| 0003347 | Draft | Bug | public | 2018-02-12 11:15 | 2018-02-12 21:19 |
| Reporter | xanderdin | Assigned To | wmayer | ||
| Summary | 0003347: No 'Tick' arrow style among other styles in Draft preferences | ||||
| Description | Menu Edit -> Preferences -> Draft -> Texts and dimensions -> Arrow style There is no 'Tick' option in that drop-down list. | ||||
| Additional Information | OS: Debian GNU/Linux 9.3 (stretch) Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.17.13274 (Git) Build type: Release Branch: master Hash: 58887d8b841f18f3da4e5e3f8052f75edba5b9cc Python version: 2.7.13 Qt version: 4.8.7 Coin version: 4.0.0a OCC version: 6.8.0.oce-0.17 Locale: Russian/Ukraine (ru_UA) | ||||
@xanderdin Are you saying is it missing (I don't see it in 0.16) or that you're requesting it as a feature? |
Hm, good question. I'd say it is missing. Look, when you draw a dimension line, you can set its type as one of the following from 'Arrow Type' drop-down list in the property editor: Dot, Circle, Arrow, Tick. So I thought that in the Preferences should be the same set of arrows styles. Not sure about either was it so in previous versions. Having this in mind I'm not really certain now, is it a bug or a feature request. Sorry. Probably you're better to decide. Thanks. |
Here is the preference menu that you have a screenshot of: preferences-drafttexts.ui Here is the dropdown you're speaking of: Draft.py I can see in the code (DlgPrefsTechDraw2.ui) that in Techdraw there is the option to use ticks. |
yorik, care to weigh in? |
https://github.com/FreeCAD/FreeCAD/commit/903aae07b9a9bbb3277bf28d3a3baca1cba2b50f |
| 2018-02-12 11:15 | xanderdin | New Issue | |
| 2018-02-12 11:15 | xanderdin | File Added: NoTick-1.png | |
| 2018-02-12 17:45 | Kunda1 | Note Added: 0010944 | |
| 2018-02-12 19:49 | xanderdin | Note Added: 0010948 | |
| 2018-02-12 20:20 | Kunda1 | Note Added: 0010949 | |
| 2018-02-12 20:21 | Kunda1 | Assigned To | => yorik |
| 2018-02-12 20:21 | Kunda1 | Status | new => assigned |
| 2018-02-12 20:22 | Kunda1 | Note Added: 0010950 | |
| 2018-02-12 20:54 | wmayer | Status | assigned => closed |
| 2018-02-12 20:54 | wmayer | Resolution | open => fixed |
| 2018-02-12 20:54 | wmayer | Fixed in Version | => 0.17 |
| 2018-02-12 20:54 | wmayer | Note Added: 0010952 | |
| 2018-02-12 21:19 | Kunda1 | Assigned To | yorik => wmayer |
| 2018-02-12 21:19 | Kunda1 | Target Version | => 0.17 |
