| 0003560 | Spreadsheet | Bug | public | 2018-08-15 12:28 | 2021-11-24 15:22 |
| Reporter | lokomoko | Assigned To | eivindkvedalen | ||
| Summary | 0003560: Renaming alias in spreadsheet changes the spreadsheet part of the reference from label to internal name | ||||
| Description | Renaming an alias in a spreadsheet changes the spreadsheet-part of a reference to the alias from Label (e.g. "MyInputData") to internal name/Id (e.g. "Spreadsheet001"). Discussed in Forum under Renaming alias in spreadsheet changes the name of the spreadsheet in any reference | ||||
| Steps To Reproduce | 1. Create new document 2. In spreadsheet workbench create a spreadsheet by the name "MyData" 3. Create cell with an alias e.g. "BoxSize" and a value 4. In part workbench create a 3D-object (e.g. cube) and therein a reference to the alias (e.g. "=MyData.BoxSize"). 5. In spreadsheet change name of alias to BoxLength Actual Result: The reference in the 3D-Object is "=Spreadsheet001.BoxLength" now, that is the alias was changed, but also the name of the spreadsheet Expected Result: The reference in the 3D-Object should be "=MyData.BoxLength" | ||||
| Additional Information | OS: Ubuntu 16.04.5 LTS Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.17.13528 (Git) AppImage Build type: None Branch: releases/FreeCAD-0-17 Hash: 5c3f7bf8ec51e2c7187789f7edba71a7aa82a88b Python version: 2.7.6 Qt version: 4.8.6 Coin version: 4.0.0a OCC version: 7.3.0 Locale: German/Germany (de_DE) | ||||
| Tags | equation, expressions, formula, spreadsheet | ||||
|  | Direct link to forum topic Renaming alias in spreadsheet changes the name of the spreadsheet in any reference |
|  | When renaming an alias then at some point the functions Document::renameObjectIdentifiers,  DocumentObject::renameObjectIdentifiers, PropertyExpressionEngine::renameObjectIdentifiers and ObjectIdentifier::relativeTo are called. Because the ObjectIdentifier hasn't explicitly set documentObjectName it gets the (internal) name from the pointer to the DocumentObject. |
|  | This ticket has been migrated to GitHub as issue 5800. |
| 2018-08-15 12:28 | lokomoko | New Issue | |
| 2018-08-15 12:28 | lokomoko | Tag Attached: equation | |
| 2018-08-15 12:28 | lokomoko | Tag Attached: expressions | |
| 2018-08-15 12:28 | lokomoko | Tag Attached: formula | |
| 2018-08-15 12:28 | lokomoko | Tag Attached: spreadsheet | |
| 2018-08-15 12:41 | lokomoko | Note Added: 0011625 | |
| 2018-08-17 13:39 | Kunda1 | Description Updated | |
| 2018-11-11 11:27 | wmayer | Assigned To | => eivindkvedalen |
| 2018-11-11 11:27 | wmayer | Status | new => confirmed |
| 2018-11-11 11:27 | wmayer | Note Added: 0012176 | |
| 2021-11-24 15:22 | chennes | Project | FreeCAD => Spreadsheet |
