| 0003523 | FreeCAD | Bug | public | 2018-07-02 02:19 | 2020-03-27 13:32 |
| Reporter | ger08061959 | Assigned To | |||
| Summary | 0003523: Crash (after installing PySide2) with segmentation fault | ||||
| Description | Sheet Metal workbench loaded nurbs configuration file loaded During initialization the error 'module' object has no attribute 'getModulePath' occurred in /home/ger/.FreeCAD/Mod/Cfd/InitGui.py Please look into the log file for further information ERROR 1: libgrass_dgl.7.4.1.so: cannot open shared object file: No such file or directory ERROR 1: libgrass_dgl.7.4.1.so: cannot open shared object file: No such file or directory ERROR 1: libgrass_vector.7.4.1.so: cannot open shared object file: No such file or directory ERROR 1: libgrass_vector.7.4.1.so: cannot open shared object file: No such file or directory Program received signal SIGSEGV, Segmentation fault. #0 /lib/x86_64-linux-gnu/libc.so.6(+0x3ef20) [0x7f5993d0cf20] #1 /lib/x86_64-linux-gnu/libc.so.6(+0x190e30) [0x7f5993e5ee30] 0000002 /home/ger/.local/lib/python2.7/site-packages/PySide2/Qt/lib/libQt5Core.so.5(+0x278a88) [0x7f590c8b8a88] 0000003 0x7f590c8bb951 in QMetaType::registerNormalizedType(QByteArray const&, void (*)(void*), void* (*)(void*, void const*), int, QFlags<QMetaType::TypeFlag>, QMetaObject const*) from /home/ger/.local/lib/python2.7/site-packages/PySide2/Qt/lib/libQt5Core.so.5+0x61 0000004 /home/ger/.local/lib/python2.7/site-packages/PySide2/QtCore.so(+0x2138c6) [0x7f590ddae8c6] 0000005 /home/ger/.local/lib/python2.7/site-packages/PySide2/QtCore.so(initQtCore+0x4b) [0x7f590de3333b] 0000006 /usr/lib/x86_64-linux-gnu/libpython2.7.so.1.0(_PyImport_LoadDynamicModule+0x9b) [0x7f599599ccab] 0000007 /usr/lib/x86_64-linux-gnu/libpython2.7.so.1.0(+0x1d4afe) [0x7f5995a20afe] | ||||
| Steps To Reproduce | Start the stable version after installing pyside2 from qt website | ||||
Recompiling with Qt5 disabled still includes Qt5 and pyside2 and gives same crash.cd, recompiling with QT5 switch off, ensure nothing of pyside2 is referred to, still references to the pyside2 libraries, which crash. Uninstall (pip uninstall pyside2) removes the crashing problem. |
@ger08061959 please follow the instructions in the large yellow banner at the top of any of the FC tracker pages. You have not provided enough information for us to help you. Please also open a forum thread to discuss this with the community. |
I saw the big yellow banner: 1. No post found that stable version 0.17 would crash after installing pyside2. 2. Programs loads a few workbenches than crashes with given trace (started via console to get trace) 3. Program seems to load a few workbenches (as seen) but version 0.17 never get up and running. 4. Can't post version info as progrma crashes. 5. Program does not start so there is not a specific example where it crashes. It crashes before anything is done. Problems seems to be in the pyside2 module. If present it disrupt even stable version re-installed, source version does not compile with QT5 (requires pyside but cmake can't find), nor does work when compile with Qt 4 (can't load any module because lacking system modules from pyside2 (??)) What's the way to get FreeCAD compile with Qt5 so I can make use of the newer 3D? |
@ger08061959 like I said, the guidelines state to open a forum thread to discuss with the community directly. There are very established forum threads that discuss QT5 and py3 porting. Here is a quick example: https://forum.freecadweb.org/viewtopic.php?f=4&t=26754&p=234989 @looo please weigh in. Thanks! |
@ger08061959 is this still presenting as an issue ? |
@ger08061959 ping |
No response from OP. closing ticket |
| 2018-07-02 02:19 | ger08061959 | New Issue | |
| 2018-07-02 02:34 | ger08061959 | Note Added: 0011478 | |
| 2018-07-02 03:13 | ger08061959 | Note Edited: 0011478 | |
| 2018-07-03 02:12 | Kunda1 | Status | new => feedback |
| 2018-07-03 02:12 | Kunda1 | Note Added: 0011481 | |
| 2018-07-03 17:48 | ger08061959 | Note Added: 0011490 | |
| 2018-07-03 17:48 | ger08061959 | Status | feedback => new |
| 2018-07-05 00:29 | Kunda1 | Note Added: 0011493 | |
| 2019-06-20 07:24 | Kunda1 | Status | new => feedback |
| 2019-06-20 07:24 | Kunda1 | Note Added: 0013277 | |
| 2020-01-06 16:23 | Kunda1 | Note Added: 0013999 | |
| 2020-03-27 13:32 | Kunda1 | Status | feedback => closed |
| 2020-03-27 13:32 | Kunda1 | Resolution | open => no change required |
| 2020-03-27 13:32 | Kunda1 | Note Added: 0014306 |
