| 0003349 | FreeCAD | Bug | public | 2018-02-14 11:21 | 2018-09-25 12:31 |
| Reporter | Tooniis | Assigned To | |||
| Platform | Linux | OS | Ubuntu | OS Version | 17.10 |
| Summary | 0003349: Anti-Aliasing does not work at all | ||||
| Description | Anti-Aliasing does not work at all in both 3D view and sketch view, even after restarting FreeCAD | ||||
| Steps To Reproduce | 1-Launch FreeCAD. 2-Edit Menu > Preferences > Display. 3-Change Anti-Aliasing to any setting other than "None". 4-Press "OK". 5-Restart FreeCAD. 6-There is still no anti-aliasing in both the 3D view and sketch view. | ||||
| Additional Information | CPU: Intel Core i5 6200U Skylake Integrated GPU: Intel HD Graphics 520 Dedicated GPU: AMD Radeon R5 M330 (HAINAN) I tried with both GPUs. | ||||
| Tags | anti-aliasing, display, linux | ||||
@Tooniis Can you still reproduce on 0.17 or 0.18dev ? (Please post your Help > About FreeCAD > Copy to clipboard) |
@Tooniis ping |
@Tooniis ping |
Forum thread: https://forum.freecadweb.org/viewtopic.php?f=8&t=30208 |
The anti-aliasing setting definitely works. If on a system you can't see the effect then it could be because: * the hardware/driver doesn't support it * things are not configured correctly It's also possible that when using Qt4 things don't work correctly any more and moving to Qt5 fixes them. This has been observed in quite a lot of cases now. In either way it's nothing we can change in FreeCAD code to make this working as expected. |
| 2018-02-14 11:21 | Tooniis | New Issue | |
| 2018-02-14 11:21 | Tooniis | Tag Attached: linux | |
| 2018-02-14 11:21 | Tooniis | Tag Attached: anti-aliasing | |
| 2018-02-14 11:21 | Tooniis | Tag Attached: display | |
| 2018-02-14 14:09 | Kunda1 | Status | new => feedback |
| 2018-06-11 00:47 | Kunda1 | Note Added: 0011401 | |
| 2018-06-25 12:51 | Kunda1 | Note Added: 0011465 | |
| 2018-08-01 03:00 | Kunda1 | Note Added: 0011574 | |
| 2018-08-08 20:13 | Kunda1 | Note Added: 0011608 | |
| 2018-09-25 12:31 | wmayer | Status | feedback => closed |
| 2018-09-25 12:31 | wmayer | Resolution | open => unable to reproduce |
| 2018-09-25 12:31 | wmayer | Note Added: 0011836 |
