| 0003505 | TechDraw | Patch | public | 2018-06-09 11:37 | 2018-06-14 13:00 |
| Reporter | marams | Assigned To | wandererfan | ||
| Summary | 0003505: Insert new Page using Template: unicode filename | ||||
| Description | In TechDraw "Insert new Page using Template" fails if the path contains special characters. Patch attached. | ||||
0001-TechDraw-Insert-new-Page-using-Template-use-unicode-.patch (1,249 bytes)
From 41dad4c4de3051ff93ab453f3a78fabab4cbe39d Mon Sep 17 00:00:00 2001
Date: Sat, 9 Jun 2018 09:31:55 +0200
Subject: [PATCH] TechDraw: Insert new Page using Template: use unicode
filepath
src/Mod/TechDraw/Gui/Command.cpp | 2 +-
1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/src/Mod/TechDraw/Gui/Command.cpp b/src/Mod/TechDraw/Gui/Command.cpp
index 208921e6f..4430975f5 100644
--- a/src/Mod/TechDraw/Gui/Command.cpp
+++ b/src/Mod/TechDraw/Gui/Command.cpp
@@ -208,7 +208,7 @@ void CmdTechDrawNewPage::activated(int iMsg)
//why is "Template" property set twice? -wf
// once to set DrawSVGTemplate.Template to OS template file name
- doCommand(Doc,"App.activeDocument().%s.Template = '%s'",TemplateName.c_str(), templateFileName.toStdString().c_str());
+ doCommand(Doc,"App.activeDocument().%s.Template = \"%s\"",TemplateName.c_str(), (const char*)templateFileName.toUtf8());
// once to set Page.Template to DrawSVGTemplate.Name
doCommand(Doc,"App.activeDocument().%s.Template = App.activeDocument().%s",PageName.c_str(),TemplateName.c_str());
// consider renaming DrawSVGTemplate.Template property?
2.17.1
@marams thank you for the patch. Please familiarize yourself with the FC guidelines on how to post to our tracker. For example, from this ticket we don't know what version you are using, this can be easily solved with post you Help > About FreeCAD > Copy to clipboard Also, in order to prevent tracker bloat (as mentioned in the enormous yellow banner at the top of this page) we ask that people post their issues to the forum first in order for the community to evaluate if a ticket is merited. Here are our guidelines: https://freecadweb.org/wiki/Tracker CC @wandererfan |
@wandererfan when you get a moment, would you mind weighing in ? |
commit 79e290ff Don't know why it didn't get closed automagically. |
@wandererfan think you needed to use the '#' in front of the ticket number per https://freecadweb.org/wiki/Tracker#Remotely_resolving_a_ticket Also I think you need to put the actual in the commit body to trigger mantisbt (not the summary). Also MantisBT Source Integration plugin has been finicky and may just be broken |
Closed. |
| 2018-06-09 11:37 | marams | New Issue | |
| 2018-06-09 11:37 | marams | File Added: 0001-TechDraw-Insert-new-Page-using-Template-use-unicode-.patch | |
| 2018-06-09 13:02 | Kunda1 | Status | new => feedback |
| 2018-06-09 13:02 | Kunda1 | Note Added: 0011383 | |
| 2018-06-13 13:54 | Kunda1 | Note Added: 0011428 | |
| 2018-06-13 15:08 | wandererfan | Note Added: 0011429 | |
| 2018-06-13 15:09 | wandererfan | Status | feedback => resolved |
| 2018-06-13 15:09 | wandererfan | Resolution | open => fixed |
| 2018-06-13 15:09 | wandererfan | Fixed in Version | => 0.18 |
| 2018-06-13 15:09 | wandererfan | Target Version | => 0.18 |
| 2018-06-13 15:10 | Kunda1 | Note Added: 0011430 | |
| 2018-06-13 15:12 | Kunda1 | Note Edited: 0011430 | |
| 2018-06-14 13:00 | Kunda1 | Assigned To | => wandererfan |
| 2018-06-14 13:00 | Kunda1 | Status | resolved => closed |
| 2018-06-14 13:00 | Kunda1 | Note Added: 0011432 |
