| 0003293 | Path | Feature | public | 2017-12-30 15:14 | 2018-01-26 18:50 |
| Reporter | Assigned To | sliptonic | |||
| Summary | 0003293: New Feather Path Dressup for getting a Roll on or foo to a path also for Using Mashine CRC insted off Compensation | ||||
| Description | hi i made a new DRESSUP to get a Toolpath for in and out on Profile operations also the dressup is for PRO CNC as it respects mashine Cutter Radius Compensation USE to get Mashine Tooltable doing the complete offset as G41/G42 its not perfect but it works BESt is to get a better in and out of the path non tool breking | ||||
| Steps To Reproduce | |||||
| Tags | Path | ||||
2017-12-30 15:14
InitGui.py (10,188 bytes)
# * (c) Yorik van Havre (yorik@uncreated.net) 2014 *
# * This file is part of the FreeCAD CAx development system. *
# * This program is free software; you can redistribute it and/or modify *
# * it under the terms of the GNU Lesser General Public License (LGPL) *
# * as published by the Free Software Foundation; either version 2 of *
# * the License, or (at your option) any later version. *
# * for detail see the LICENCE text file. *
# * FreeCAD is distributed in the hope that it will be useful, *
# * but WITHOUT ANY WARRANTY; without even the implied warranty of *
# * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the *
# * GNU Lesser General Public License for more details. *
# * You should have received a copy of the GNU Library General Public *
# * License along with FreeCAD; if not, write to the Free Software *
# * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 *
# * USA *
class PathWorkbench (Workbench):
"Path workbench"
def __init__(self):
self.__class__.Icon = FreeCAD.getResourceDir() + "Mod/Path/Resources/icons/PathWorkbench.svg"
self.__class__.MenuText = "Path"
self.__class__.ToolTip = "Path workbench"
def Initialize(self):
# Add preferences pages - before loading PathGui to properly order pages of Path group
from PathScripts import PathPreferencesPathJob, PathPreferencesPathDressup
FreeCADGui.addPreferencePage(PathPreferencesPathJob.JobPreferencesPage, "Path")
FreeCADGui.addPreferencePage(PathPreferencesPathDressup.DressupPreferencesPage, "Path")
# Check enablement of experimental features
from PathScripts.PathPreferences import PathPreferences
# load the builtin modules
import Path
import PathScripts
import PathGui
from PySide import QtGui
FreeCADGui.addLanguagePath(":/translations")
FreeCADGui.addIconPath(":/icons")
# load python modules
from PathScripts import PathArray
from PathScripts import PathComment
# from PathScripts import PathCompoundExtended
from PathScripts import PathCustom
from PathScripts import PathDressupDogbone
from PathScripts import PathDressupDragknife
from PathScripts import PathDressupRampEntry
from PathScripts import PathDressupTagGui
from PathScripts import PathDressupLeadInOut
from PathScripts import PathDrillingGui
from PathScripts import PathEngraveGui
from PathScripts import PathFixture
from PathScripts import PathHelixGui
from PathScripts import PathHop
from PathScripts import PathInspect
from PathScripts import PathJobCmd
from PathScripts import PathMillFaceGui
from PathScripts import PathPlane
from PathScripts import PathPocketGui
from PathScripts import PathPocketShapeGui
from PathScripts import PathPost
from PathScripts import PathProfileContourGui
from PathScripts import PathProfileEdgesGui
from PathScripts import PathProfileFacesGui
from PathScripts import PathSanity
