| 0003518 | Expressions | Bug | public | 2018-06-20 16:20 | 2020-01-06 20:32 |
| Reporter | amrit3701 | Assigned To | wmayer | ||
| Summary | 0003518: Expressions (fx) not updated | ||||
| Description | When I try to merge a parametric object in a new document, its expressions are not updated. For eg. suppose we have a parametric object which has an expression "object.Length.Value". And when I try to merge this object in some document which already have some objects, the newly merge object named as "object001" but its expression remains the same (i.e "object.Length.Value"). I expected that newly expression should changed as "object001.Length.Value". | ||||
| Additional Information | OS: Ubuntu 16.04.4 LTS Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.18.13919 (Git) Build type: None Branch: master Hash: 05bee3aa1fb8a27fa1528a50dc8f8b15ac5b0cce Python version: 2.7.12 Qt version: 4.8.7 Coin version: 4.0.0a OCC version: 7.2.0 Locale: English/India (en_IN) | ||||
Punting to @eivindkvedalen |
https://github.com/FreeCAD/FreeCAD/commit/de074ec4f37ee8baf4c268a3bc528f4bddf8ac15 |
@wmayer Thanks for fixing this issue but there is still small bug present. The expression after the first operator (+, -, *, /) is not updated. Explanation: I have created a Cube using Part workbench and also created a sketch of rectangle. Expression of one side of the rectangle is "Box.Length" and other side is "Box.Length + Box.Length". This file has two objects (i.e. Box and sketch) and saved it as testing.fcstd. Now, created a new document in FreeCAD, merged this testing.fcstd twice. This file has four objects (i.e. Box, Sketch, Box001 and Sketch001) and expressions of Sketch001 object are "[('Constraints[9]', 'Box001.Length'), ('Constraints[8]', 'Box001.Length + Box.Length')]". The first expression is updated properly (Box.Length -> Box001.Length) but the expression in which operators are used is not updated properly ('Box.Length + Box.Length' -> 'Box001.Length + Box.Length'). It should be equal to `Box001.Length + Box001.Length` |
@wmayer should we assign this ticket to the 0.19 milestone? |
I think we would need to replace all occurences of the object name in the expression string, I could try that: https://stackoverflow.com/questions/20406744/how-to-find-and-replace-all-occurrences-of-a-substring-in-a-string But there might be dire implications, such as an object having the same name as a property.. Ex an object named Length... |
Just tested this using the FreeCAD version below and was unable to reproduce the error described here. Rather, after merging the testing.fcstd document twice, the Expression with the operator was updated as expected to "Box001.Length + Box001.Length". Has this issue been resolved? OS: Gentoo/Linux Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.19.18787 (Git) Build type: Debug Branch: master Hash: 9898f3b242bec84396ee30a5722f8c462223e612 Python version: 3.6.5 Qt version: 5.12.4 Coin version: 4.0.0a OCC version: 7.3.0 Locale: English/United States (en_US) |
@ezzieyguywuf Let me test more cases before closing this ticket. |
@amrit3701 any progress ? |
@Kunda1 Thanks for the ping. I tested it on lastest FreeCAD 0.19v and it looks like this bug is resolved. Now we can close this ticket. @wmayer thanks for fixing this issue! OS: macOS 10.15 Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.19.19145 (Git) Build type: Release Branch: master Hash: c43315728cc643c6a382af0bba5b596407bbaf26 Python version: 3.7.6 Qt version: 5.12.5 Coin version: 4.0.0a OCC version: 7.3.0 Locale: English/India (en_IN) |
Fixed in c:FreeCAD:de074ec4f37ee8: |
| 2018-06-20 16:20 | amrit3701 | New Issue | |
| 2018-06-22 13:03 | Kunda1 | Project | FreeCAD => Expressions |
| 2018-06-22 13:03 | Kunda1 | Assigned To | => eivindkvedalen |
| 2018-06-22 13:03 | Kunda1 | Status | new => assigned |
| 2018-06-22 13:04 | Kunda1 | Note Added: 0011462 | |
| 2018-11-11 09:59 | wmayer | Assigned To | eivindkvedalen => wmayer |
| 2018-11-11 09:59 | wmayer | Status | assigned => closed |
| 2018-11-11 09:59 | wmayer | Resolution | open => fixed |
| 2018-11-11 09:59 | wmayer | Fixed in Version | => 0.18 |
| 2018-11-11 09:59 | wmayer | Note Added: 0012174 | |
| 2018-11-11 11:30 | wmayer | Relationship added | has duplicate 0003462 |
| 2019-07-06 10:16 | amrit3701 | Status | closed => feedback |
| 2019-07-06 10:16 | amrit3701 | Resolution | fixed => reopened |
| 2019-07-06 10:16 | amrit3701 | Note Added: 0013336 | |
| 2019-07-29 14:51 | Kunda1 | Note Added: 0013392 | |
| 2019-07-29 14:52 | Kunda1 | Status | feedback => assigned |
| 2019-08-13 15:08 | yorik | Note Added: 0013424 | |
| 2019-12-03 03:39 | ezzieyguywuf | Note Added: 0013856 | |
| 2019-12-03 15:06 | amrit3701 | Note Added: 0013860 | |
| 2020-01-06 16:00 | Kunda1 | Note Added: 0013993 | |
| 2020-01-06 18:27 | amrit3701 | Note Added: 0014004 | |
| 2020-01-06 18:28 | amrit3701 | Note Edited: 0014004 | |
| 2020-01-06 18:30 | amrit3701 | Note Edited: 0014004 | |
| 2020-01-06 20:32 | Kunda1 | Status | assigned => closed |
| 2020-01-06 20:32 | Kunda1 | Note Added: 0014005 |
