| 0003460 | Spreadsheet | Feature | public | 2018-05-04 21:04 | 2021-11-24 15:30 |
| Reporter | ulrich1a | Assigned To | realthunder | ||
| Summary | 0003460: Add the following functions to expressions and spreadsheet: concatenate text and indirect | ||||
| Description | It would be an advantage, if a spreadsheet can be filled with different sets of parameters to create a model and then just change one cell to select a certain parameter set. This can be done in a traditional spreadsheet with text concatenation and a line with indirect-functions that use the concatenated text as a cell-adress. | ||||
| Tags | expressions, spreadsheet | ||||
| 2018-05-04 21:04 | ulrich1a | New Issue | |
| 2018-05-04 21:04 | ulrich1a | Tag Attached: expressions | |
| 2018-05-04 21:04 | ulrich1a | Tag Attached: spreadsheet | |
| 2020-02-27 05:54 | realthunder | Note Added: 0014186 | |
| 2020-02-27 18:09 | Kunda1 | Assigned To | => realthunder |
| 2020-02-27 18:09 | Kunda1 | Status | new => assigned |
| 2021-11-24 15:30 | chennes | Project | Expressions => Spreadsheet |
