| 0003294 | TechDraw | Bug | public | 2018-01-01 05:36 | 2018-01-08 07:09 |
| Reporter | terok | Assigned To | |||
| Summary | 0003294: TechDraw: ProjectionGroup scale number editing should be disabled when user selects "Automatic" scale. | ||||
| Description | In ProjectionGroup Custom scale settings there is small inconsistency in operation. When inserting projection, if Scale list is set to “Automatic”, it should disable the Custom Scale number editing. When set to "Custom scale" it should enable user to select the custom scale. See https://forum.freecadweb.org/viewtopic.php?f=35&t=26093#p206444 | ||||
| Steps To Reproduce | STEPS TO REPRODUCE: - File → Open some .stepfile [or FreeCAD doc] → Change to TechDraw Workbench - Press button “Insert new Default Drawing page” on top left → Select Part[or body] on ComboView left - Press “Insert multiple Views of single part” on top toolbar Now there is ProjectionGroup setting on ComboView’s Task tab As seen on attached image, I am editing Custom scale numbers, while the scale is set to "Automatic". However these number do nothing at this mode.... When Scale list is set to “Automatic”, it should Disable the Custom Scale number editing. | ||||
| Additional Information | OS: Windows 10 Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.17.12871 (Git) Build type: Release Branch: master Hash: 070395d67ca45826f1481da80aa9e0f6a9ef4292 Python version: 2.7.8 Qt version: 4.8.7 Coin version: 4.0.0a OCC version: 7.1.0 Locale: English/UnitedStates (en_US) | ||||
| 2018-01-01 05:36 | terok | New Issue | |
| 2018-01-01 05:36 | terok | File Added: Cylinder.FCStd | |
| 2018-01-01 05:36 | terok | File Added: TechDraw_Projectionpage_scale_numbers_not_disabled_in_Automatic_mode.png | |
| 2018-01-01 14:43 | chrisb | Summary | ProjectionGroup scale number editing should be disabled when user selects "Automatic" scale. => TechDraw: ProjectionGroup scale number editing should be disabled when user selects "Automatic" scale. |
| 2018-01-02 12:45 | Kunda1 | Additional Information Updated | |
| 2018-01-08 06:49 | terok | Note Added: 0010727 | |
| 2018-01-08 07:09 | chrisb | Status | new => closed |
| 2018-01-08 07:09 | chrisb | Resolution | open => fixed |
| 2018-01-08 07:09 | chrisb | Fixed in Version | => 0.17 |
