| 0003292 | Path | Feature | public | 2017-12-30 14:51 | 2018-01-23 20:10 |
| Reporter | Assigned To | sliptonic | |||
| Priority | low | Severity | trivial | Reproducibility | always |
| OS | Ubuntu | OS Version | 14,04 | ||
| Summary | 0003292: a better postprocess out as clear with linuxcnc postprocessor | ||||
| Description | Hi i added 2 more postprocessor optins -- no-doubles as well improved the INT out on command T D H also got the Modal right gives a bettter cler g-code out | ||||
| Tags | #post-to-forum | ||||
2017-12-30 14:51
linuxcnc_post.py (13,319 bytes)
# * (c) sliptonic (shopinthewoods@gmail.com) 2014 *
# * This file is part of the FreeCAD CAx development system. *
# * This program is free software; you can redistribute it and/or modify *
# * it under the terms of the GNU Lesser General Public License (LGPL) *
# * as published by the Free Software Foundation; either version 2 of *
# * the License, or (at your option) any later version. *
# * for detail see the LICENCE text file. *
# * FreeCAD is distributed in the hope that it will be useful, *
# * but WITHOUT ANY WARRANTY; without even the implied warranty of *
# * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the *
# * GNU Lesser General Public License for more details. *
# * You should have received a copy of the GNU Library General Public *
# * License along with FreeCAD; if not, write to the Free Software *
# * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 *
# * USA *
from __future__ import print_function
TOOLTIP='''
This is a postprocessor file for the Path workbench. It is used to
take a pseudo-gcode fragment outputted by a Path object, and output
real GCode suitable for a linuxcnc 3 axis mill. This postprocessor, once placed
in the appropriate PathScripts folder, can be used directly from inside
FreeCAD, via the GUI importer or via python scripts with:
import linuxcnc_post
linuxcnc_post.export(object,"/path/to/file.ncc","")
import FreeCAD
from FreeCAD import Units
import Path
import argparse
import datetime
import shlex
from PathScripts import PostUtils
from PathScripts import PathUtils
now = datetime.datetime.now()
parser = argparse.ArgumentParser(prog='linuxcnc', add_help=False)
parser.add_argument('--header', action='store_true', help='output headers (default)')
parser.add_argument('--no-header', action='store_true', help='suppress header output')
parser.add_argument('--comments', action='store_true', help='output comment (default)')
parser.add_argument('--no-comments', action='store_true', help='suppress comment output')
parser.add_argument('--line-numbers', action='store_true', help='prefix with line numbers')
parser.add_argument('--no-line-numbers', action='store_true', help='don\'t prefix with line numbers (default)')
parser.add_argument('--show-editor', action='store_true', help='pop up editor before writing output (default)')
parser.add_argument('--no-show-editor', action='store_true', help='don\'t pop up editor before writing output')
parser.add_argument('--precision', default='3', help='number of digits of precision, default=4')
parser.add_argument('--preamble', help='set commands to be issued before the first command, default="G17\nG90"')
parser.add_argument('--postamble', help='set commands to be issued after the last command, default="M05\nG17 G90\nM2"')
parser.add_argument('--inches', action='store_true', help='Convert output for US imperial mode (G20)')
parser.add_argument('--modal', action='store_true', help='Dont output the Same Gcommand Name USE Modal Mode')
parser.add_argument('--no-doubles', action='store_true', help='Dont output the Same Axis Value Mode')
TOOLTIP_ARGS=parser.format_help()
# These globals set common customization preferences
OUTPUT_COMMENTS = True
OUTPUT_HEADER = True
OUTPUT_LINE_NUMBERS = False
SHOW_EDITOR = True
MODAL = False # if true commands are suppressed if the same as previous line.
OUTPUT_DOUBLES = True
COMMAND_SPACE = " "
LINENR = 100 # line number starting value
# These globals will be reflected in the Machine configuration of the project
UNITS = "G21" # G21 for metric, G20 for us standard
UNIT_SPEED_FORMAT = 'mm/min'
UNIT_FORMAT = 'mm'
MACHINE_NAME = "LinuxCNC"
