| 0003474 | Expressions | Bug | public | 2018-05-13 20:24 | 2019-01-20 00:04 |
| Reporter | DeepSOIC | Assigned To | DeepSOIC | ||
| Summary | 0003474: Spreadsheet drag-drop across containers makes linked objects move as well | ||||
| Description | When dragging a spreadsheet linked by expressions to other objects, across coordinate systems (e.g. into, or out of Part), a whole cluster of linked together objects follows. This is not needed (spreadsheet links are expression links, not geometric links), and looks like there is no easy workaround. forum thread: https://forum.freecadweb.org/viewtopic.php?p=229098 | ||||
| Steps To Reproduce | 1. Open attached file dragdrop-spreadsheet-bug.FCStd (13.16 KiB) Not downloaded yet 2. Drag-drop Spreadsheet into Part -> Everything is moved into Part, except for Cube001. expected behavior: only spreadsheet should end up in Part. Also: 1. Open attached file. 2. Select everything but Part and Spreadsheet 3. Drag-drop the "everything" into Part -> Spreadsheet is also moved into Part. expected: spreadsheet stays outside of Part. | ||||
| Additional Information | OS: Windows 10 Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.17.13509 (Git) Build type: Release Branch: releases/FreeCAD-0-17 Hash: 0258808ccb6ba3bd5ea9312f79cd023f1a8671b7 Python version: 2.7.14 Qt version: 4.8.7 Coin version: 4.0.0a OCC version: 7.2.0 Locale: Russian/RussianFederation (ru_RU) | ||||
@eivindkvedalen quick question, this ticket is targeted for 0.18 will it in fact make it in to the 0.18 release ? |
i'm working on it right now, stay tuned... |
https://github.com/FreeCAD/FreeCAD/pull/1917 |
https://github.com/FreeCAD/FreeCAD/commit/28cbe2bd8986701bb7404842cf60138957e23ed6 |
| 2018-05-13 20:24 | DeepSOIC | New Issue | |
| 2018-05-13 20:24 | DeepSOIC | File Added: dragdrop-spreadsheet-bug.FCStd | |
| 2018-05-30 23:27 | Kunda1 | Project | FreeCAD => Expressions |
| 2018-05-30 23:31 | Kunda1 | Target Version | => 0.18 |
| 2018-05-30 23:31 | Kunda1 | Description Updated | |
| 2018-05-30 23:31 | Kunda1 | Steps to Reproduce Updated | |
| 2018-05-30 23:31 | Kunda1 | Additional Information Updated | |
| 2019-01-19 11:59 | Kunda1 | Note Added: 0012466 | |
| 2019-01-19 12:11 | DeepSOIC | Note Added: 0012467 | |
| 2019-01-19 12:17 | DeepSOIC | Note Added: 0012468 | |
| 2019-01-20 00:04 | wmayer | Assigned To | => DeepSOIC |
| 2019-01-20 00:04 | wmayer | Status | new => closed |
| 2019-01-20 00:04 | wmayer | Resolution | open => fixed |
| 2019-01-20 00:04 | wmayer | Fixed in Version | => 0.18 |
| 2019-01-20 00:04 | wmayer | Note Added: 0012469 |