from PathScripts import PathSimpleCopy
from PathScripts import PathStop
from PathScripts import PathSurfaceGui
from PathScripts import PathToolController
from PathScripts import PathToolLenOffset
from PathScripts import PathToolLibraryManager
from PathScripts import PathSimulatorGui
import PathCommands
# build commands list
projcmdlist = ["Path_Job", "Path_Post"]
toolcmdlist = ["Path_Inspect", "Path_Simulator", "Path_ToolLibraryEdit", "Path_SelectLoop"]
prepcmdlist = ["Path_Plane", "Path_Fixture", "Path_ToolLenOffset", "Path_Comment", "Path_Stop", "Path_Custom", "Path_Shape"]
twodopcmdlist = ["Path_Contour", "Path_Profile_Faces", "Path_Profile_Edges", "Path_Pocket_Shape", "Path_Drilling", "Path_Engrave", "Path_MillFace", "Path_Helix"]
threedopcmdlist = ["Path_Pocket_3D"]
modcmdlist = ["Path_OperationCopy", "Path_Array", "Path_SimpleCopy" ]
dressupcmdlist = ["PathDressup_Dogbone", "PathDressup_DragKnife", "PathDressup_Tag","PathDressup_LeadInOut", "PathDressup_RampEntry"]
extracmdlist = []
#modcmdmore = ["Path_Hop",]
#remotecmdlist = ["Path_Remote"]
# Add commands to menu and toolbar
def QT_TRANSLATE_NOOP(scope, text):
return text
class ThreeDCommandGroup:
def GetCommands(self):
return tuple(threedopcmdlist)
def GetResources(self):
return { 'MenuText': QT_TRANSLATE_NOOP("Path",'3D Operations'),
'ToolTip': QT_TRANSLATE_NOOP("Path",'3D Operations')
def IsActive(self):
if FreeCAD.ActiveDocument is not None:
for o in FreeCAD.ActiveDocument.Objects:
if o.Name[:3] == "Job":
return True
return False
if PathPreferences.experimentalFeaturesEnabled():
projcmdlist.append("Path_Sanity")
threedopcmdlist.append("Path_Surface")
extracmdlist.extend(["Path_Shape", "Path_Area", "Path_Area_Workplane"])
FreeCADGui.addCommand('Path_3dTools', ThreeDCommandGroup())
threedcmdgroup = ['Path_3dTools']
else:
threedcmdgroup = threedopcmdlist
self.appendToolbar(QT_TRANSLATE_NOOP("Path", "Project Setup"), projcmdlist)
self.appendToolbar(QT_TRANSLATE_NOOP("Path", "Tool Commands"), toolcmdlist)
#self.appendToolbar(QT_TRANSLATE_NOOP("Path", "Partial Commands"), prepcmdlist)
self.appendToolbar(QT_TRANSLATE_NOOP("Path", "New Operations"), twodopcmdlist+threedcmdgroup)
self.appendToolbar(QT_TRANSLATE_NOOP("Path", "Path Modification"), modcmdlist)
if extracmdlist:
self.appendToolbar(QT_TRANSLATE_NOOP("Path", "Helpful Tools"), extracmdlist)
self.appendMenu([QT_TRANSLATE_NOOP("Path", "&Path")], projcmdlist +["Path_ExportTemplate", "Separator"] + toolcmdlist +["Separator"] +twodopcmdlist +["Separator"] +threedopcmdlist +["Separator"])
#self.appendMenu([QT_TRANSLATE_NOOP("Path", "Path"), QT_TRANSLATE_NOOP(
# "Path", "Tools")], toolcmdlist)
self.appendMenu([QT_TRANSLATE_NOOP("Path", "&Path"), QT_TRANSLATE_NOOP(
"Path", "Path Dressup")], dressupcmdlist)
"Path", "Partial Commands")], prepcmdlist)
# "Path", "New Operations")], opcmdlist)
"Path", "Path Modification")], modcmdlist)
# "Path", "Path Modification")], modcmdmore)
# self.appendMenu([QT_TRANSLATE_NOOP("Path", "Path"), QT_TRANSLATE_NOOP(
# "Path", "Remote Operations")], remotecmdlist)
if extracmdlist:
self.appendMenu([QT_TRANSLATE_NOOP("Path", "&Path")], extracmdlist)
self.dressupcmds = dressupcmdlist
Path.Area.setDefaultParams(Accuracy = PathPreferences.defaultLibAreaCurveAccuracy())
Log('Loading Path workbench... done\n')
def GetClassName(self):
return "Gui::PythonWorkbench"
def Activated(self):
# update the translation engine
FreeCADGui.updateLocale()
Msg("Path workbench activated\n")
def Deactivated(self):
