| 0003418 | Arch | Bug | public | 2018-04-01 17:39 | 2018-04-02 16:45 |
| Reporter | mahaidong | Assigned To | yorik | ||
| Summary | 0003418: export to html , can not open by browser. | ||||
| Description | when i change to , it can work. | ||||
test.html (17,704 bytes)
<!DOCTYPE html>
<html>
<head>
<title>FreeCAD model</title>
<script type="text/javascript" src="http://cdnjs.cloudflare.com/ajax/libs/three.js/r50/three.min.js"></script>
<script>
var camera, controls, scene, renderer;
window.onload = function() {
var SCREEN_WIDTH = window.innerWidth, SCREEN_HEIGHT = window.innerHeight;
var VIEW_ANGLE = 35, ASPECT = SCREEN_WIDTH / SCREEN_HEIGHT, NEAR = 0.1, FAR = 20000;
renderer = new THREE.WebGLRenderer();
renderer.setSize( SCREEN_WIDTH, SCREEN_HEIGHT );
document.body.appendChild( renderer.domElement );
scene = new THREE.Scene();
camera = new THREE.PerspectiveCamera(
VIEW_ANGLE, // Field of view
ASPECT, // Aspect ratio
NEAR, // Near plane
FAR // Far plane
camera.position.set( -12.9227733612, -17.7701721191, 10.9604349136 );
camera.lookAt( scene.position );
// placeholder for the FreeCAD camera
controls = new THREE.TrackballControls( camera );
controls.rotateSpeed = 1.0;
controls.zoomSpeed = 1.2;
controls.panSpeed = 0.8;
controls.noZoom = false;
controls.noPan = false;
controls.staticMoving = true;
controls.dynamicDampingFactor = 0.3;
controls.keys = [ 65, 83, 68 ];
var geom = new THREE.Geometry();
var v0 = new THREE.Vector3(-17.5583610954,-10.2581920204,-2.69981960679);
var v1 = new THREE.Vector3(-17.5583610954,-20.2581920204,7.30018039321);
var v2 = new THREE.Vector3(-17.5583610954,-10.2581920204,7.30018039321);
var v3 = new THREE.Vector3(-17.5583610954,-20.2581920204,-2.69981960679);
var v4 = new THREE.Vector3(-7.5583610954,-20.2581920204,7.30018039321);
var v5 = new THREE.Vector3(-7.5583610954,-10.2581920204,-2.69981960679);
var v6 = new THREE.Vector3(-7.5583610954,-10.2581920204,7.30018039321);
var v7 = new THREE.Vector3(-7.5583610954,-20.2581920204,-2.69981960679);
console.log(geom.vertices)
geom.vertices.push(v0);
geom.vertices.push(v1);
geom.vertices.push(v2);
geom.vertices.push(v3);
geom.vertices.push(v4);
geom.vertices.push(v5);
geom.vertices.push(v6);
geom.vertices.push(v7);
geom.faces.push( new THREE.Face3(0L, 1L, 2L) );
geom.faces.push( new THREE.Face3(3L, 1L, 0L) );
geom.faces.push( new THREE.Face3(4L, 5L, 6L) );
geom.faces.push( new THREE.Face3(4L, 7L, 5L) );
geom.faces.push( new THREE.Face3(7L, 4L, 3L) );
geom.faces.push( new THREE.Face3(3L, 4L, 1L) );
geom.faces.push( new THREE.Face3(6L, 5L, 0L) );
geom.faces.push( new THREE.Face3(6L, 0L, 2L) );
geom.faces.push( new THREE.Face3(0L, 5L, 3L) );
geom.faces.push( new THREE.Face3(3L, 5L, 7L) );
geom.faces.push( new THREE.Face3(6L, 2L, 1L) );
geom.faces.push( new THREE.Face3(6L, 1L, 4L) );
var basematerial = new THREE.MeshBasicMaterial( { color: 0xcccccc } );
var mesh = new THREE.Mesh( geom, basematerial );
scene.add( mesh );
var linematerial = new THREE.LineBasicMaterial({linewidth: 1, color: 0x000000,});
var wire = new THREE.Geometry();
wire.vertices.push(new THREE.Vector3(-17.5583610954, -10.2581920204, 7.30018039321));
wire.vertices.push(new THREE.Vector3(-17.5583610954, -10.2581920204, 2.30018039321));
wire.vertices.push(new THREE.Vector3(-17.5583610954, -10.2581920204, -0.19981960679));
wire.vertices.push(new THREE.Vector3(-17.5583610954, -10.2581920204, -1.44981960679));
wire.vertices.push(new THREE.Vector3(-17.5583610954, -10.2581920204, -2.07481960679));
wire.vertices.push(new THREE.Vector3(-17.5583610954, -10.2581920204, -2.38731960679));
wire.vertices.push(new THREE.Vector3(-17.5583610954, -10.2581920204, -2.69981960679));
wire.vertices.push(new THREE.Vector3(-17.5583610954, -15.2581920204, -2.69981960679));
wire.vertices.push(new THREE.Vector3(-17.5583610954, -17.7581920204, -2.69981960679));
wire.vertices.push(new THREE.Vector3(-17.5583610954, -19.0081920204, -2.69981960679));
