0003342FreeCADBugpublic2018-02-24 13:45
Reporterpaomod Assigned Tochrisb
PriorityhighSeveritymajorReproducibilityN/A
Platformlinux
Product Version0.16
Summary0003342: wrong cut of two intersecting revolution shapes
DescriptionI generate two revolution shapes, ,they are intersecting. I do the cut operation but the result is not correct: the intersection of the two remains in the "cut" shape.
paomod
2018-02-08 16:54
reporter
freeCADrep.fcstd (51,647 bytes)
2018-02-13 03:07
administrator   ~0010958
@paomod please read the tracker guidelines (enormous yellow box at the top of the page) . In it you will find the need for you to always mention your full FC version info (Help > About FreeCAD > Copy to clipboard) you will also find that we ask users to consult the community before opening a ticket. Please go to the Open Discussion sub-forum and open a ticket which references this ticket and vice-a-versa. Thank you.
paomod
2018-02-24 12:04
reporter   ~0010974
Hello,
         here below the missing info.
OS: Ubuntu 14.04.5 LTS
Version: 0.16.6712 (Git)
Build type: None
Branch: releases/FreeCAD-0-16
Hash: da2d364457257a7a8c6fb2137cea12c45becd71a
Python version: 2.7.6
Qt version: 4.8.6
OCC version: 6.8.0.oce-0.17
paomod
2018-02-24 12:17
reporter   ~0010975
I opened this in the forum:
https://forum.freecadweb.org/viewtopic.php?f=8&t=27093
chrisb
2018-02-24 13:45
developer   ~0010977
Issue was due to errors in a sketch, see forum discussion.
2018-02-08 16:54 paomod New Issue
2018-02-08 16:54 paomod File Added: freeCADrep.fcstd
2018-02-13 03:04 Kunda1 Summary wrong cut of two intersecting revolustion shapes => wrong cut of two intersecting revolution shapes
2018-02-13 03:07 Kunda1 Status new => feedback
2018-02-13 03:07 Kunda1 Note Added: 0010958
2018-02-24 12:04 paomod Note Added: 0010974
2018-02-24 12:04 paomod Status feedback => new
2018-02-24 12:17 paomod Note Added: 0010975
2018-02-24 13:45 chrisb Assigned To => chrisb
2018-02-24 13:45 chrisb Status new => closed
2018-02-24 13:45 chrisb Resolution open => no change required
2018-02-24 13:45 chrisb Note Added: 0010977