Msg("Path workbench deactivated\n")
def ContextMenu(self, recipient):
import PathScripts
if len(FreeCADGui.Selection.getSelection()) == 1:
obj = FreeCADGui.Selection.getSelection()[0]
if obj.isDerivedFrom("Path::Feature"):
self.appendContextMenu("", "Separator")
self.appendContextMenu("", ["Path_Inspect"])
selectedName = obj.Name
if "Remote" in selectedName:
self.appendContextMenu("", ["Refresh_Path"])
if "Job" in selectedName:
self.appendContextMenu("", ["Path_ExportTemplate"])
if isinstance (obj.Proxy, PathScripts.PathOp.ObjectOp):
self.appendContextMenu("", ["Path_OperationCopy"])
if "Profile" in selectedName or "Contour" in selectedName or "Dressup" in selectedName:
#self.appendContextMenu("", ["Set_StartPoint"])
#self.appendContextMenu("", ["Set_EndPoint"])
for cmd in self.dressupcmds:
self.appendContextMenu("", [cmd])
Gui.addWorkbench(PathWorkbench())
FreeCAD.addImportType(
"GCode (*.nc *.gc *.ncc *.ngc *.cnc *.tap *.gcode)", "PathGui")
FreeCAD.addExportType(
PathDressupLeadInOut.py (17,085 bytes)
# -*- coding: utf-8 -*-
# * Copyright (c) 2017 LTS <SammelLothar@gmx.de> under LGPL *
# * This program is distributed in the hope that it will be useful, *
# * GNU Library General Public License for more details. *
# * License along with this program; if not, write to the Free Software *
# * USA *
from __future__ import print_function
import FreeCAD
import FreeCADGui
import Path
import Part
from PySide import QtCore, QtGui
import math
#import DraftVecUtils as D
import PathScripts.PathLog as PathLog
import PathScripts.PathUtils as PathUtils
from PathScripts.PathGeom import PathGeom
"""LeadInOut Dressup MASHIN-CRC USE ROLL-ON ROLL-OFF to profile"""
# Qt tanslation handling
def translate(text, context="PathDressup_LeadInOut", disambig=None):
return QtCore.QCoreApplication.translate(context, text, disambig)
PathLog.setLevel(PathLog.Level.INFO, PathLog.thisModule())
movecommands = ['G1', 'G01', 'G2', 'G02', 'G3', 'G03']
rapidcommands = ['G0', 'G00']
arccommands = ['G2', 'G3', 'G02', 'G03']
global currLocation
currLocation = {}
class ObjectDressup:
def __init__(self, obj):
self.obj = obj
obj.addProperty("App::PropertyLink", "ToolController", "Path", QtCore.QT_TRANSLATE_NOOP("App::Property", "The tool controller that will be used to calculate the path"))
obj.addProperty("App::PropertyLink", "Base", "Path", QtCore.QT_TRANSLATE_NOOP("App::Property","The base path to modify"))
obj.addProperty("App::PropertyBool", "LeadIn", "Path", QtCore.QT_TRANSLATE_NOOP("App::Property","Calculate roll-on to path"))
obj.addProperty("App::PropertyBool", "LeadOut", "Path", QtCore.QT_TRANSLATE_NOOP("App::Property","Calculate roll-off from path"))
obj.addProperty("App::PropertyBool", "KeepToolDown", "Path", QtCore.QT_TRANSLATE_NOOP("App::Property","Keep the Tool Down in Path"))
obj.addProperty("App::PropertyBool", "UseMashineCRC", "Path", QtCore.QT_TRANSLATE_NOOP("App::Property","Use Mashine Cutter Radius Compensation /Tool Path Offset G41/G42"))
obj.addProperty("App::PropertyDistance", "Length", "Path", QtCore.QT_TRANSLATE_NOOP("App::Property","Length or Radius of the approach"))
obj.addProperty("App::PropertyEnumeration", "StyleOn", "Path", QtCore.QT_TRANSLATE_NOOP("PathDressup_LeadInOut", "The Style of LeadIn the Path"))
obj.StyleOn = ["Arc", "Tangent", "Perpendicular"]
obj.addProperty("App::PropertyEnumeration", "StyleOff", "Path", QtCore.QT_TRANSLATE_NOOP("PathDressup_LeadInOut", "The Style of LeadOut the Path"))
obj.StyleOff = ["Arc", "Tangent", "Perpendicular"]
