| 0003540 | PartDesign | Bug | public | 2018-07-16 23:41 | 2018-09-21 13:15 |
| Reporter | chrisb | Assigned To | wmayer | ||
| Summary | 0003540: Body invisible after deleting Part container | ||||
| Description | If I have a Part contaner that contains a body and I delete the Part without deleting its contents, the the body becomes invisible until it is reloaded. Corresponding forum discussion | ||||
| Steps To Reproduce | - Open the file attached to the first forum post - delete Part, say "no" to deleting the contents too Now body is invisible. | ||||
Issue was confirmed in forum thread. |
There is a similar issue with the PartDesign Boolean feature. If one deletes a PD Boolean feature, the Body that was used as Tool remains invisible. A new view (View --> New view menu) is the only way to make the Body visible in the 3D view again. Not sure if this should be treated as a separate issue. |
https://github.com/FreeCAD/FreeCAD/commit/75acfe898f97d213647b0b93032287e48a31abfe |
| 2018-07-16 23:41 | chrisb | New Issue | |
| 2018-07-27 14:06 | Kunda1 | Status | new => confirmed |
| 2018-07-27 14:06 | Kunda1 | Note Added: 0011551 | |
| 2018-07-27 14:06 | Kunda1 | Target Version | => 0.18 |
| 2018-09-03 08:19 | normandc | Note Added: 0011694 | |
| 2018-09-21 13:14 | wmayer | Severity | tweak => minor |
| 2018-09-21 13:15 | wmayer | Assigned To | => wmayer |
| 2018-09-21 13:15 | wmayer | Status | confirmed => closed |
| 2018-09-21 13:15 | wmayer | Resolution | open => fixed |
| 2018-09-21 13:15 | wmayer | Fixed in Version | => 0.18 |
| 2018-09-21 13:15 | wmayer | Note Added: 0011802 |