wire.vertices.push(new THREE.Vector3(-17.5583610954, -19.6331920204, -2.69981960679));
wire.vertices.push(new THREE.Vector3(-17.5583610954, -19.9456920204, -2.69981960679));
wire.vertices.push(new THREE.Vector3(-17.5583610954, -20.2581920204, -2.69981960679));
wire.vertices.push(new THREE.Vector3(-17.5583610954, -20.2581920204, 2.30018039321));
wire.vertices.push(new THREE.Vector3(-17.5583610954, -20.2581920204, 4.80018039321));
wire.vertices.push(new THREE.Vector3(-17.5583610954, -20.2581920204, 6.05018039321));
wire.vertices.push(new THREE.Vector3(-17.5583610954, -20.2581920204, 6.67518039321));
wire.vertices.push(new THREE.Vector3(-17.5583610954, -20.2581920204, 6.98768039321));
wire.vertices.push(new THREE.Vector3(-17.5583610954, -20.2581920204, 7.30018039321));
var line = new THREE.Line(wire, linematerial);
scene.add(line);
wire.vertices.push(new THREE.Vector3(-7.5583610954, -10.2581920204, 7.30018039321));
wire.vertices.push(new THREE.Vector3(-7.5583610954, -10.2581920204, 2.30018039321));
wire.vertices.push(new THREE.Vector3(-7.5583610954, -10.2581920204, -0.19981960679));
wire.vertices.push(new THREE.Vector3(-7.5583610954, -10.2581920204, -1.44981960679));
wire.vertices.push(new THREE.Vector3(-7.5583610954, -10.2581920204, -2.07481960679));
wire.vertices.push(new THREE.Vector3(-7.5583610954, -10.2581920204, -2.38731960679));
wire.vertices.push(new THREE.Vector3(-7.5583610954, -10.2581920204, -2.69981960679));
wire.vertices.push(new THREE.Vector3(-7.5583610954, -15.2581920204, -2.69981960679));
wire.vertices.push(new THREE.Vector3(-7.5583610954, -17.7581920204, -2.69981960679));
wire.vertices.push(new THREE.Vector3(-7.5583610954, -19.0081920204, -2.69981960679));
wire.vertices.push(new THREE.Vector3(-7.5583610954, -19.6331920204, -2.69981960679));
wire.vertices.push(new THREE.Vector3(-7.5583610954, -19.9456920204, -2.69981960679));
wire.vertices.push(new THREE.Vector3(-7.5583610954, -20.2581920204, -2.69981960679));
wire.vertices.push(new THREE.Vector3(-7.5583610954, -20.2581920204, 2.30018039321));
wire.vertices.push(new THREE.Vector3(-7.5583610954, -20.2581920204, 4.80018039321));
wire.vertices.push(new THREE.Vector3(-7.5583610954, -20.2581920204, 6.05018039321));
wire.vertices.push(new THREE.Vector3(-7.5583610954, -20.2581920204, 6.67518039321));
wire.vertices.push(new THREE.Vector3(-7.5583610954, -20.2581920204, 6.98768039321));
wire.vertices.push(new THREE.Vector3(-7.5583610954, -20.2581920204, 7.30018039321));
scene.add(line);
wire.vertices.push(new THREE.Vector3(-12.5583610954, -20.2581920204, 7.30018039321));
wire.vertices.push(new THREE.Vector3(-15.0583610954, -20.2581920204, 7.30018039321));
wire.vertices.push(new THREE.Vector3(-16.3083610954, -20.2581920204, 7.30018039321));
wire.vertices.push(new THREE.Vector3(-16.9333610954, -20.2581920204, 7.30018039321));
wire.vertices.push(new THREE.Vector3(-17.2458610954, -20.2581920204, 7.30018039321));
wire.vertices.push(new THREE.Vector3(-17.5583610954, -20.2581920204, -0.19981960679));
wire.vertices.push(new THREE.Vector3(-17.5583610954, -20.2581920204, -1.44981960679));
wire.vertices.push(new THREE.Vector3(-17.5583610954, -20.2581920204, -2.07481960679));
wire.vertices.push(new THREE.Vector3(-17.5583610954, -20.2581920204, -2.38731960679));
wire.vertices.push(new THREE.Vector3(-12.5583610954, -20.2581920204, -2.69981960679));
wire.vertices.push(new THREE.Vector3(-10.0583610954, -20.2581920204, -2.69981960679));
wire.vertices.push(new THREE.Vector3(-8.8083610954, -20.2581920204, -2.69981960679));
wire.vertices.push(new THREE.Vector3(-8.1833610954, -20.2581920204, -2.69981960679));
wire.vertices.push(new THREE.Vector3(-7.8708610954, -20.2581920204, -2.69981960679));
scene.add(line);
wire.vertices.push(new THREE.Vector3(-12.5583610954, -10.2581920204, 7.30018039321));
wire.vertices.push(new THREE.Vector3(-15.0583610954, -10.2581920204, 7.30018039321));
wire.vertices.push(new THREE.Vector3(-16.3083610954, -10.2581920204, 7.30018039321));