obj.addProperty("App::PropertyEnumeration", "RadiusCenter", "Path", QtCore.QT_TRANSLATE_NOOP("PathDressup_LeadInOut", "The Mode of Point Radiusoffset or Center"))
obj.RadiusCenter = ["Radius", "Center"]
obj.Proxy = self
def __getstate__(self):
return None
def __setstate__(self, state):
return None
def setup(self, obj):
obj.Length = 5.0
obj.LeadIn = True
obj.LeadOut = True
obj.KeepToolDown=False
obj.UseMashineCRC=False
obj.StyleOn = 'Arc'
obj.StyleOff = 'Arc'
obj.RadiusCenter = 'Radius'
obj.ToolController = obj.Base.ToolController
def execute(self, obj):
if not obj.Base:
return
if not obj.Base.isDerivedFrom("Path::Feature"):
return
if not obj.Base.Path:
return
if obj.Length < 0:
PathLog.error(translate("Length/Radius positiv not Null\n"))
obj.Length = 0.1
self.wire, self.rapids = PathGeom.wireForPath(obj.Base.Path)
obj.Path = self.generateLeadInOutCurve(obj)
def getDirectionOfPath(self,obj):
if obj.Base.Side == 'Outside':
if obj.Base.Direction =='CW':
return 'left'
else:
return 'right'
else:
return 'right'
return 'left'
def normalize(self, Vector):
x=Vector.x
y=Vector.y
len = math.sqrt( x*x + y*y )
if((math.fabs(len))> 0.0000000000001):
vx = round(x / len,0)
vy = round(y / len,0)
return FreeCAD.Base.Vector(vx,vy,0)
def getLeadStart(self,obj, queue,action):
'''returns Lead In G-code.'''
global currLocation
results = []
zdepth = currLocation["Z"]
horizFeed = obj.ToolController.HorizFeed.Value
vertFeed = obj.ToolController.VertFeed.Value
toolnummer = obj.Base.ToolController.ToolNumber
# set the correct twist command
if self.getDirectionOfPath(obj) == 'left':
arcdir = "G3"
else:
arcdir = "G2"
R= obj.Length.Value #Radius of roll or length
if queue[1].Name == "G1": #line
p0 = queue[0].Placement.Base
p1 = queue[1].Placement.Base
v = self.normalize(p1.sub(p0))
#PathLog.notice(" CURRENT_IN : P0 Z:{} p1 Z:{}".format(p0.z,p1.z))
else:
#PathLog.notice(" CURRENT_IN ARC : P0 X:{} Y:{} P1 X:{} Y:{} ".format(p0.x,p0.y,p1.x,p1.y))
if self.getDirectionOfPath(obj) == 'right':
off_v = FreeCAD.Base.Vector(v.y*R,-v.x*R,0.0)
else:
off_v = FreeCAD.Base.Vector(-v.y*R,v.x*R,0.0)
offsetvector = FreeCAD.Base.Vector(v.x*R,v.y*R, 0) #IJ
if obj.RadiusCenter == 'Radius':
leadstart = (p0.add(off_v)).sub(offsetvector) #Rmode
else:
leadstart = p0.add(off_v) #Dmode
if action == 'start':
extendcommand = Path.Command('G0', {"X": 0.0, "Y": 0.0, "Z": obj.Base.ClearanceHeight.Value})
results.append(extendcommand)
extendcommand = Path.Command('G0', {"X": leadstart.x, "Y": leadstart.y, "Z": obj.Base.ClearanceHeight.Value})
extendcommand = Path.Command('G0', {"X": leadstart.x, "Y": leadstart.y, "Z": obj.Base.SafeHeight.Value})
if action == 'layer':
if not obj.KeepToolDown:
extendcommand = Path.Command('G0', {"Z": obj.Base.SafeHeight.Value})
extendcommand = Path.Command('G0', {"X": leadstart.x, "Y": leadstart.y})
extendcommand = Path.Command('G1', {"X": leadstart.x, "Y": leadstart.y, "Z": p1.z, "F": vertFeed})
if obj.UseMashineCRC:
results.append(Path.Command('G42', {'D':toolnummer}))
else:
results.append(Path.Command('G41', {'D':toolnummer}))
if obj.StyleOn == 'Arc':
arcmove = Path.Command(arcdir, {"X": p0.x, "Y": p0.y, "I": offsetvector.x, "J": offsetvector.y, "F": horizFeed}) # add G2/G3 move
results.append(arcmove)
elif obj.StyleOn == 'Tangent':
extendcommand = Path.Command('G1', {"X": p0.x, "Y": p0.y, "Z": p0.z, "F": horizFeed})
else :
PathLog.notice(" CURRENT_IN Perp")
return results
def getLeadEnd(self,obj, queue,action):
'''returns the Gcode of LeadOut.'''
