| 0003339 | Draft | Bug | public | 2018-02-07 07:20 | 2018-11-09 00:26 |
| Reporter | stunts1990 | Assigned To | |||
| Platform | x86-64 | OS | Windows 10 Home | OS Version | 1709 |
| Summary | 0003339: Point Sizes different after undoing deletion | ||||
| Description | When a point is deleted and the undo button is pressed, the point should be back in its original size. However when the undo button is pressed, the point ends up being smaller than what it was before the Deletion. This means that the undo button does not fully undo the last action and only partially completes what it was required to do as a smaller point back on the canvas indicates a partial restoration of the point that is some portion of the point went missing in the undo step. | ||||
| Steps To Reproduce | Start Up FreeCAD. Press Ctrl+N to create a new drawing. Left Click on Start and then left click on Draft to change the workbench to Draft. Press 2 to change view to Top View. Left Click on Create point object in the draft creation tools toolbox. Left click on the canvas to place the point object on the canvas. Press the delete key to delete the point object. Press Ctrl+Z to undo the deletion You may note that the point object did not restore back to its original size and is smaller than what it was prior to its deletion. | ||||
| Additional Information | You can see the difference in the point sizes in the image. | ||||
| Tags | Draft, undo | ||||
@stunts1990 thanks for the ticket. please open a forum thread to announce to community. BTW, please always add you Help > About FreeCAD > Copy to clipboard info when opening a ticket. |
I cannot reproduce on OS: Ubuntu 14.04.5 LTS Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.17.13247 (Git) Build type: Release/Daily-PPA Branch: master Hash: 5022c8df5cef0690f2c8acff4bcebd82655a5f04 Python version: 2.7.6 Qt version: 4.8.6 Coin version: 4.0.0a OCC version: 7.1.0 Locale: English/UnitedStates (en_US) |
@stunts1990 please try to reproduce the issue using the bleeding edge 0.18dev version and report back ( https://github.com/FreeCAD/FreeCAD/releases/tag/0.18_pre ) |
@stunts1990 please respond |
@stunts1990 ping |
Forum thread: https://forum.freecadweb.org/viewtopic.php?f=8&t=30209 |
@stunts1990 please follow the forum thread |
The reported issue for true for 0.16 or older but not with 0.17 or later. So, since the bug reporter shows no reaction I vote for closing the ticket. |
@stunts1990 please respond or we will close this ticket |
Resolving this ticket for now. |
Closing ticket per wmayer's suggestion |
| 2018-02-07 07:20 | stunts1990 | New Issue | |
| 2018-02-07 07:20 | stunts1990 | File Added: bug1.PNG | |
| 2018-02-07 07:20 | stunts1990 | Tag Attached: Draft | |
| 2018-02-07 16:05 | Kunda1 | Tag Attached: undo | |
| 2018-02-07 16:22 | Kunda1 | Note Added: 0010929 | |
| 2018-02-07 16:22 | Kunda1 | Note Edited: 0010929 | |
| 2018-02-07 16:23 | Kunda1 | Product Version | 0.18 => 0.17 |
| 2018-02-08 00:25 |
Note Added: 0010930 | |
| 2018-05-31 17:38 | Kunda1 | Status | new => feedback |
| 2018-05-31 17:38 | Kunda1 | Note Added: 0011338 | |
| 2018-06-07 16:51 | Kunda1 | Note Added: 0011359 | |
| 2018-08-01 02:59 | Kunda1 | Note Added: 0011573 | |
| 2018-08-08 20:14 | Kunda1 | Note Added: 0011609 | |
| 2018-08-08 20:41 | Kunda1 | Note Added: 0011611 | |
| 2018-10-04 07:43 | wmayer | Note Added: 0011911 | |
| 2018-10-17 20:38 | Kunda1 | Note Added: 0012056 | |
| 2018-10-17 20:39 | Kunda1 | Status | feedback => resolved |
| 2018-10-17 20:39 | Kunda1 | Resolution | open => fixed |
| 2018-10-17 20:39 | Kunda1 | Note Added: 0012057 | |
| 2018-11-09 00:26 | Kunda1 | Status | resolved => closed |
| 2018-11-09 00:26 | Kunda1 | Note Added: 0012157 |