CORNER_MIN = {'x': 0, 'y': 0, 'z': 0}
CORNER_MAX = {'x': 500, 'y': 300, 'z': 300}
PRECISION=3
# Preamble text will appear at the beginning of the GCODE output file.
PREAMBLE = '''G17 G90
# Postamble text will appear following the last operation.
POSTAMBLE = '''M05
G17 G90
M2
# Pre operation text will be inserted before every operation
PRE_OPERATION = ''''''
# Post operation text will be inserted after every operation
POST_OPERATION = ''''''
# Tool Change commands will be inserted before a tool change
TOOL_CHANGE = ''''''
# to distinguish python built-in open function from the one declared below
if open.__module__ == '__builtin__':
pythonopen = open
def processArguments(argstring):
global OUTPUT_HEADER
global OUTPUT_COMMENTS
global OUTPUT_LINE_NUMBERS
global SHOW_EDITOR
global PRECISION
global PREAMBLE
global POSTAMBLE
global UNITS
global UNIT_SPEED_FORMAT
global UNIT_FORMAT
global MODAL
global OUTPUT_DOUBLES
try:
args = parser.parse_args(shlex.split(argstring))
if args.no_header:
OUTPUT_HEADER = False
if args.header:
if args.no_comments:
OUTPUT_COMMENTS = False
if args.comments:
if args.no_line_numbers:
if args.line_numbers:
OUTPUT_LINE_NUMBERS = True
if args.no_show_editor:
SHOW_EDITOR = False
if args.show_editor:
SHOW_EDITOR = True
print("Show editor = %d" % SHOW_EDITOR)
PRECISION = args.precision
if args.preamble is not None:
PREAMBLE = args.preamble
if args.postamble is not None:
POSTAMBLE = args.postamble
if args.inches:
UNITS = 'G20'
UNIT_SPEED_FORMAT = 'in/min'
UNIT_FORMAT = 'in'
PRECISION=4
if args.modal:
MODAL = True
if args.no_doubles:
OUTPUT_DOUBLES = False
except:
return False
return True
def export(objectslist, filename, argstring):
if not processArguments(argstring):
return None
global UNITS
for obj in objectslist:
if not hasattr(obj, "Path"):
print("the object " + obj.Name + " is not a path. Please select only path and Compounds.")
return None
print("postprocessing...")
gcode = ""
# write header
if OUTPUT_HEADER:
gcode += linenumber() + "(Exported by FreeCAD)\n"
gcode += linenumber() + "(Post Processor: " + __name__ + ")\n"
gcode += linenumber() + "(Output Time:" + str(now) + ")\n"
# Write the preamble
if OUTPUT_COMMENTS:
gcode += linenumber() + "(begin preamble)\n"
for line in PREAMBLE.splitlines(False):
gcode += linenumber() + line + "\n"
gcode += linenumber() + UNITS + "\n"
# fetch machine details
job = PathUtils.findParentJob(obj)
myMachine = 'not set'
if hasattr(job,"MachineName"):
myMachine = job.MachineName
if hasattr(job, "MachineUnits"):
if job.MachineUnits == "Metric":
UNITS = "G21"
else:
UNITS = "G20"
# do the pre_op
if OUTPUT_COMMENTS:
gcode += linenumber() + "(begin operation: %s)\n" % obj.Label
gcode += linenumber() + "(machine: %s, %s)\n" % (myMachine, UNIT_SPEED_FORMAT)
for line in PRE_OPERATION.splitlines(True):
gcode += parse(obj)
# do the post_op
if OUTPUT_COMMENTS:
gcode += linenumber() + "(finish operation: %s)\n" % obj.Label
for line in POST_OPERATION.splitlines(True):
# do the post_amble
if OUTPUT_COMMENTS:
gcode += "(begin postamble)\n"
for line in POSTAMBLE.splitlines(True):
if FreeCAD.GuiUp and SHOW_EDITOR:
dia = PostUtils.GCodeEditorDialog()
dia.editor.setText(gcode)
result = dia.exec_()
if result:
final = dia.editor.toPlainText()
else:
final = gcode
else:
final = gcode
print("done postprocessing.")
if not filename == '-':
gfile = pythonopen(filename, "wb")
gfile.write(final)
gfile.close()
return final
def linenumber():
global LINENR
if OUTPUT_LINE_NUMBERS is True:
LINENR += 10
return "N" + str(LINENR) + " "
return ""
def parse(pathobj):
global PRECISION
global MODAL
out = ""
lastcommand = None
precision_string = '.' + str(PRECISION) +'f'
# params = ['X','Y','Z','A','B','I','J','K','F','S'] #This list control
# the order of parameters
# linuxcnc doesn't want K properties on XY plane Arcs need work.
params = ['X', 'Y', 'Z', 'A', 'B', 'C', 'I', 'J', 'F', 'S', 'T', 'Q', 'R', 'L', 'H', 'D']
#keep track for no doubles
currLocation = {}
firstmove = Path.Command("G0", {"X": -1, "Y": -1, "Z": -1, "F": -1})
currLocation.update(firstmove.Parameters)
if hasattr(pathobj, "Group"): # We have a compound or project.
