| 0003402 | FreeCAD | Bug | public | 2018-03-27 00:10 | 2018-08-26 15:20 |
| Reporter | pager48 | Assigned To | normandc | ||
| Summary | 0003402: Cannot use part design tools after leaving sketch and in sketcher workbench | ||||
| Description | Freecad cannot use part design tools (fillet in this example) after leaving sketch while in sketcher workbench. | ||||
| Steps To Reproduce | -Draw similar sketch -Pad it -Select same edges as in screen cast (Must be in sketcher workbench while selecting edges) -Switch to part design WB -Select fillet Results: Cannot use part design tool | ||||
This was for FreeCAD 0.17, Libs: 0.17R5235 (Git shallow) |
To be more specific it was FreeCAD_0.17.13452.glibc2.17-x86_64.AppImage |
OS: Linux Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.17.13452 (Git) AppImage Build type: None Branch: master Hash: 34633c144de9133c1f9aeb7da783f369cae9bfaf Python version: 2.7.6 Qt version: 4.8.6 Coin version: 4.0.0a OCC version: 7.1.0 Locale: English/UnitedStates (en_US) |
Including offending file |
@normandc do you mind weighing in? |
No issue here. You are mentioning two completely different FreeCAD versions. Look at the revision number, and the inscription "Git shallow". It is thousands of commits different from the current FreeCAD sources. AFAIK this is from the unofficial assembly3 build which is based on heavily modified FreeCAD sources. Who knows what happens with that version. Please create your model again but in an official development build. Even then, it works here with your provided FreeCAD file. In other words, if this only affects your assembly3 build, it is an invalid bug that should be reported to the assembly3 developer, not here. Besides your workflow is wrong. You should create sketches from the PartDesign workbench, not from Sketcher. When closing a sketch, you are brought back to PartDesign automatically. |
Tested and confirmed same bug exists in: OS: Linux Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.16.6712 (Git) Build type: None Branch: releases/FreeCAD-0-16 Hash: da2d364457257a7a8c6fb2137cea12c45becd71a Python version: 2.7.6 Qt version: 4.8.6 Coin version: 4.0.0a OCC version: 6.8.0.oce-0.17 |
I was curious and tried that.. Not replicable. I think pager48 selected entities from a SKETCH not edges of a solid. I use some existing solid, switched to sketcher, selected several edges and was able to fillet easily. OS: Windows 10 Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.17.13488 (Git) Build type: Release Branch: master Hash: 2891173923bcecaace64e0544f5773facbdef436 Python version: 2.7.14 Qt version: 4.8.7 Coin version: 4.0.0a OCC version: 7.1.0 Locale: German/Germany (de_DE) |
@pager48 please respond to 0003402:0011113 |
Harry is right. I just watched again the video. At 0:06 we clearly see in the tree that the Sketch is still selected when he selects edges on the solid then clicks on the Fillet tool. Doing the same thing as in the video, I get the same error message. This is user error plain and simple. |
This report is invalid. This is user error as shown in the video. Sketch is selected at the same time as edges on the Body, this is what causes the issue. |
| 2018-03-27 00:10 | pager48 | New Issue | |
| 2018-03-27 00:10 | pager48 | File Added: cannot-use-part-tools.mkv | |
| 2018-03-27 00:11 | pager48 | Note Added: 0011060 | |
| 2018-03-27 00:11 | pager48 | Note Added: 0011061 | |
| 2018-03-27 00:46 | pager48 | Note Added: 0011063 | |
| 2018-03-27 00:49 | pager48 | File Added: issue.fcstd | |
| 2018-03-27 00:49 | pager48 | Note Added: 0011065 | |
| 2018-03-27 18:45 | Kunda1 | Note Added: 0011070 | |
| 2018-03-27 19:01 | normandc | Note Added: 0011071 | |
| 2018-03-27 19:02 | normandc | Note Edited: 0011071 | |
| 2018-03-28 05:41 | pager48 | Note Added: 0011073 | |
| 2018-03-29 10:52 | Kunda1 | Tag Attached: #pending | |
| 2018-04-03 09:42 | harrygeier | File Added: proof.gif | |
| 2018-04-03 09:45 | harrygeier | Note Added: 0011113 | |
| 2018-06-07 16:54 | Kunda1 | Note Added: 0011360 | |
| 2018-06-07 16:54 | Kunda1 | Status | new => feedback |
| 2018-06-11 19:39 | normandc | Note Added: 0011405 | |
| 2018-06-11 19:41 | normandc | Assigned To | => normandc |
| 2018-06-11 19:41 | normandc | Status | feedback => closed |
| 2018-06-11 19:41 | normandc | Resolution | open => no change required |
| 2018-06-11 19:41 | normandc | Note Added: 0011406 | |
| 2018-08-26 15:20 | Kunda1 | Tag Detached: #pending |
