| 0003579 | Sketcher | Feature | public | 2018-09-02 16:51 | 2018-10-06 14:43 |
| Priority | low | Severity | feature | Reproducibility | have not tried |
| Summary | 0003579: Esc key should not leave Sketcher. It interferes with the Create tools | ||||
| Description | Create tools can be ended by pressing Esc, some modes like Polyline even need 2 Esc keypresses. One keypress too much exits Sketcher, sometimes unwanted. Since a key for "Exit Skecther" can be configured Esc key should be removed here. Forum discussion. | ||||
| Tags | shortcuts | ||||
It would appear to me that the perceived problem was already solved here: https://forum.freecadweb.org/viewtopic.php?f=34&t=30643&start=20#p255406 Do we still know to strip the ESC from closing? |
The usage of ESC for closing dialogs is considered to be UI standard. See: https://forum.freecadweb.org/viewtopic.php?f=34&t=30643&start=20#p259336 |
| 2018-09-02 16:51 | chrisb | New Issue | |
| 2018-09-02 19:30 | Kunda1 | Tag Attached: shortcuts | |
| 2018-09-28 14:08 | abdullah | Note Added: 0011868 | |
| 2018-10-06 05:50 | abdullah | Assigned To | => abdullah |
| 2018-10-06 05:50 | abdullah | Status | new => assigned |
| 2018-10-06 05:51 | abdullah | Status | assigned => resolved |
| 2018-10-06 05:51 | abdullah | Resolution | open => won't fix |
| 2018-10-06 05:51 | abdullah | Note Added: 0011941 | |
| 2018-10-06 14:43 | abdullah | Status | resolved => closed |
