| 0003415 | FreeCAD | Bug | public | 2018-04-01 01:03 | 2018-05-31 14:52 |
| Reporter | pager48 | Assigned To | |||
| Summary | 0003415: Cannot fillet or chamfer edge | ||||
| Description | No edges can be chamfered or fillited. Attached part this is with latest build | ||||
@normandc care to check this ticket ? |
First of all, product version should not be 0.18, its development isn't even started yet. pager48, you used the B-spline tool in the Sketcher, but this creates an open B-spline. Then you used a coincident constraint to close it, but the curve forms a sharp concave corner at the joint which is never good with fillets. If you want a closed B-spline, you should use the Periodic B-spline tool instead, which is below the B-spline tool in the toolbar. I replaced your B-spline in Sketch001 with a periodic B-spline, and it's possible to fillet the edges - although, with such tight curvature changes, there's an upper limit to the radius value where it fails. And that cannot be avoided. FreeCAD is limited by the OCCT kernel, but I doubt it would be better with commercial programs in this scenario. IMO this report should be closed as I don't see what can be done from FreeCAD's part. |
@pager48 please please please open forum threads asking about these things before opening tickets. It creates more work for volunteers who are ATM working on the 0.17 release. |
I think I will resolve (not close) this ticket based on NormandC's recommendation. |
| 2018-04-01 01:03 | pager48 | New Issue | |
| 2018-04-01 01:03 | pager48 | File Added: cannot-fillet.fcstd | |
| 2018-04-01 12:43 | Kunda1 | Note Added: 0011095 | |
| 2018-04-01 14:09 | normandc | File Added: issue-3415_normandc1.fcstd | |
| 2018-04-01 14:09 | normandc | Note Added: 0011096 | |
| 2018-04-01 16:28 | Kunda1 | Note Added: 0011097 | |
| 2018-04-02 17:26 | Kunda1 | Status | new => resolved |
| 2018-04-02 17:26 | Kunda1 | Resolution | open => no change required |
| 2018-04-02 17:26 | Kunda1 | Note Added: 0011109 | |
| 2018-04-02 17:27 | Kunda1 | Product Version | 0.18 => 0.17 |
| 2018-04-02 17:27 | Kunda1 | Priority | high => normal |
| 2018-04-02 17:27 | Kunda1 | Severity | major => minor |
| 2018-05-31 14:52 | Kunda1 | Status | resolved => closed |
