0003555FreeCADGeneralpublic2021-02-06 06:32
Reporterwyman Assigned Tonormandc
Product Version0.17
Target Version0.20
Summary0003555: Tutorial documentations:Creating a simple part with PartDesign
Description1) the mis-match color of icon "create body".
2) mis-match wording, tutorial shows "...new object labelled "Body" appears under the document label", propram screen shows "Part".
3) unclear instruction about section "Create sketch: ", on ready on screen icon as "Press New sketch", guess it is from upper menu bar with pull down arrow, but the icon wording is skecther not "sketch", and no prompt for "ok". Later found out it was problem between direction instruction steps and background of the command of sketch.
4) By section "Using Pad and Pocket features", before "...Click on Pad...", should add hints to tell to go to [Part Design] then click icon [Pad].
Unable to go further with the tutorial. Screen shows "In order to sue PartDesign you need an active Body object in the document. Please make on active(double click) or create one..." I tried clicking [Pad] both at the white sketch or green sketch. No length question dialogue box appeared.
That is all.
Tagsdocumentation, wiki
2018-08-12 23:39
administrator   ~0011617
@wyman
What tutorial are you referring to ?
wyman
2018-08-13 02:54
reporter   ~0011618
The tutorial from below:
https://www.freecad.org/wiki/Creating_a_simple_part_with_PartDesign
2018-08-23 16:49
administrator   ~0011639
Forum thread: https://forum.freecad.org/viewtopic.php?f=21&t=30471
normandc
2018-08-25 17:36
manager   ~0011651
There is no mist-match of color. Reporter simply used the wrong tool and created a Part container (yellow) instead of a PartDesign Body (blue). All further difficulties result from this error.
The tutorial's introduction specifically mentions it is about designing a part in the PartDesign workbench, and it instructs to switch to it from the beginning.
Next time, don't create a bug report. Post your questions and comments on the FreeCAD forum.
2018-08-12 01:26 wyman New Issue
2018-08-12 23:39 Kunda1 Note Added: 0011617
2018-08-12 23:40 Kunda1 Note Edited: 0011617
2018-08-13 02:54 wyman Note Added: 0011618
2018-08-23 16:49 Kunda1 Note Added: 0011639
2018-08-23 16:49 Kunda1 Status new => acknowledged
2018-08-23 16:50 Kunda1 Tag Attached: documentation
2018-08-23 16:50 Kunda1 Tag Attached: wiki
2018-08-25 17:36 normandc Assigned To => normandc
2018-08-25 17:36 normandc Status acknowledged => closed
2018-08-25 17:36 normandc Resolution open => no change required
2018-08-25 17:36 normandc Note Added: 0011651
2021-02-06 06:32 abdullah Target Version => 0.20