# if OUTPUT_COMMENTS:
# out += linenumber() + "(compound: " + pathobj.Label + ")\n"
for p in pathobj.Group:
out += parse(p)
return out
else: # parsing simple path
# groups might contain non-path things like stock.
if not hasattr(pathobj, "Path"):
return out
# out += linenumber() + "(" + pathobj.Label + ")\n"
for c in pathobj.Path.Commands:
outstring = []
command = c.Name
outstring.append(command)
# if modal: only print the command if it is not the same as the
# last one
if MODAL is True:
if command == lastcommand:
outstring.pop(0)
# Now add the remaining parameters in order
for param in params:
if param in c.Parameters:
if param == 'F' and (currLocation[param] == c.Parameters[param] and OUTPUT_DOUBLES):
if c.Name not in ["G0", "G00"]: #linuxcnc doesn't use rapid speeds
speed = Units.Quantity(c.Parameters['F'], FreeCAD.Units.Velocity)
outstring.append(
param + format(float(speed.getValueAs(UNIT_SPEED_FORMAT)), precision_string) )
elif param == 'T' :
outstring.append(param + str(int(c.Parameters['T'])))
elif param == 'H' :
outstring.append(param + str(int(c.Parameters['H'])))
elif param == 'D' :
outstring.append(param + str(int(c.Parameters['D'])))
elif param == 'S' :
outstring.append(param + str(int(c.Parameters['S'])))
else:
if (not OUTPUT_DOUBLES) and (param in currLocation) and (currLocation[param] == c.Parameters[param]):
continue
else:
pos = Units.Quantity(c.Parameters[param], FreeCAD.Units.Length)
outstring.append(
param + format(float(pos.getValueAs(UNIT_FORMAT)), precision_string) )
#param + format(c.Parameters[param], precision_string))
# store the latest command
lastcommand = command
currLocation.update(c.Parameters)
# Check for Tool Change:
if command == 'M6':
# out += linenumber() + "(begin toolchange)\n"
for line in TOOL_CHANGE.splitlines(True):
out += linenumber() + line
if command == "message":
if OUTPUT_COMMENTS is False:
out = []
else:
outstring.pop(0) # remove the command
# prepend a line number and append a newline
if len(outstring) >= 1:
if OUTPUT_LINE_NUMBERS:
outstring.insert(0, (linenumber()))
# append the line to the final output
for w in outstring:
out += w + COMMAND_SPACE
out = out.strip() + "\n"
return out
print(__name__ + " gcode postprocessor loaded.")
@maxcncmaho please open a forum thread to present this to the Path community. Also please follow the instructions on how to fill out a proper ticket: https://freecadweb.org/wiki/Tracker This one is missing full version info and a forum thread |
@maxcncmaho please let the Path devs know about this ticket by starting a thread on the |
@sliptonic please weigh in at your convenience. thanks! |
Changes incorporated and refined in p:1232: |
| 2017-12-30 14:51 |
New Issue | |
| 2017-12-30 14:51 |
File Added: linuxcnc_post.py | |
| 2017-12-30 17:06 | Kunda1 | Status | new => feedback |
| 2017-12-30 17:06 | Kunda1 | Note Added: 0010635 | |
| 2017-12-30 17:06 | Kunda1 | Tag Attached: #post-to-forum | |
| 2018-01-02 12:49 | Kunda1 | Note Added: 0010661 | |
| 2018-01-02 12:49 | Kunda1 | Note Edited: 0010661 | |
| 2018-01-23 19:04 | Kunda1 | Note Added: 0010832 | |
| 2018-01-23 20:10 | sliptonic | Assigned To | => sliptonic |
| 2018-01-23 20:10 | sliptonic | Status | feedback => closed |
| 2018-01-23 20:10 | sliptonic | Resolution | open => fixed |
| 2018-01-23 20:10 | sliptonic | Fixed in Version | => 0.17 |
| 2018-01-23 20:10 | sliptonic | Note Added: 0010837 |
