| 0003433 | Sketcher | Bug | public | 2018-04-16 20:51 | 2018-10-28 09:03 |
| Reporter | ulrich1a | Assigned To | abdullah | ||
| Platform | Linux | OS | Debian | OS Version | Stretch |
| Summary | 0003433: Cannot constrain another b-spline to a b-spline with a block constraint | ||||
| Description | A b-spline can be fixed with a block constraint. This is very comfortable in many situations. But it is misleading, when one attempts to constrain another b-spline to it with auto-constraint. It appears as if an auto-constraint was added, but there is no additional constraint in the list. | ||||
| Steps To Reproduce | Open a sketch in a document. 1. Add an b-spline to it. 2. Apply the block constraint to it. 3. Start a second b-spline at the endpoint of the first one. When the auto-constraint of a dot appears, start the second spline and draw it. At the end the second spline is not fixed to the blocked one. | ||||
| Additional Information | The behavior was confirmed as half a bug in the forum: https://forum.freecad.org/viewtopic.php?f=9&t=26572&sid=7e682fdf2296ef7fcf08fe3c813f3c77&start=10#p227778 | ||||
| Tags | constraints, sketcher | ||||
There is an update in the forum, linking to an appimage, for further feedback: https://forum.freecad.org/viewtopic.php?f=9&t=26572&start=20#p235410 |
@kunda1 I think this is fixed in master now. Could we have it tested by a 3rd party to confirm and close if appropriate? thanks!! |
@ulrich1a please test and confirm the fix |
I tested the steps and can confirm the fix. In 0.17 doesn't work, in git master it works. |
@qurn thank you Closing ticket |
| 2018-04-16 20:51 | ulrich1a | New Issue | |
| 2018-04-16 20:51 | ulrich1a | Tag Attached: constraints | |
| 2018-04-16 20:51 | ulrich1a | Tag Attached: sketcher | |
| 2018-04-17 00:19 | normandc | Assigned To | => abdullah |
| 2018-04-17 00:19 | normandc | Status | new => assigned |
| 2018-05-25 11:55 | abdullah | Note Added: 0011277 | |
| 2018-05-25 11:55 | abdullah | Status | assigned => feedback |
| 2018-09-28 17:39 | abdullah | Note Added: 0011871 | |
| 2018-09-28 19:27 | Kunda1 | Target Version | => 0.18 |
| 2018-10-28 02:40 | Kunda1 | Note Added: 0012105 | |
| 2018-10-28 08:43 | qurn | Note Added: 0012107 | |
| 2018-10-28 09:03 | Kunda1 | Status | feedback => closed |
| 2018-10-28 09:03 | Kunda1 | Resolution | open => fixed |
| 2018-10-28 09:03 | Kunda1 | Fixed in Version | => 0.18 |
| 2018-10-28 09:03 | Kunda1 | Note Added: 0012108 |
