| 0003288 | Sketcher | Bug | public | 2017-12-24 14:57 | 2018-01-01 19:53 |
| Reporter | paullee | Assigned To | wmayer | ||
| Priority | high | Severity | major | Reproducibility | random |
| Platform | Fedora 27 | OS | linux | OS Version | 4.14.7-300.fc27. |
| Summary | 0003288: Sketch Angle Constraints Wrong Reference Reading | ||||
| Description | Forum Thread There are a few angle Constraints in the sketch below as reference. A point move around and the angles update as reference. At some particular cases, see screencapture for the one captured, a reading return 11.76 deg though it is apparently 2 lines bigger than 90 degrees. [It report the complementary angle i.e.,-ve (180 - correct angle) ] The reference provide wrong reading frustrate subsequent calculation / expression. Interestingly, when the file is untouched and re-opened, it reads (I am not sure if re-opening the sketch w/o closing the file do the same thing) -168.xx degree which is the correct reading. OS: Linux Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.17.12852 (Git) Build type: None Branch: master Hash: 8e3b2d7e84924444bc219133a7e0bbd07413cf4f Python version: 2.7.6 Qt version: 4.8.6 Coin version: 4.0.0a OCC version: 7.1.0 Locale: English/UnitedStates (en_US) | ||||
| Steps To Reproduce | As described above. | ||||
| Additional Information | Something related to Your text to link here... ? | ||||
| 2017-12-24 14:57 | paullee | New Issue | |
| 2017-12-24 14:57 | paullee | File Added: Test _ Sketch _ Angle Constraint Puzzle.fcstd | |
| 2017-12-24 16:17 | Kunda1 | Status | new => confirmed |
| 2017-12-24 16:17 | Kunda1 | Description Updated | |
| 2017-12-24 16:17 | Kunda1 | Target Version | => 0.17 |
| 2018-01-01 18:24 | abdullah | Note Added: 0010652 | |
| 2018-01-01 19:53 | wmayer | Assigned To | => wmayer |
| 2018-01-01 19:53 | wmayer | Status | confirmed => closed |
| 2018-01-01 19:53 | wmayer | Resolution | open => fixed |
| 2018-01-01 19:53 | wmayer | Fixed in Version | => 0.17 |
| 2018-01-01 19:53 | wmayer | Note Added: 0010654 |