wire.vertices.push(new THREE.Vector3(-16.9333610954, -10.2581920204, 7.30018039321));
wire.vertices.push(new THREE.Vector3(-17.2458610954, -10.2581920204, 7.30018039321));
wire.vertices.push(new THREE.Vector3(-12.5583610954, -10.2581920204, -2.69981960679));
wire.vertices.push(new THREE.Vector3(-10.0583610954, -10.2581920204, -2.69981960679));
wire.vertices.push(new THREE.Vector3(-8.8083610954, -10.2581920204, -2.69981960679));
wire.vertices.push(new THREE.Vector3(-8.1833610954, -10.2581920204, -2.69981960679));
wire.vertices.push(new THREE.Vector3(-7.8708610954, -10.2581920204, -2.69981960679));
scene.add(line);
wire.vertices.push(new THREE.Vector3(-15.0583610954, -20.2581920204, -2.69981960679));
wire.vertices.push(new THREE.Vector3(-16.3083610954, -20.2581920204, -2.69981960679));
wire.vertices.push(new THREE.Vector3(-16.9333610954, -20.2581920204, -2.69981960679));
wire.vertices.push(new THREE.Vector3(-17.2458610954, -20.2581920204, -2.69981960679));
wire.vertices.push(new THREE.Vector3(-17.5583610954, -12.7581920204, -2.69981960679));
wire.vertices.push(new THREE.Vector3(-17.5583610954, -11.5081920204, -2.69981960679));
wire.vertices.push(new THREE.Vector3(-17.5583610954, -10.8831920204, -2.69981960679));
wire.vertices.push(new THREE.Vector3(-17.5583610954, -10.5706920204, -2.69981960679));
scene.add(line);
wire.vertices.push(new THREE.Vector3(-7.5583610954, -15.2581920204, 7.30018039321));
wire.vertices.push(new THREE.Vector3(-7.5583610954, -17.7581920204, 7.30018039321));
wire.vertices.push(new THREE.Vector3(-7.5583610954, -19.0081920204, 7.30018039321));
wire.vertices.push(new THREE.Vector3(-7.5583610954, -19.6331920204, 7.30018039321));
wire.vertices.push(new THREE.Vector3(-7.5583610954, -19.9456920204, 7.30018039321));
wire.vertices.push(new THREE.Vector3(-17.5583610954, -15.2581920204, 7.30018039321));
wire.vertices.push(new THREE.Vector3(-17.5583610954, -12.7581920204, 7.30018039321));
wire.vertices.push(new THREE.Vector3(-17.5583610954, -11.5081920204, 7.30018039321));
wire.vertices.push(new THREE.Vector3(-17.5583610954, -10.8831920204, 7.30018039321));
wire.vertices.push(new THREE.Vector3(-17.5583610954, -10.5706920204, 7.30018039321));
scene.add(line);
// placeholder for the FreeCAD objects
var light = new THREE.PointLight( 0xFFFF00 );
light.position.set( -10000, -10000, 10000 );
scene.add( light );
renderer.render( scene, camera );
animate();
function animate(){
requestAnimationFrame( animate );
render();
function render(){
controls.update();
</script>
</head>
<body></body>
</html> |
@mahaidong please read the instructions that are posted ever so prominently at the top of our bugtracker. You are missing several key bits of information + a forum thread that needs to be open beforehand |
I also post to https://forum.freecadweb.org [url=https://forum.freecadweb.org/viewtopic.php?f=9&t=3914&p=225014#p225014 ]https://forum.freecadweb.org/viewtopic.php?f=9&t=3914&p=225014#p225014 [/url]:) |
src/Mod/Arch/importWebGL.py maybe can fix by this : line180
line200
Dont know where this new notation comes from, but anyway, this is fixed in https://git.io/vxis1 Thanks for the fix! |
| 2018-04-01 17:39 | mahaidong | New Issue | |
| 2018-04-01 17:39 | mahaidong | File Added: test.html | |
| 2018-04-01 18:18 | Kunda1 | Assigned To | => Kunda1 |
| 2018-04-01 18:18 | Kunda1 | Status | new => feedback |
| 2018-04-01 18:18 | Kunda1 | Note Added: 0011099 | |
| 2018-04-01 19:46 | mahaidong | Status | feedback => assigned |
| 2018-04-01 19:53 | mahaidong | Note Added: 0011101 | |
| 2018-04-02 05:00 | mahaidong | Note Added: 0011102 | |
| 2018-04-02 05:00 | mahaidong | Note Edited: 0011102 | |
| 2018-04-02 05:08 | mahaidong | Note Edited: 0011101 | |
| 2018-04-02 16:44 | yorik | Note Added: 0011103 | |
| 2018-04-02 16:45 | yorik | Note Edited: 0011103 | |
| 2018-04-02 16:45 | yorik | Assigned To | Kunda1 => yorik |
| 2018-04-02 16:45 | yorik | Status | assigned => closed |
| 2018-04-02 16:45 | yorik | Resolution | open => fixed |
