0003420FreeCADBugpublic2021-02-06 06:49
Reporterherrdeh Assigned Toyorik
Status assignedResolutionopen
PlatformallOSallOS Versionall
Product Version0.17
Target Version0.20
Summary0003420: SVG imports from inkscape lead to wrong dimensions
DescriptionWith the change from 0.91 to 0.92 inkscape devs changed the conversion factor of userunit (uu) and mm. Pre-0.92 it was 1uu=1 inch/90 and starting from 0.92 it is 1 uu=1inch/96. This was necessary to meet the actual recommendations/rules of svg-standard and css. See this article in inkscapewiki for further reading.
When a user creates a file in inkscape with absolute dimensions (mm) and saves it, then imports it into FC, bodies in Freecad come out with too large dimensions. For example - a 100mm square will be 106,66mm in FC now (100 x 96/90).
In this discussion in the German forum folks who can read German can follow the process of isotating the bug.
New forum thread opened in https://forum.freecad.org/viewtopic.php?f=8&t=37102
Steps To ReproduceImport a SVG file from inkscape >=0.92 - check measures.
Tagsimport, Inkscape, SVG
Relationships
related to 0003304 new Integrate Inkscape in to FreeCAD
has duplicate 0004200 closed Import from SVG gets wrong scale
yorik
2018-04-03 15:38
administrator   ~0011114
Would it be possible to provide two very simle test files that would allow to check the results?
herrdeh
2018-04-04 08:12
reporter
herrdeh
2018-04-04 08:14
reporter   ~0011120
Here are inkscape test files. Unluckily, none of my FC versions are capable of SVG import at the moment, so I cannot provide FC test files. But importing both of these examples should lead to different squares, allthough both of them are 100x200mm in inkscape.
yorik
2018-04-04 14:07
administrator   ~0011121
Thanks! I'll have a look at this after the release is out.
2019-06-17 14:59
administrator   ~0013238
New forum discussion thread opened in https://forum.freecad.org/viewtopic.php?f=8&t=37102
teo8976
2019-11-23 13:40
reporter   ~0013837
This has nothing to do specifically with Inkscape, and it has nothing to do specifically with mm.
Look at the attached SVG file. I wrote this SVG file by hand, it was not exported from Inkscape:
<svg width="595.28pt" height="420.94pt"  viewBox="0 0 210 148" xmlns="http://www.w3.org/2000/svg">
This defines a physical size in pt for the document (which is A4) and a corresponding viewbox such that 1 user unit should be 2.83465 pt which is 1 mm.
Hence the physical size of 1 unit in the document should be that.
That is defined by the document.
I have imported this and exported to dxf and the resulting width of the 190mm rectangles is about 185mm.
Then for some reason, if instead of exporting to dxf I print it to pdf (not export to pdf, print and select "print to pdf"), for some reason they're even much smaller.
But I don't know, maybe the "print" feature has no notion of a real physical size and just print everything to fit whatever paper size you choose.
1_08mm_plakene_DINA4.svg (1,455 bytes)
openBrain
2019-11-24 13:30
developer   ~0013839
@teo8976 : actually it has to do with Inkscape because for long time, FreeCAD relies on Inkscape SVG format. Inkscape doesn't export a viewbox so user unit can't be arithmetically determined. Issue was that Inkscape was using a strange 90 dpi so FC converts with this setting. Inkscape has recently moved to SVG standard 96 dpi and it makes emerge some problems. Things has been greatly improved and I'm now able to correctly import your file with latest 0.19 (despite I found a small bug that I'll report). Time for you to leave your 0.15 release and upgrade. ;)
teo8976
2019-11-24 13:54
reporter   ~0013840
Yeah but my file (which was not created by Inkscape) does have a viewbox AND document width and height on the root node, so the size of a user unit should be calculated from those without any fixed dpi involved. I haven't tried changing the width, height and viewbox though, to see whether the results differ (they should).
I know, that's the version I got with apt-get. Time for [whoever maintains that] to release a more recent one for Ubuntu.
openBrain
2019-11-24 14:20
developer   ~0013841
@teo8976 : the file you posted in this ticket raised the evidence that 'pt' unit has been forever not well defined in FC. ;) I submitted this PR to fix it. However as I explained above, this only solves part of your problems as I explained above.
Everything should be OK with 0.19 version once the PR is integrated. Thanks for your perseverance.
yorik
2022-03-03 13:55
administrator   ~0016616
This ticket has been migrated to GitHub as issue 5781.
2018-04-03 13:03 herrdeh New Issue
2018-04-03 13:03 herrdeh Tag Attached: import
2018-04-03 13:03 herrdeh Tag Attached: Inkscape
2018-04-03 13:03 herrdeh Tag Attached: SVG
2018-04-03 15:38 yorik Note Added: 0011114
2018-04-03 15:39 yorik Assigned To => yorik
2018-04-03 15:39 yorik Status new => assigned
2018-04-03 15:39 yorik Status assigned => feedback
2018-04-04 08:12 herrdeh File Added: Viereck-100x200-Rand0,1-inkscape092.svg
2018-04-04 08:12 herrdeh File Added: Viereck-100x200-Rand0,1-inkscape048.svg
2018-04-04 08:14 herrdeh Note Added: 0011120
2018-04-04 08:14 herrdeh Status feedback => assigned
2018-04-04 14:07 yorik Note Added: 0011121
2018-08-23 17:37 Kunda1 Target Version => 0.18
2018-12-05 13:10 yorik Target Version 0.18 => 0.19
2019-06-17 14:59 Kunda1 Description Updated
2019-06-17 14:59 Kunda1 Note Added: 0013238
2019-06-22 15:32 Kunda1 Relationship added related to 0003304
2019-11-22 16:39 openBrain Relationship added has duplicate 0004200
2019-11-23 13:40 teo8976 File Added: 1_08mm_plakene_DINA4.svg
2019-11-23 13:40 teo8976 Note Added: 0013837
2019-11-24 13:30 openBrain Note Added: 0013839
2019-11-24 13:54 teo8976 Note Added: 0013840
2019-11-24 14:20 openBrain Note Added: 0013841