global currLocation
results = []
arcdir = "G2"
else:
arcdir = "G3"
else:#dealing with a circle
else:
offsetvector = FreeCAD.Base.Vector(v.x*R,v.y*R, 0.0)
leadend = (p1.add(off_v)).add(offsetvector) #Rmode
else:
leadend = p1.add(off_v) #Dmode
IJ= off_v#.negative()
results.append(queue[1])
if obj.StyleOff == 'Arc':
arcmove = Path.Command(arcdir, {"X": leadend.x, "Y": leadend.y, "I": IJ.x, "J": IJ.y, "F": horizFeed}) # add G2/G3 move
elif obj.StyleOff == 'Tangent':
extendcommand = Path.Command('G1', {"X": leadend.x, "Y": leadend.y, "Z": currLocation["Z"], "F": horizFeed})
else :
if obj.UseMashineCRC:#crc off
results.append(Path.Command('G40', {}))
return results
def generateLeadInOutCurve(self, obj):
global currLocation
firstmove = Path.Command("G0", {"X": 0, "Y": 0, "Z": 0})
currLocation.update(firstmove.Parameters)
newpath = []
queue = []
num=0
action= 'start'
for curCommand in obj.Base.Path.Commands:
replace = None
# don't worry about non-move commands, just add to output
if curCommand.Name not in movecommands + rapidcommands:
newpath.append(curCommand)
continue
# rapid retract triggers exit move, else just add to output
if curCommand.Name in rapidcommands:
#detect start position
if (curCommand.x != None) or (curCommand.y != None):
firstmove = curCommand
currLocation.update(curCommand.Parameters)
if action !='start':#done move out
if obj.LeadOut:
temp = self.getLeadEnd(obj,queue,'end')
newpath.extend(temp)
newpath.append(curCommand) #Z clear DONE
if curCommand.Name in movecommands:
queue.append(curCommand)
if action == 'start' and len(queue) <2:
continue
if len(queue) > 2: queue.pop(0)
if obj.LeadIn:
temp=self.getLeadStart(obj,queue,action)
action='none'
else:
if curCommand.z != currLocation["Z"] and action != 'start':# vertical feeding to depth
if obj.LeadOut:#fish cycle
if len(queue) > 2: queue.pop(len(queue)-1)
temp = self.getLeadEnd(obj,queue,action)
action = 'layer'
continue
else:
if obj.LeadIn and len(queue)>=2 and action == 'start':
action='none'
else:
commands = newpath
return Path.Path(commands)
class ViewProviderDressup:
def __init__(self, vobj):
vobj.Proxy = self
def attach(self, vobj):
self.obj = vobj.Object
def claimChildren(self):
if hasattr(self.obj.Base, "InList"):
for i in self.obj.Base.InList:
if hasattr(i, "Group"):
group = i.Group
for g in group:
if g.Name == self.obj.Base.Name:
group.remove(g)
i.Group = group
print(i.Group)
# FreeCADGui.ActiveDocument.getObject(obj.Base.Name).Visibility = False
return [self.obj.Base]
def onDelete(self, arg1=None, arg2=None):
PathLog.debug("Deleting Dressup")
'''this makes sure that the base operation is added back to the project and visible'''
FreeCADGui.ActiveDocument.getObject(arg1.Object.Base.Name).Visibility = True
job = PathUtils.findParentJob(self.obj)
job.Proxy.addOperation(arg1.Object.Base)
arg1.Object.Base = None
return True
return None
return None
class CommandPathDressupLeadInOut:
return {'Pixmap': 'Path-Dressup',
'MenuText': QtCore.QT_TRANSLATE_NOOP("PathDressup_LeadInOut", "LeadInOut Dressup"),
'ToolTip': QtCore.QT_TRANSLATE_NOOP("PathDressup_LeadInOut", "Creates a Cutter Radius Compensation G41/G42 Entry Dressup object from a selected path")}
def IsActive(self):
return True
return False
# check that the selection contains exactly what we want
selection = FreeCADGui.Selection.getSelection()
if len(selection) != 1:
PathLog.error(translate("Please select one path object\n"))
return
baseObject = selection[0]
if not baseObject.isDerivedFrom("Path::Feature"):
PathLog.error(translate("The selected object is not a path\n"))
return
if baseObject.isDerivedFrom("Path::FeatureCompoundPython"):
PathLog.error(translate("Please select a Profile object"))
