| 0003297 | PartDesign | Feature | public | 2018-01-03 17:43 | 2021-02-06 06:43 |
| Summary | 0003297: Part Design usability improvement for selection of Sweep Path | ||||
| Description | When creating a sweep in PDN the selection and deselection of path elements is time consuming and tedious. Selection: It is only possible to select one path segment at a time. It would be far more compfortable to use the common multi selection using the ctrl key. The Path Workbench has an appropriate selection mechanism plus the comfortable possibility to select all segments of a path in a certain plane. Deselection: Same as above, plus the fact, that if the path segments have to be repaired due to topo naming issues they have to be searched in the model. It would be far easier if the elements in the list could be selected and deleted. Additional comfort would be provided if on selection of a list element the corresponding edge or sweep element could be highlighted. | ||||
| Steps To Reproduce | See corresponding forum discussion | ||||
| Additional Information | OS: Mac OS X Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.17.12915 (Git) Build type: Release Branch: (HEAD detached at 90a71f3) Hash: 90a71f34bc448d1396d2e27f4177885897199152 Python version: 2.7.14 Qt version: 5.6.2 Coin version: 4.0.0a OCC version: 7.1.0 Locale: German/Germany (de_DE) | ||||
| child of | 0003060 | new | More streamlined UI for adding edges and faces (e.g. for PD Fillet tool) |
Another point: it is possible to select edges of the existing solid as path elements. It would be nice to have an option to propagate the selection to edges tangent, like what is done with FIllet and Chamfer features. |
This ticket has been migrated to GitHub as issue 5755. |
| 2018-01-03 17:43 | chrisb | New Issue | |
| 2018-01-03 17:43 | chrisb | Status | new => assigned |
| 2018-01-03 17:43 | chrisb | Assigned To | => abdullah |
| 2018-01-03 17:57 | normandc | Note Added: 0010686 | |
| 2018-01-03 18:15 | chrisb | Additional Information Updated | |
| 2018-01-03 20:35 | Kunda1 | Steps to Reproduce Updated | |
| 2019-02-23 20:56 | wmayer | Target Version | 0.18 => 0.19 |
| 2019-02-24 16:32 | normandc | Relationship added | child of 0003060 |
