| 0003485 | Draft | Bug | public | 2018-05-18 08:22 | 2019-02-19 22:57 |
| Reporter | roland | Assigned To | yorik | ||
| Platform | Macintosh | OS | os X | OS Version | 10.13.4 |
| Summary | 0003485: Draft : The move tool does not work correctly | ||||
| Description | In the draft mode, when I click a corner in order to drag it to another corner, the part i'm dragging is not moved (at all) or is moved in a totally different way. (see picture enclosed) | ||||
| Steps To Reproduce | - Click any corner of the enclose FCStd file (in pink color on the png file and try to drag it using the move tool. - A "ghost" part is drawn but NOT a the right position (in my case, lower) and it's impossible to drop the part anywhere. | ||||
| Additional Information | I've tried with two distinct mice (the regular one with a ball on top, and a "magic mouse" wireless) : same result. I've tried with a previous version of "os X" (el capitain) and it seems to work fine (i'm not very familiar with the move tool, but the moves are ot eratic as they are on os X 10.13.4.) Version : OS: Mac OS X Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.17.13519 (Git) Build type: Release Branch: (HEAD detached at 1a8b868) Hash: 1a8b868018f45ea486c0023fdbfeb06febc1fb89 Python version: 2.7.14 Qt version: 5.10.1 Coin version: 4.0.0a OCC version: 7.2.0 Locale: English/UnitedStates (en_US) Thanks for your work ! Roland Lannuzel (Paris, France) | ||||
| Tags | mouse, mouse-gestures | ||||
Please, read DRAFT MODE instead of SKETCH MODE :-/ (don't know if i could have edited my report) |
@roland please post this issue for community discussion on the forums. Reference this ticket and also reference the forum link in this ticket. |
@chrisb care to weigh in ? |
@chrisb ping |
Forum thread: https://forum.freecadweb.org/viewtopic.php?f=8&t=29731 |
Sorry for being late. I can reproduce the issue here: OS: Mac OS X Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.18.13976 (Git) Build type: Release Branch: (HEAD detached at fae0de5) Hash: fae0de58581694157a97d567c151bdce75d387dc Python version: 2.7.15 Qt version: 5.11.0 Coin version: 4.0.0a OCC version: 7.2.0 Locale: German/Germany (de_DE) |
Changed from Sketcher to Draft Confirmed by DeepSOIC in https://forum.freecadweb.org/viewtopic.php?f=8&t=29731&p=244126#p244111 |
Just reproduced this on 0.18.15780 on Linux 64-bit. This bug is making it difficult for me to work with large multi-part projects containing a mixture of Part and PartDesign objects. |
The problem is only cosmetic. The "ghost" (the temporary shape displayed while using Draft Move) is not taking the Part displacement into consideration. But since it is a direct copy of the base object's coin node, it should appear at the same place.. I need to investigate more how the Part container works. In any case, the actual moving of object works correctly (for the ones that are permitted to move, of course, as there are several pads there) |
Fixed with https://github.com/FreeCAD/FreeCAD/compare/3fc17edb4149...187988b64b7d |
| 2018-05-18 08:22 | roland | New Issue | |
| 2018-05-18 08:22 | roland | Tag Attached: Draft | |
| 2018-05-18 08:22 | roland | Tag Attached: mouse | |
| 2018-05-18 08:22 | roland | Tag Attached: mouse-gestures | |
| 2018-05-18 08:22 | roland | File Added: Draft.png | |
| 2018-05-18 08:22 | roland | File Added: Clones.FCStd | |
| 2018-05-18 08:42 | roland | Note Added: 0011258 | |
| 2018-05-29 19:48 | Kunda1 | Summary | Sketch mode : The move tool does not work correctly (high sierra only?) => Draft mode : The move tool does not work correctly (high sierra only?) |
| 2018-05-29 19:48 | Kunda1 | Additional Information Updated | |
| 2018-05-29 19:49 | Kunda1 | Assigned To | => Kunda1 |
| 2018-05-29 19:49 | Kunda1 | Status | new => feedback |
| 2018-05-29 19:49 | Kunda1 | Note Added: 0011300 | |
| 2018-06-11 00:49 | Kunda1 | Summary | Draft mode : The move tool does not work correctly (high sierra only?) => Sketcher : The move tool does not work correctly (high sierra only?) |
| 2018-06-11 00:49 | Kunda1 | Project | Draft => Sketcher |
| 2018-06-11 00:49 | Kunda1 | Tag Detached: Draft | |
| 2018-06-11 00:50 | Kunda1 | Note Added: 0011402 | |
| 2018-07-05 02:15 | Kunda1 | Note Added: 0011496 | |
| 2018-07-12 12:04 | Kunda1 | Note Added: 0011516 | |
| 2018-07-12 15:40 | chrisb | Note Added: 0011522 | |
| 2018-07-12 18:31 | Kunda1 | Summary | Sketcher : The move tool does not work correctly (high sierra only?) => Draft : The move tool does not work correctly (high sierra only?) |
| 2018-07-12 18:31 | Kunda1 | Description Updated | |
| 2018-07-12 18:31 | Kunda1 | Project | Sketcher => Draft |
| 2018-07-12 18:33 | Kunda1 | Assigned To | Kunda1 => |
| 2018-07-12 18:33 | Kunda1 | Status | feedback => confirmed |
| 2018-07-12 18:33 | Kunda1 | Note Added: 0011524 | |
| 2018-07-12 18:33 | Kunda1 | Target Version | => 0.18 |
| 2018-08-26 00:06 | Kunda1 | Summary | Draft : The move tool does not work correctly (high sierra only?) => Draft : The move tool does not work correctly |
| 2019-02-07 04:15 | jzroth | Note Added: 0012588 | |
| 2019-02-16 22:45 | yorik | Note Added: 0012670 | |
| 2019-02-16 22:46 | yorik | Assigned To | => yorik |
| 2019-02-16 22:46 | yorik | Status | confirmed => assigned |
| 2019-02-19 22:57 | yorik | Note Added: 0012697 | |
| 2019-02-19 22:57 | yorik | Status | assigned => closed |
| 2019-02-19 22:57 | yorik | Resolution | open => fixed |
| 2019-02-19 22:57 | yorik | Fixed in Version | => 0.18 |