return
# everything ok!
FreeCAD.ActiveDocument.openTransaction(translate("Create LeadInOut Dressup"))
FreeCADGui.addModule("PathScripts.PathDressupLeadInOut")
FreeCADGui.addModule("PathScripts.PathUtils")
FreeCADGui.doCommand('obj = FreeCAD.ActiveDocument.addObject("Path::FeaturePython", "LeadInOutDressup")')
FreeCADGui.doCommand('dbo = PathScripts.PathDressupLeadInOut.ObjectDressup(obj)')
FreeCADGui.doCommand('obj.Base = FreeCAD.ActiveDocument.' + selection[0].Name)
FreeCADGui.doCommand('PathScripts.PathDressupLeadInOut.ViewProviderDressup(obj.ViewObject)')
FreeCADGui.doCommand('PathScripts.PathUtils.addToJob(obj)')
FreeCADGui.doCommand('Gui.ActiveDocument.getObject(obj.Base.Name).Visibility = False')
FreeCADGui.doCommand('obj.ToolController = PathScripts.PathUtils.findToolController(obj)')
FreeCADGui.doCommand('dbo.setup(obj)')
FreeCAD.ActiveDocument.commitTransaction()
FreeCAD.ActiveDocument.recompute()
if FreeCAD.GuiUp:
# register the FreeCAD command
FreeCADGui.addCommand('PathDressup_LeadInOut', CommandPathDressupLeadInOut())
PathLog.notice("Loading PathDressupLeadInOut... done\n")
@maxcncmaho please open a forum thread to present this to the Path community. Also please follow the instructions on how to fill out a proper ticket: https://freecadweb.org/wiki/Tracker This one is missing full version info and a forum thread |
@sliptonic care to weigh in ? |
@mlampert care to weigh in? |
@sliptonic ping |
This has been implemented and merged. Issue can be closed |
Closing |
| 2017-12-30 15:14 |
New Issue | |
| 2017-12-30 15:14 |
File Added: InitGui.py | |
| 2017-12-30 15:14 |
File Added: PathDressupLeadInOut.py | |
| 2017-12-30 15:14 |
File Added: lead.jpg | |
| 2017-12-30 15:14 |
Tag Attached: Path | |
| 2017-12-30 17:07 | Kunda1 | Status | new => feedback |
| 2017-12-30 17:07 | Kunda1 | Note Added: 0010636 | |
| 2017-12-30 17:07 | Kunda1 | Tag Attached: #post-to-forum | |
| 2017-12-31 00:50 | Kunda1 | Note Added: 0010641 | |
| 2018-01-02 12:47 | Kunda1 | Note Added: 0010660 | |
| 2018-01-26 14:14 | Kunda1 | Note Added: 0010861 | |
| 2018-01-26 18:21 | sliptonic | Note Added: 0010866 | |
| 2018-01-26 18:50 | Kunda1 | Assigned To | => sliptonic |
| 2018-01-26 18:50 | Kunda1 | Status | feedback => closed |
| 2018-01-26 18:50 | Kunda1 | Resolution | open => fixed |
| 2018-01-26 18:50 | Kunda1 | Fixed in Version | => 0.17 |
| 2018-01-26 18:50 | Kunda1 | Note Added: 0010867 | |
| 2018-01-26 18:50 | Kunda1 | Tag Detached: #post-to-forum |
