| 0003411 | FreeCAD | Bug | public | 2018-03-29 13:17 | 2018-06-10 19:38 |
| Reporter | danybd | Assigned To | |||
| Priority | high | Severity | feature | Reproducibility | always |
| Summary | 0003411: Pockets can not be created properlly on a imported .stl part | ||||
| Description | Pockets can not be created properlly on a imported .stl part. If you try to create a pocket using one side of the part, the part get black and partly disappears beeing no more solid part. Trying to find out, if the behavior could be a bug, I uninstalled the version v0.16 and tried the version 0.14. Using that version is working properlly | ||||
| Steps To Reproduce | 1-Import a .stl part 2-Create shape from mesh... -> 0.10mm 3-Convert to solid 4-Refine shape 5-Select one side of the part 6-Part Design -> Create Sketch 7-Draw a circle (the figure you draw is not relevant) 8-Pocket (the figure you drawed the step before) After that the part should get corrupt | ||||
this is not a bug. He missed ONE step .. STL must be converted to solid BEFORE working on it in part design., there is even a warning coming up . see the pocket in the complex STL of the screenshot.. OS: Windows 10 Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.17.13488 (Git) Build type: Release Branch: master Hash: 2891173923bcecaace64e0544f5773facbdef436 Python version: 2.7.14 Qt version: 4.8.7 Coin version: 4.0.0a OCC version: 7.1.0 Locale: German/Germany (de_DE) |
@danybd please read 0003411:0011111 Resolving issue |
Closing BTW, thanks @harrygeier for testing and commenting. |
| 2018-03-29 13:17 | danybd | New Issue | |
| 2018-04-03 09:15 | harrygeier | File Added: 2018-04-03 11_12_11-NotificationsForm.png | |
| 2018-04-03 09:15 | harrygeier | Note Added: 0011111 | |
| 2018-04-03 09:16 | harrygeier | Note Edited: 0011111 | |
| 2018-06-07 16:55 | Kunda1 | Status | new => resolved |
| 2018-06-07 16:55 | Kunda1 | Resolution | open => no change required |
| 2018-06-07 16:55 | Kunda1 | Note Added: 0011361 | |
| 2018-06-10 19:38 | Kunda1 | Status | resolved => closed |
| 2018-06-10 19:38 | Kunda1 | Note Added: 0011397 |
