0003497SketcherBugpublic2018-05-30 15:43
Reporterbillfromnet Assigned To
PlatformLinuxOSUbuntuOS Version17.10
Product Version0.17
Summary0003497: Contraint labeling orientation is incorrect and misleading
DescriptionI've attached a sketch to a plane with 180 degree Attachment Angle (InertialCS). I added a vertical position constraint based on a reference to an extrusion elsewhere. The constraint seems to be applied, and its numerical magnitude is displayed correctly, but it is depicted with a 90 degree shift and zero magnitude which is quite confusing.
Steps To ReproduceIn this specific case, which is probably unnecessarily detailed...
* Create an extrusion including an arc
* create a plane tangent to the resulting cylinder surface
* Create a sketch
** Attach sketch to plane with non-default attachment angle
** vertically constrain a point in sketch based on value of arc extrusion LengthFwd
Additional InformationOS: Ubuntu 17.10
Version: 0.17.13522 (Git) AppImage
Build type: None
Branch: releases/FreeCAD-0-17
Hash: 3bb5ff4e70c0c526f2d9dd69b1004155b2f527f2
Python version: 2.7.6
Qt version: 4.8.6
OCC version: 7.2.0
billfromnet
2018-05-30 12:27
reporter   ~0011303
Attaching sample fcstd file,
walls.fcstd (64,349 bytes)
billfromnet
2018-05-30 12:32
reporter   ~0011304
Never mind. Conflicting constraints cause the problem. Sorry to bother. Now how do I close this issue...
2018-05-30 15:43
administrator   ~0011305
@billfromnet no worries, I'll take care of it. In future please run issues by the community forum first. Thank you.
2018-05-30 12:23 billfromnet New Issue
2018-05-30 12:23 billfromnet Tag Attached: constraints
2018-05-30 12:23 billfromnet Tag Attached: display
2018-05-30 12:27 billfromnet File Added: walls.fcstd
2018-05-30 12:27 billfromnet Note Added: 0011303
2018-05-30 12:32 billfromnet Note Added: 0011304
2018-05-30 15:43 Kunda1 Status new => closed
2018-05-30 15:43 Kunda1 Resolution open => no change required
2018-05-30 15:43 Kunda1 Note Added: 0011305
2018-05-30 15:43 Kunda1 Tag Detached: display
2018-05-30 15:43 Kunda1 Tag Detached: constraints
