None):
return QtCore.QCoreApplication.translate(context, text, disambig)
class ObjectProfile(PathAreaOp.ObjectOp):
'''Base class for proxy objects of all profile operations.'''
def initAreaOp(self, obj):
'''initAreaOp(obj) ... creates all profile specific properties.
Do not overwrite.'''
# Profile Properties
obj.addProperty("App::PropertyEnumeration", "Side", "Profile", QtCore.QT_TRANSLATE_NOOP("App::Property", "Side of edge that tool should cut"))
obj.Side = ['Outside', 'Inside'] # side of profile that cutter is on in relation to direction of profile
obj.addProperty("App::PropertyEnumeration", "Direction", "Profile", QtCore.QT_TRANSLATE_NOOP("App::Property", "The direction that the toolpath should go around the part ClockWise CW or CounterClockWise CCW"))
obj.Direction = ['CW', 'CCW'] # this is the direction that the profile runs
obj.addProperty("App::PropertyBool", "UseComp", "Profile", QtCore.QT_TRANSLATE_NOOP("App::Property", "make True, if using Cutter Radius Compensation"))
obj.addProperty("App::PropertyDistance", "OffsetExtra", "Profile", QtCore.QT_TRANSLATE_NOOP("App::Property", "Extra value to stay away from final profile- good for roughing toolpath"))
obj.addProperty("App::PropertyEnumeration", "JoinType", "Profile", QtCore.QT_TRANSLATE_NOOP("App::Property", "Controls how tool moves around corners. Default=Round"))
obj.JoinType = ['Round', 'Square', 'Miter'] # this is the direction that the Profile runs
obj.addProperty("App::PropertyFloat", "MiterLimit", "Profile", QtCore.QT_TRANSLATE_NOOP("App::Property", "Maximum distance before a miter join is truncated"))
obj.setEditorMode('MiterLimit', 2)
def areaOpOnChanged(self, obj, prop):
'''areaOpOnChanged(obj, prop) ... updates Side and MiterLimit visibility depending on changed properties.
if prop == "UseComp":
if not obj.UseComp:
obj.setEditorMode('Side', 2)
else:
obj.setEditorMode('Side', 0)
if prop == 'JoinType':
if obj.JoinType == 'Miter':
obj.setEditorMode('MiterLimit', 0)
else:
def areaOpAreaParams(self, obj, isHole):
'''areaOpAreaParams(obj, isHole) ... returns dictionary with area parameters.
params = {}
params['Fill'] = 0
params['Coplanar'] = 0
params['SectionCount'] = -1
offset = 0.0
if obj.UseComp:
offset = self.radius + obj.OffsetExtra.Value
if obj.Side == 'Inside':
offset = 0 - offset
if isHole:
offset = 0 - offset
params['Offset'] = offset
jointype = ['Round', 'Square', 'Miter']
params['JoinType'] = jointype.index(obj.JoinType)
params['MiterLimit'] = obj.MiterLimit
return params
def areaOpPathParams(self, obj, isHole):
'''areaOpPathParams(obj, isHole) ... returns dictionary with path parameters.
params = {}
# Reverse the direction for holes
if isHole:
direction = "CW" if obj.Direction == "CCW" else "CCW"
else:
direction = obj.Direction
if direction == 'CCW':
params['orientation'] = 0
else:
params['orientation'] = 1
if not obj.UseComp:
else:
return params
def areaOpUseProjection(self, obj):
'''areaOpUseProjection(obj) ... returns True'''
return True
def areaOpSetDefaultValues(self, obj):
'''areaOpSetDefaultValues(obj) ... sets default values.
obj.Side = "Outside"
obj.OffsetExtra = 0.0
obj.Direction = "CW"
obj.UseComp = True
obj.JoinType = "Round"
obj.MiterLimit = 0.1
@mlampert care to weigh in ? |
https://github.com/FreeCAD/FreeCAD/commit/c093c59416228828563fd830f54ceff1fe2059c6 |
| 2017-12-16 08:18 |
New Issue | |
| 2017-12-16 08:18 |
Tag Attached: Path | |
| 2017-12-16 08:18 |
Tag Attached: CRC | |
| 2017-12-16 08:18 |
Tag Attached: Edge Profile | |
| 2017-12-18 10:09 |
File Added: PathProfileBase.py | |
| 2017-12-18 10:09 |
Note Added: 0010614 | |
| 2017-12-18 12:12 | Kunda1 | Note Added: 0010615 | |
| 2017-12-23 13:39 | wmayer | Assigned To | => sliptonic |
| 2017-12-23 13:39 | wmayer | Status | new => closed |
| 2017-12-23 13:39 | wmayer | Resolution | open => fixed |
| 2017-12-23 13:39 | wmayer | Fixed in Version | => 0.17 |
| 2017-12-23 13:39 | wmayer | Note Added: 0010624 | |
| 2018-03-03 10:31 | Kunda1 | Tag Detached: CRC | |
| 2019-01-13 11:13 | Kunda1 | Tag Detached: Edge Profile |
