| 0003366 | GCS | General | public | 2018-03-10 00:31 | 2018-06-03 07:58 |
| Reporter | Manuel | Assigned To | abdullah | ||
| Platform | Arch Linux | ||||
| Summary | 0003366: Constraint angle between Line and Arc (via tangent helper line) doesn't play well with symmetry constraint | ||||
| Description | Using the constraints symmetry and angle between Line and Arc (via tangent helper line) can cause FreeCAD to detect conflicting constraints upon value change even though the values are valid. | ||||
| Steps To Reproduce | * Download attached FreeCAD file * Open the contained sketch * Change the angle constraint (Constraint number 12) by at least 1° (for example to 111°) * FreeCAD will report conflicting constraints even though the new value should result in a valid sketch | ||||
| Additional Information | Forum thread: https://forum.freecadweb.org/viewtopic.php?f=8&t=27271 Additional note: The order in which the constraints are created seems to matter. Deleting constraint 2 in the attached file (the symmetry constraint at the endpoints of the arc) and recreating it makes the bug disappear. Installation details: OS: "Arch Linux" Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.17.13362 (Git) AppImage Build type: None Branch: master Hash: 8c6b4ad1a60e2af6c1512cd01b6f47620612a5bd Python version: 2.7.6 Qt version: 4.8.6 Coin version: 4.0.0a OCC version: 7.1.0 Locale: German/Germany (de_DE) | ||||
| Tags | Solver | ||||
Forgot to upload the fcstd file. Here it is. |
Moved to 'GCS' and assigned to abdullah |
The culprit is the edge-to-edge tangency + coincident instead of endpoint-to-endpoint tangency. It is no longer possible to create such construction (edge-to-edge tangency + coincident) in current FC, as it automatically changes that construction to endpoint-to-endpoint tangency. With current FC open the sketch and do: 1. Delete constraints 9 and 10 (coincident and tangency) 2. Add a coincident back 3. Add an edge to edge tangency 4. FreeCAD detects this situation and substitutes the constraints created in step 3 with an endpoint-to-endpoint tangency constraint (you will appreciate the coincident has disappeared). |
To be closed as soon as Abdullah's improvements are in master: https://forum.freecadweb.org/viewtopic.php?f=10&t=28370 |
https://github.com/FreeCAD/FreeCAD/pull/1429 |
| 2018-03-10 00:31 | Manuel | New Issue | |
| 2018-03-10 00:31 | Manuel | Tag Attached: Solver | |
| 2018-03-10 00:33 | Manuel | File Added: bugreport_angle_arc_line_minimal.fcstd | |
| 2018-03-10 00:33 | Manuel | Note Added: 0011030 | |
| 2018-03-10 01:34 | Kunda1 | Project | FreeCAD => GCS |
| 2018-03-10 01:34 | Kunda1 | Category | Bug => General |
| 2018-03-10 01:35 | Kunda1 | Assigned To | => abdullah |
| 2018-03-10 01:35 | Kunda1 | Status | new => assigned |
| 2018-03-10 01:35 | Kunda1 | Note Added: 0011031 | |
| 2018-04-27 09:12 | abdullah | Note Added: 0011200 | |
| 2018-04-27 21:29 | chrisb | Note Added: 0011213 | |
| 2018-06-03 07:58 | chrisb | Status | assigned => closed |
| 2018-06-03 07:58 | chrisb | Resolution | open => fixed |
| 2018-06-03 07:58 | chrisb | Note Added: 0011345 |
