| 0003458 | Part | Bug | public | 2018-05-04 12:31 | 2022-01-24 19:16 |
| Reporter | chrisb | Assigned To | |||
| Summary | 0003458: Recompute does not create a solid containing a complex shaped hole (upstream OCC bug) | ||||
| Description | When a solid contains a very complex hole it is not displayed correctly. See forum discussion UR_ has found a fix: https://forum.freecadweb.org/viewtopic.php?f=3&t=28487&start=10#p231534 and some code: | ||||
| Tags | #ready-for-migration, OCC 7.3, OCC Bug, upstream | ||||
It's a 100% OCCT bug. With v7.2 it at least can create the missing face but must perform the meshing twice. |
@wmayer should a bug be submitted upstream ? |
@user1234 writes in https://forum.freecadweb.org/viewtopic.php?p=534396#p534396
This ticket has been migrated to GitHub as issue 5787. |
| 2018-05-04 12:31 | chrisb | New Issue | |
| 2018-05-04 21:30 | kkremitzki | Project | PartDesign => Part |
| 2018-05-04 21:30 | kkremitzki | Category | Bug => General |
| 2018-05-27 14:05 | wmayer | Category | General => Bug |
| 2018-05-27 16:39 | wmayer | Note Added: 0011287 | |
| 2018-05-30 23:39 | Kunda1 | Tag Attached: OCC Bug | |
| 2018-05-30 23:39 | Kunda1 | Tag Attached: upstream | |
| 2018-05-30 23:39 | Kunda1 | Tag Attached: OCC 7.3 | |
| 2018-05-30 23:39 | Kunda1 | Note Added: 0011316 | |
| 2018-05-30 23:40 | Kunda1 | Status | new => confirmed |
| 2018-05-30 23:40 | Kunda1 | Summary | Recompute does not create a solid containing a complex shaped hole => Recompute does not create a solid containing a complex shaped hole (upstream OCC bug) |
| 2018-08-23 17:33 | Kunda1 | Description Updated | |
| 2022-01-15 13:25 | Kunda1 | Note Added: 0016211 | |
