| 0003334 | Sketcher | Bug | public | 2018-01-30 15:20 | 2018-10-02 19:03 |
| Priority | low | Severity | tweak | Reproducibility | always |
| Summary | 0003334: Undo bug in Sketcher | ||||
| Description | Undoing a very simple sketch with self constraints shortens the vertical axis so that it has to be enlarged to be visible again | ||||
| Steps To Reproduce | - New Sketch - Auto Constraints on - Draw line from the center (auto-coincidence) horizontal to somewhere on the X-axis - Hit Control Z twice Result: The auto-constraints are gone and the Y-Axis is shortened to almost invisible wthout enlargement | ||||
| Additional Information | https://forum.freecadweb.org/viewtopic.php?f=10&t=26634#p212277 There is a sample file attached as well. | ||||
| Tags | sketcher, undo | ||||
| 2018-01-30 15:20 | chrisb | New Issue | |
| 2018-01-30 15:20 | chrisb | Status | new => assigned |
| 2018-01-30 15:20 | chrisb | Assigned To | => abdullah |
| 2018-02-05 16:35 | Kunda1 | Tag Attached: undo | |
| 2018-02-05 16:36 | Kunda1 | Tag Attached: sketcher | |
| 2018-10-01 14:36 | abdullah | Note Added: 0011882 | |
| 2018-10-02 19:03 | wmayer | Status | assigned => closed |
| 2018-10-02 19:03 | wmayer | Resolution | open => fixed |
| 2018-10-02 19:03 | wmayer | Fixed in Version | => 0.18 |
| 2018-10-02 19:03 | wmayer | Note Added: 0011887 |
