| 0003542 | Path | Bug | public | 2018-07-20 16:19 | 2020-12-01 17:06 |
| Summary | 0003542: Clean up import/export UI | ||||
| Description | The File open/import/export menus allow GCode as an option. IMPORT/OPEN 1. opens the selector dialog for the pre-processor 2. Creates a naked path object in the tree EXPORT 1. opens the dialog to select the post-processor 2. attempts to post whatever object is selected This is really the wrong way to handle post-processing and is confusing to users | ||||
| Additional Information | Recommend the following changes. 1. Remove gcode from the File import/export file types. 2. Add import... and export (post process)... menu items to the Path menu 3. export (post-process)... should trigger the current post process behavior 4. import should create a custom object in a Job. existing export template... item should be left as is. | ||||
The improved custom (gcode_pre) preprocessor now creates an item in a Path Job. Export from the main menu has been removed. |
@sliptonic any commit(s) associated with this ticket ? |
https://github.com/FreeCAD/FreeCAD/commit/d5edb6ed2a81948e898d1954c302ea5e1ec77411 c:FreeCAD:d5edb6ed2a81948e898d1954c302ea5e1ec77411: FreeCAD master fbb59ae7 |
Closing ticket |
| 2018-07-20 16:19 | sliptonic | New Issue | |
| 2018-07-20 16:19 | sliptonic | Status | new => assigned |
| 2018-07-20 16:19 | sliptonic | Assigned To | => sliptonic |
| 2019-01-22 04:03 | sliptonic | Target Version | 0.18 => 0.19 |
| 2020-10-07 18:14 | sliptonic | Status | assigned => resolved |
| 2020-10-07 18:14 | sliptonic | Resolution | open => fixed |
| 2020-10-07 18:14 | sliptonic | Note Added: 0014787 | |
| 2020-10-08 01:14 | Kunda1 | Note Added: 0014792 | |
| 2020-12-01 17:03 | Kunda1 | Note Added: 0015045 | |
| 2020-12-01 17:04 | Kunda1 | Changeset attached | => FreeCAD master fbb59ae7 |
| 2020-12-01 17:05 | Kunda1 | Note Edited: 0015045 | |
| 2020-12-01 17:06 | Kunda1 | Status | resolved => closed |
| 2020-12-01 17:06 | Kunda1 | Fixed in Version | => 0.19 |
| 2020-12-01 17:06 | Kunda1 | Note Added: 0015046 |
