| 0003513 | FreeCAD | Bug | public | 2018-06-16 16:20 | 2018-09-25 11:23 |
| Reporter | omni_brain | Assigned To | wmayer | ||
| Summary | 0003513: Can't open file - some exceptions are shown in the log | ||||
| Description | I'm new to cad and played a bit around with FreeCAD - may've made some mistakes with mesh constraints - however I would expect that the program maybe becomes slow but not destroying files :) I've attached the file - it always gives: ----------- Traceback (most recent call last): File "C:\Program Files\FreeCAD 0.17\bin\lib\json\__init__.py", line 339, in loads return _default_decoder.decode(s) File "C:\Program Files\FreeCAD 0.17\bin\lib\json\decoder.py", line 364, in decode obj, end = self.raw_decode(s, idx=_w(s, 0).end()) File "C:\Program Files\FreeCAD 0.17\bin\lib\json\decoder.py", line 382, in raw_decode raise ValueError("No JSON object could be decoded") <type 'exceptions.ValueError'>: No JSON object could be decoded ------------ Note that I used 0.18 designing that - I switched back to 0.17. I hope it helps. | ||||
| Steps To Reproduce | Try to load the file in 0.17 or 0.18 - loads somewhat but shows an error in the log | ||||
@omni_brain
This should be your first red flag. Try to start from scratch in 0.17 and recreate the steps and see if you get an issue. Some feedback about your ticket, you are missing key info to help us help you. Please read the enormous yellow banner at the top of the tracker page on how FreeCAD asks the community to go about reporting tickets |
I switched back to 0.17 because I couldn't load the file & edit the mesh with 0.18. I didn't use 0.17 and 0.18 to create that. Nor did I save that file with 0.17. It was just additional info what I've tried. I hoped that 0.17 could save some of my work - but it just showed the traceback from above. IDK when I've time to redo that - I think I'll first learn more about CAD software, maybe I made a bit too many constraints there. But in any case a good software product shouldn't produce invalid files/cause loss of work. The file can be opened and the 3d object can be seen but one of the meshes can't be edited :/. But that teaches me that if I use freecad I should do vsc for the cad files :). |
https://github.com/FreeCAD/FreeCAD/commit/b112ac0ec1ace8c297e6a2affc511a8e517a3fa5 The error message is a false-positive and the file can be loaded without any loss of information. |
| 2018-06-16 16:20 | omni_brain | New Issue | |
| 2018-06-16 16:20 | omni_brain | File Added: k2.FCStd | |
| 2018-06-17 11:01 | Kunda1 | Status | new => feedback |
| 2018-06-17 11:01 | Kunda1 | Note Added: 0011446 | |
| 2018-06-17 13:45 | omni_brain | Note Added: 0011448 | |
| 2018-06-17 13:45 | omni_brain | Status | feedback => new |
| 2018-09-25 11:23 | wmayer | Assigned To | => wmayer |
| 2018-09-25 11:23 | wmayer | Status | new => closed |
| 2018-09-25 11:23 | wmayer | Resolution | open => fixed |
| 2018-09-25 11:23 | wmayer | Fixed in Version | => 0.18 |
| 2018-09-25 11:23 | wmayer | Note Added: 0011833 |
