| 0003577 | Draft | Bug | public | 2018-09-02 00:27 | 2019-08-14 22:17 |
| Reporter | bkardon | Assigned To | Kunda1 | ||
| Platform | Mac OS | OS | macOS Sierra | OS Version | 10.12.6 |
| Summary | 0003577: FreeCAD crashes when I click on the Draft>Rectangle tool | ||||
| Description | FreeCAD crashes when I click the "Draft>Rectangle" tool. Thanks for all your work! | ||||
| Steps To Reproduce | 1. Open FreeCAD 0.17 2. Create a new empty document 3. Select the Draft workbench from the dropdown menu 4. Click the Draft>Rectangle tool 5. FreeCAD crashes immediately | ||||
| Additional Information | Here's my FreeCAD info:
Here is the terminal output from following the steps to reproduce:
I tried to get the FreeCAD "log" file after the crash, but running "FreeCAD -l" did not result in the creation of a log file as described in the documentation. Maybe I did it wrong or wasn't looking in the right place. | ||||
| Tags | macOS | ||||
I apologize, I seem to have accidentally posted this issue twice. I'm not sure how to delete it at this point. |
You can't. Only a Manager or Developer can. I deleted your duplicate issue. Please check if the issue still exists in the current development build, available here: https://github.com/FreeCAD/FreeCAD/releases/tag/0.18_pre The revision number is wrong (5235), it was built last week and should be around 14400. |
I can't reproduce on OS: Ubuntu 18.04.1 LTS Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.17.13541 (Git) Build type: None Branch: releases/FreeCAD-0-17 Hash: 9948ee4f1570df9216862a79705afb367b2c6ffb Python version: 2.7.15rc1 Qt version: 4.8.7 Coin version: 4.0.0a OCC version: 7.3.0 Locale: French/Canada (fr_CA) Please report if other Draft tools produce the crash. |
@bkardon please respond |
@bkardon ping |
@bkardon please test this on the 0.18dev build and report back. @chrisb care to test this out on MacOS ? |
Hey @peterl94 can you reproduce this issue? |
@chrisb please test on osx thanks |
@looo care to test this on OSX ? |
Discussion thread: https://forum.freecadweb.org/viewtopic.php?f=8&t=37938 |
@chrisb can't reproduce per https://forum.freecadweb.org/viewtopic.php?f=8&t=37938&p=326906#p326906 |
Closing |
| 2018-09-02 00:27 | bkardon | New Issue | |
| 2018-09-02 00:31 | bkardon | Note Added: 0011679 | |
| 2018-09-02 18:43 | normandc | Note Added: 0011681 | |
| 2018-09-02 19:26 | normandc | Note Added: 0011682 | |
| 2018-10-02 20:59 | Kunda1 | Note Added: 0011891 | |
| 2018-10-02 20:59 | Kunda1 | Status | new => feedback |
| 2018-10-17 20:26 | Kunda1 | Note Added: 0012049 | |
| 2018-10-28 02:37 | Kunda1 | Note Added: 0012103 | |
| 2019-01-05 11:51 | Kunda1 | Note Added: 0012382 | |
| 2019-02-27 21:47 | Kunda1 | Note Added: 0012794 | |
| 2019-03-03 14:05 | Kunda1 | Tag Attached: MacOSX | |
| 2019-04-06 19:24 | Kunda1 | Note Added: 0013012 | |
| 2019-07-23 23:55 | Kunda1 | Note Added: 0013382 | |
| 2019-08-14 21:58 | Kunda1 | Note Added: 0013426 | |
| 2019-08-14 22:17 | Kunda1 | Assigned To | => Kunda1 |
| 2019-08-14 22:17 | Kunda1 | Status | feedback => closed |
| 2019-08-14 22:17 | Kunda1 | Resolution | open => no change required |
| 2019-08-14 22:17 | Kunda1 | Note Added: 0013427 | |
