| 0003483 | Draft | Bug | public | 2018-05-18 07:37 | 2022-02-03 15:15 |
| Reporter | steelman | Assigned To | yorik | ||
| Summary | 0003483: Simple paths cannot be upgraded | ||||
| Description | Simple paths imported from SVG files cannot be upgraded to Blocks | ||||
| Steps To Reproduce | 1. Create an SVG file with simple (open) paths comprising two nodes each (one edge). 2. Import it into the Draft workbench as geometry. 3. Select the paths and use the upgrade tool. Expected result: The paths are upgraded to a Block. Actual result: Nothing happens to the objects and a message is displayed: Unable to upgrade these objects | ||||
| Additional Information | It appears the bug still exists and is caused by this condition. If paths comprise more then two nodes, the Block is created properly. OS: Debian GNU/Linux 9.4 (stretch) Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.16. Build type: None Python version: 2.7.13 Qt version: 4.8.7 Coin version: 4.0.0a OCC version: 6.8.0.oce-0.17 | ||||
| Tags | SVG | ||||
The attached file contains four paths to demonstrate the problem. The problem described above can be triggered by an attempt to import paths №3 and №4. Paths №1 and №2 can be upgraded to a Block successfully. Upgrading single path (№3 or №4) doesn't work either. |
@steelman Please test with 0.17 and report your results. Also please verify bugs on the forums first and let the community as described in the large yellow banner that should be displayed at the top of this tracker page. |
@steelman ping |
Alive. I will check this the next week. |
Thanks, resetting this to 'Feedback' status, JIC. |
Still broken in OS: Debian GNU/Linux 9.5 (stretch) Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.17.13528 (Git) AppImage Build type: None Branch: releases/FreeCAD-0-17 Hash: 5c3f7bf8ec51e2c7187789f7edba71a7aa82a88b Python version: 2.7.6 Qt version: 4.8.6 Coin version: 4.0.0a OCC version: 7.3.0 Locale: Polish/Poland (pl_PL) and OS: Debian GNU/Linux 9.5 (stretch) Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.18.5235 (Git shallow) AppImage Build type: Release Branch: master Hash: 3e6cc7bbcd03ef2a9d57d504b0971c098e64171a Python version: 3.6.5 Qt version: 5.6.2 Coin version: 4.0.0a OCC version: 7.2.0 Locale: Polish/Poland (pl_PL) |
@steelman Edit: Forum thread: https://forum.freecad.org/viewtopic.php?f=8&t=30427 |
I don't understand what you are trying to accomplish by upgrading these paths. Why do you need to upgrade to a Block? FYI a block is not a FreeCAD entity, it's a DXF/DWG entity so it's relevant only at import/export time, for DXF/DWG file formats. In FreeCAD the basic entities are vertex, edge, wire, face, shell, solid, compound and compsolid. Paths Nº 1 & 2 are not upgraded to Blocks, they are upgraded to Wires because they comprise 2 edges. Since Paths Nº 3 and 4 only comprise a single edge each, I'm guessing there is simply nothing to upgrade. |
vocx has a workaround in https://forum.freecad.org/viewtopic.php?f=8&t=30427&p=477089#p360510 |
Fixed with http://github.com/FreeCAD/FreeCAD/commit/8492cfb9eb |
| 2018-05-18 07:37 | steelman | New Issue | |
| 2018-05-18 08:37 | steelman | File Added: paths.svg | |
| 2018-05-18 08:37 | steelman | Note Added: 0011257 | |
| 2018-05-18 08:40 | steelman | Note Edited: 0011257 | |
| 2018-05-29 19:47 | Kunda1 | Status | new => feedback |
| 2018-05-29 19:47 | Kunda1 | Note Added: 0011299 | |
| 2018-05-29 19:49 | Kunda1 | Relationship added | related to 0003484 |
| 2018-06-17 18:23 | Kunda1 | Tag Attached: SVG | |
| 2018-08-01 03:01 | Kunda1 | Note Added: 0011575 | |
| 2018-08-05 13:57 | steelman | Note Added: 0011590 | |
| 2018-08-05 13:57 | steelman | Status | feedback => new |
| 2018-08-06 08:40 | Kunda1 | Assigned To | => Kunda1 |
| 2018-08-06 08:40 | Kunda1 | Status | new => feedback |
| 2018-08-06 08:40 | Kunda1 | Note Added: 0011591 | |
| 2018-08-19 13:29 | steelman | Note Added: 0011631 | |
| 2018-08-19 13:29 | steelman | Status | feedback => assigned |
| 2018-08-21 12:45 | Kunda1 | Assigned To | Kunda1 => |
| 2018-08-21 12:45 | Kunda1 | Status | assigned => acknowledged |
| 2018-08-21 12:45 | Kunda1 | Note Added: 0011633 | |
| 2018-08-21 12:46 | Kunda1 | Note Edited: 0011633 | |
| 2018-09-02 21:31 | normandc | Note Added: 0011689 | |
| 2021-02-11 17:40 | Kunda1 | Note Added: 0015328 | |
| 2022-02-03 15:15 | yorik | Assigned To | => yorik |
| 2022-02-03 15:15 | yorik | Status | acknowledged => closed |
| 2022-02-03 15:15 | yorik | Resolution | open => fixed |
| 2022-02-03 15:15 | yorik | Fixed in Version | => 0.20 |
| 2022-02-03 15:15 | yorik | Note Added: 0016344 |
