0003353FreeCADFeaturepublic2021-02-06 06:49
Reporteryorik Assigned Toyorik
PrioritynormalSeverityminorReproducibilityN/A
Status assignedResolutionopen
PlatformPCOSDebianOS VersionTesting 64bit
Target Version0.20
Summary0003353: Direct modeling tools
DescriptionFreeCADs is a feature-based parametric modeling system, hence different modeling steps depend on one or multiple previous steps. Each step is at the same time a tool/operation, and a geometrical object, resulting from that operation. This mix of operation and object is called a feature. Direct modeling, often presented as the opposite of parametric modeling, allows to graphically move vertices, push or pull faces and edges to modify the geometry of an object.
This issue is a GSOC idea https://www.freecad.org/wiki/Direct_modeling_tools
and also as a test for bountysource...
Relationships
related to 0001367 assignedyorik Draft Extend Draft Edit mode to work with 3D shapes
2021-01-31 11:21
administrator   ~0015233
Several attempts have already begun to tackle this issue:
yorik
2022-03-03 13:55
administrator   ~0016599
This ticket has been migrated to GitHub as issue 5764.
2018-02-22 17:58 yorik New Issue
2018-02-22 17:58 yorik Status new => assigned
2018-02-22 17:58 yorik Assigned To => yorik
2020-11-18 15:09 yorik Relationship added related to 0001367
2021-01-31 11:21 Kunda1 Note Added: 0015233
2021-01-31 11:21 Kunda1 Note Edited: 0015233
