0003340DraftBugpublic2021-04-12 06:14
Reporterwmayer Assigned Toyorik
PriorityhighSeverityblockReproducibilityalways
Status assignedResolutionopen
Product Version0.17
Target Version0.20
Summary0003340: Massive memory leak in Draft
DescriptionWhen using e.g. the dimension tool and hovering over a shape causes a huge memory leak. A user reported that the total memory consumption went up to 11 GB (!!!)
Additional Informationhttps://forum.freecad.org/viewtopic.php?f=10&t=26784
Relationships
related to 0003993 closedwmayer FreeCAD Memory leak with Python3
yorik
2018-03-08 15:15
administrator   ~0011023
This is now reduced as much as we can on the FreeCAD side I think. There is still some memory leak somewhere in pivy, though. But this has ow been minimized as much as possible.
I suggest we either close this now, as there is AFAICS not much more we can do in the FreeCAD code itself, or leave it open, removing the 0.17 target, in case someone wants to dig into the pivy code later, as after all, it has become more or less our baby (or Looo's :) ) now...
In any case I'll remove the 0.17 tag
2018-03-08 15:50
administrator   ~0011025
Out of curiosity what makes you believe that there is a leak in pivy?
yorik
2018-03-08 17:32
administrator   ~0011026
Try this https://forum.freecad.org/viewtopic.php?f=10&t=26784&start=20#p216270
2018-03-08 20:19
administrator   ~0011027
See this: https://forum.freecad.org/viewtopic.php?f=10&t=26784&start=30#p219240
yorik
2019-02-16 22:27
administrator   ~0012668
This one fell far below my radar... In any case the problem is not big anymore, more several optimizations to do, so better to reschedule for 0.19...
carlopav
2020-06-14 21:17
developer   ~0014547
@yorik, what's the status of this? is that something that could be done now?
yorik
2020-06-15 08:13
administrator   ~0014548
It needs testing again, basically. I have not observed this anymore, but it needs to be metered precisely to make sure.
carlopav
2020-06-15 17:17
developer   ~0014554
I think i've observed a huge augmenting of memory used when changing from 2d to 3d and back into 2d several times on the dimension object... Do you experience the same?
2020-10-10 12:53
administrator   ~0014816
Is this the memory leak solved in FreeCAD master ab4ab444 ?
thread: https://forum.freecad.org/viewtopic.php?f=15&t=50583
2020-10-10 12:58
administrator   ~0014817
Tracking in https://forum.freecad.org/viewtopic.php?f=8&t=51016
2021-04-12 06:14
administrator   ~0015610
When building FreeCAD with -fsanitize=address then this build reports that an SoSeparator isn't deleted. The node contains an SoCoordinate3 and an SoLineSet.
The amount of memory is only a few KB.
yorik
2022-03-03 13:55
administrator   ~0016596
This ticket has been migrated to GitHub as issue 5761.
Related Changesets
FreeCAD: master ab4ab444
2020-10-04 17:43:54
Details Diff
Path: [skip ci] fix memory leak in CommandPy::getParameters()
For some background information see: https://forum.freecad.org/viewtopic.php?f=15&t=50583
Affected Issues
0003340
mod - src/Mod/Path/App/CommandPyImp.cpp Diff File
2018-02-07 12:44 wmayer New Issue
2018-02-09 11:01 yorik Assigned To => yorik
2018-02-09 11:01 yorik Status new => assigned
2018-03-03 11:23 Kunda1 Target Version => 0.17
2018-03-08 15:15 yorik Note Added: 0011023
2018-03-08 15:15 yorik Target Version 0.17 =>
2018-03-08 15:50 wmayer Note Added: 0011025
2018-03-08 17:32 yorik Note Added: 0011026
2018-03-08 20:19 wmayer Note Added: 0011027
2018-05-31 00:19 Kunda1 Target Version => 0.18
2019-02-16 22:27 yorik Note Added: 0012668
2019-02-16 22:27 yorik Target Version 0.18 => 0.19
2019-06-20 01:49 Kunda1 Severity major => block
2019-06-20 13:16 Kunda1 Relationship added related to 0003993
2020-06-14 21:17 carlopav Note Added: 0014547
2020-06-15 08:13 yorik Note Added: 0014548
2020-06-15 17:17 carlopav Note Added: 0014554
2020-10-10 12:53 Kunda1 Note Added: 0014816
2020-10-10 12:53 Kunda1 Note Edited: 0014816
2020-10-10 12:58 Kunda1 Note Added: 0014817
2020-11-21 16:36 Kunda1 Changeset attached => FreeCAD master ab4ab444
2021-02-06 06:45 abdullah Target Version => 0.20
2021-04-12 06:14 wmayer Note Added: 0015610
